Neverwet - hydropobic coating
Does anybody know about this stuff?
http://www.youtube.com/watch?v=DZrjXSsfxMQ
Specifically, is it insanely toxic or something?
http://www.homedepot.com/p/Rust-Oleum-Stops-Rust-18-oz-NeverWet-Multi-Purpose-Spray-Kit-274232/204216476#.Ue9O2-FeY0k
(PDF) http://www.rustoleum.com/MSDS/ENGLISH/274234.PDF
(PDF) http://www.rustoleum.com/MSDS/ENGLISH/274233.PDF
Not sure if I'd want to spray Acetone around anything I liked.
I find it hard to believe they're reccomending spraying this on a PCB lol...
The nice thing about it being paint is you can just repaint the wall every time someone screws up and uses a permanent marker instead of a dry erase one...
C.W.
Edit:
Geez, I just checked out the price...that's a non-starter.
Much cheaper to use smooth melamine coated board.
Back when my shop did component level repair we used to clean PCB's with acetone. For the most part the plastics used in electornic components and circuit boards are immune to its solvent effects, and it is hydrophobic and evaporates very quickly making it a good solvent for depositing something else that is hydrophobic in suspension.
I think you meant hydrophilic. Acetone is pretty much completely soluble in water.
Jim
I wonder if the affect is more permanent in conjunction with rustoleum? I don't what to try this on. Ideas?
