The main problem is that peak current for some SD cards can be well over the 40mA that a Propeller I/O pin is capable of. There are ways around this because the peak current is transient and the average current is well below the maximum, but the fixes would be much more complicated than just running the SD card off the Prop's power supply.
Cluso99 recently posted a thread about using Prop pins for power. His warning about adding medium to large capacitor probably saved me from killing yet another Prop.
That's a 'yes' to hopeless na
For example, use a transistor controled by a prop pin to switch poweroff?
