Powering a micro SD card from Prop pins?
Hugh
Would I be hopelessly naive to try to supply Gnd and 3.3V to a micro SD card socket by using prop pins set low and high?
Hugh
Hugh
That's a 'yes' to hopeless na
For example, use a transistor controled by a prop pin to switch poweroff?
