MAX6675 For Reflow Oven controller — Parallax Forums
Igor_RastIgor_Rast Posts: 357
edited 2013-07-30 13:01 in Propeller 1
Ok ,
SO I am trying to build a small reflow oven controller, already have the oven ( a small 9liter model ) modified bringin both heating elements to the top , also a solid state relay to turn it on/off . ill figure pwm will have to do that later .
But for the moment I cant get to seem to get any temp readings out of the max 6675 ,
This is my second one , The first one , i think i blew it up by putting more then 5 volts acoss it by accident , but now the second ( these are not the cheapest ) is also not sowing me some love here
Anyone mind sharing a pice of code , I have tryied modifinig the one found in the obex(Mike Lord) that usualy works with a tv , but I need it to work on terminal to start with , after i got a 20X4 lcd already hooked and working . still no luck with it .
code used is below ,
CON
  _CLKMODE      = XTAL1 + PLL16X
  _XINFREQ      = 5_000_000
      SCK      =  0
      CS       =  1
      So       =  18
      TempScale  = 0     '1 is Farienheight   0 is Centegrade
    RS = 11      ' 1
    RW = 10      ' 2
    E  = 9      ' 3
    DBLow  = 12    ' 0
    DBHigh = 15
  ' ASCII codes.
    CR  = 13
    LF  = 10
    PSTClearScreen = 16
Var
       Long TempIn
OBJ
      Max6675       :  "Max6675_K_thermoCouple"
       pst : "parallax serial terminal"
        LCD : "LCD_20x4"
PUB _Start    |  TimeCnt_10Hz,  DisplayTime  , ElapsedCnt , index  , AddrVar
       Initialize
          LCD.RawSetPos( $00 ) ' "first" line
          LCD.RawWriteStr( string("reading sendor") )
        waitcnt(clkfreq *2 + cnt)
        repeat
             '  !Outa[LedPin]
               Max6675.ReadTemp(So, CS, SCK , TempScale , @TempIn  )
                pst.Str(String("Measured Temperture in Celsius = "))
                pst.dec( Tempin)
                pst.Str(String(" ",13))
              'LCD.RawSetPos( $40 ) ' "second" line
             ' LCD.RawWriteStr( string(Tempin) )
              waitcnt(clkfreq *2 + cnt)    'dont scan too fast or the conversion will not run
Pub  Initialize
   'Start cogs
           pst.start(115_200)
        waitcnt(clkfreq + cnt)
        pst.str(string(13,"MAX6675 ThermoCouple Demo.",13))
    LCD.usDelay( 5_0 ) ' time enough to switch to PST
     pst.str(string(13,"Start LCD Driver.",13))
    LCD.Init( E, RS, RW, DBHigh, DBLow )
    LCD.Clear
    LCD.usDelay( 2_000_000 )
''*  MAX675 v1.1                        *
''*  Author: Mike Lord                  *
''*  Copyright (c) Mike Lord            *
''*  Mike@electronicdesignservice.com   *
''*  650-219-6467                       *
''*  See end of file for terms of use.  *
' v1.0 - 01 Jul7 2011 - original version
This is written as a spin driver for the max6675 K type thermocouple chip.
