an IR localizer
I'm building a little cheap and dirty IR localizer so that one machine can locate another using IR codes. The problem seems to be that the IR sensor picks up the signal in a fairly widfe area.(the IR sensor is mounted on a Pan mechanism. So possible solutions could be:
1. Put a black tube over the receiver (could it be this easy?
2. Pan and find the Extents of where it receives---seems like a slow solution.
3. Reduce the output of the transmitter.
4. Find a different receiver
my components are those that come in standard Boe Bot Kit
Just looking for suggestions
You want to make sure the tube material doesn't transmit or reflect IR.
Roger that. Paint the inside of the tube with flat or ultra flat black paint.
I also made sensor hoods from black construction paper, but it took 2 layers to be IR-opaque and work properly. IR gets through some of the darndest things quite easily, some things that appear quite opaque to the eye. Visible light and IR are very different animals.
