New Product! EasyVR Development Kit
As Emily Kurze posted here Parallax has a new product, the EasyVR Development Kit.
I'm trying to figure out how this is different than the SayIt module Parallax used to sell?
As far as I can tell, the second board with an USB connector, is mainly used to interface the EasyVR with a PC. This eliminates the need for a bridge program to be loaded to a Basic Stamp or a Propeller.
Does anyone know if the EasyVR in a drop in replacement for the SayIt? I'm guessing it is.
I think there's some SayIt demo code in the OBEX and I posted some Propeller SayIt code in this thread. I'd be surprised if this code doesn't work with the EasyVR.
The original SayIt demo code for the Basic Stamp should also work with the EasyVR.
I'm glad to see this item for sale from Parallax.
Is this what they meant to say?
I think they're trying to point out the second board with the USB connection lets you start using the EasyVR without having to deal with loading a bridge program on your microcontroller. This lets you "spend time training your voice commands and developing your application" instead of spending time trying to figure out how to interface with the EasyVR.
I sure do... my mouse finger is itchn'! I'm a big fan of speech recognition based on Sensory components, it seems to be some of the best executed to date.
I'd like to emulate the voice command home automation module called VoicePod which I believe is also based on the Sensory chipset. Take a look at the videos at www.voicepod.com , the attention word or phrase and voice menu systems are the same as EasyVR.
While these can be used with a Basic Stamp they are much more useful with a Propeller since the Prop can listen for input from the module while actively doing other things. With the Basic Stamp, the Stamp has to stop and wait for input from the module and will miss any commands when it's not actively listening. When the Stamp is listening for the module, it can't do anything else.
You'll have trouble using this on a robot while the robot is in motion (the noise from the motors will likely interfere with the device). You'll either need to have the robot stop and listen or use the module on a remote device and send the new commands wirelessly to the robot.
If I didn't already have two SayIt modules, I'd get one of these.
Having the mic on a wire makes this module much more useful than the SayIt. I actually removed the mic from one SayIt to use on wire. I also removed the additional PCB from the same SayIt.
If anyone would rather have a SayIt than one of these modules, I'll trade my unmodified SayIt for an EasyVR module.
@NWCCTV, If you buy one and don't like it, I'll buy it off you for $45. Now it's not such a risky purchase. IMO, these things are pretty cool.
This is the link to the one that I have
http://www.robotshop.com/easyvr-speech-voice-recognition-module.html?utm_source=google&utm_medium=base&utm_campaign=jos
I doesn't look like there is any Spin code from Parallax at this time, (it's a brand new item)
This link may help with some code:
http://forums.parallax.com/showthread.php/139017-Say-it-Module-disappearance?p=1086214&viewfull=1#post1086214
Check post #1. The Prop code for the SayIt should work for the EasyVR.
Does anyone know if the same limits apply to this module as to the SayIt, in terms of total number of custom phrases that can be programmed? I didn't see the number in the User Manual, although - just like the SayIt module - you can only program one other custom trigger word in addition to the default "robot", so I'm guessing that we are still limited to 16 or 32 user-defined phrases...?
Page 5 of the new manual lists the speaker dependent words as 32. Same as the SayIt.
Thanks for being my non-fuzzy eyes on that item Duane :-)
