BST on Windows 8 Problem
Bean
I'm trying to setup BST on a client's Dell inspiron 15 notebook computer that has windows 8.
When I run the bst.exe I see the splash screen, it goes away but the editor screen never comes up.
The program stays running, but there is no display.
Has anyone else had this problem ?
Does anyone know what might be the problem ?
Bean
Bean
SimpleIDE uses the same compiler, BSTC, so there should be no loss funtionality.
No one is maintaining BST anymore so these problems will keep piling up until it's unusable.
Jonathan
I found out that for some reason it would start minimized and wouldn't restore when you clicked on in in the task bar.
If I started it, then pressed ALT-Space I could maximized it. From then on it would start fine.
Weird...
Bean
So this thread is SOLVED then?
Good to know! Must file that away.
If only SimpleIDE supported PropBasic, I'd use it in a heartbeat.
Bean
