Inexpensive, Basic StampEABLE graphic LCDs exist?
By inexpensive I mean price less than $<10
By StampEABLE I mean LCD that has own controller, where you can load your character map, graphics, etc. Via SPI/I2C or other, stamp-friendly way.
So far, the simplest way I've found is to use MAX7456+3.5' LCD AV Monitor from ebay. The combo surely costs lot more than $10, around $30, but so far this is the cheapest combo. Any ideas?
1.8" large enough?
http://www.ebay.com/itm/1-8-Serial-TFT-Color-LCD-Display-Module-With-SPI-Interface-5-IO-Ports-128X160-/190828797169?pt=AU_B_I_Electrical_Test_Equipment&hash=item2c6e485cf1#ht_3522wt_881
2.2" which seems to have a uSD slot:
http://www.ebay.com/itm/Hot-sale-2-2-inch-Serial-SPI-TFT-Color-240X320-LCD-Module-ILI9341-Driver-IC-/200942108654?pt=AU_B_I_Electrical_Test_Equipment&hash=item2ec9153fee#ht_5078wt_1119
71 x 35.5mm, without backlight
http://www.ebay.com/itm/Serial-SPI-Large-12864-128x64-Dots-Graphic-LCD-SMD-Socket-for-Arduino-AVR-PIC-/251304812059?pt=LH_DefaultDomain_0&hash=item3a82ef1e1b#ht_3357wt_1119
It even does not have the screen shadow ram, so you have to keep a copy of screen in your application ram, to avoid collizions and overprints.