│ MAX6675 driver                      │ PG             | (C) 2011            | July 20 2011  |
│ A driver for the MAX6675 K Type theromcouple chip                                          │
| See end of file for terms of use                                                           |
 SCHEMATIC
             Gnd 1  │      │ 8 Nc
             T+  2  │MAX   │ 7 Sd
             T-  3  │6675  │ 6 Cs
             Vcc 4  │      │ 5 Sck
CON
var   long stack1[20]
      long CogNr,InBit,Value
obj
      Tv        :  "Mirror_TV_Text"
Pub  ReadTemp(SD, CS, SCK, TempScale , TempertureIn_Addr )  | Index  , AddrVar
              ' SD, CS, SCK are the pin numbers of the propeller connected to the max6675
              'TempScale  = 1     '1 is Farienheight   0 is Centegrade
           dira[Cs] := 1
           dira[SCK] := 1
           dira[Sd] := 0
          Outa[Cs] := 1     'Make sure chip select is high
          Outa[SCK] := 0    'make sure Sck is low as initial value
          Outa[Cs] := 0     'Now take Chip select low to shart shift out of data
          'Tv.out($0A)      'X position follows
          'Tv.out( 1 + index )
          'Tv.out($0B)      'Y position follows
          'Tv.out( 3 )
          'Repeat Index from 0 to 15
                Waitcnt(clkfreq /10_000 + cnt)
                Outa[SCK] := 1
                Outa[SCK] := 0      'Data is now ready to be read
                Long[@TempertureIn_Addr] :=  67   'Ina[Sd]
                'Tv.hex( @TempertureIn_Addr, 4 )
               ' Tv.Str(String("-"))
                'Tv.dec(Long[@TempertureIn_Addr])
                'Tv.Str(String("  "))
           '  Tv.out($0D)
        'Tv.Str(String("after routine"))
  return
PUB SHIFTIN (Dpin, Cpin, Mode, Bits) : Value | InBit
   Shift data in, master clock, for mode use BS2#MSBPRE, #MSBPOST, #LSBPRE, #LSBPOST
   Clock rate is ~16Kbps.  Use at 80MHz only is recommended.
     X := BS2.SHIFTIN(5,6,BS2#MSBPOST,8)
    dira[Dpin]~                                            ' Set data pin to input
    outa[Cpin]:=0                                          ' Set clock low
    dira[Cpin]~~                                           ' Set clock pin to output
    If Mode == MSBPRE                                      ' Mode - MSB, before clock
       Value:=0
       REPEAT Bits                                         ' for number of bits
          InBit:= ina[Dpin]                                ' get bit value
          Value := (Value << 1) + InBit                    ' Add to  value shifted by position
          !outa[Cpin]                                      ' cycle clock
          !outa[Cpin]
          waitcnt(1000 + cnt)                              ' time delay
    elseif Mode == MSBPOST                                 ' Mode - MSB, after clock
       Value:=0
          !outa[Cpin]
    elseif Mode == LSBPOST                                 ' Mode - LSB, after clock
       Value:=0
          !outa[Cpin]
          Value := (InBit << (bits-1)) + (Value >> 1)      ' Add to  value shifted by position
    elseif Mode == LSBPRE                                  ' Mode - LSB, before clock
       Value:=0
          Value := (Value >> 1) + (InBit << (bits-1))      ' Add to  value shifted by position
          !outa[Cpin]
    elseif Mode == OnClock
       Value:=0
          waitcnt(500 + cnt)                               ' get bit value
          InBit:= ina[Dpin]                               ' time delay
          !outa[Cpin]
          waitcnt(500 + cnt)
Any help in the right direction would be greatly appriciated :P:thanks
Previeuw
    edited 2013-07-20 14:58
    The MAX6675 driver doesn't make sense to me. The code hardly goes through the motions of shifting in the data and then ends up returning data from this line:
    [SIZE=1][FONT=courier new]Long[@TempertureIn_Addr] :=  67   'Ina[Sd]
    [/FONT][/SIZE]
    Uhh? It is returning a constant value of 67. Given a resolution of 0.25 °C per bit, that corresponds to a temperature of 16.75°C. It as though this object is some sort of incomplete test code, not the final driver.
    I took a look at the OBEX listing. There are two drivers there. One is the suspect in-line object "MAX6675_K_ThermoCouple" as you have it above, and the other is "MAX6675_K_ThermoCouple_Cog", which runs in its own cog, and seems to be polished, and is is the one that should really read and return a value from the sensor.
  • JonnyMacJonnyMac Posts: 9,556
    edited 2013-07-20 15:04
    Edit: Updated object posted below. (#5)
  • Igor_RastIgor_Rast Posts: 357
    edited 2013-07-20 16:35
    @Allen , indeed the code doesnt look to make sense , but thats like the only thing i could find about it ,
    the shifting in routine was never my strong point , :p Once i get it all working ill publish the code to make it all work
    @ JonnyMac , Thanks for the headsup with the code ,
    Ive try implementing it , looks to be going in the good direction here , but dont understand it completly ,
    The values comming out supose to be are not like the 0.25 range I suspect it to be
    the return temp * 25 , i dont understand if its a 0.25 resolution based on 12 bits out of 16 bits , we suppose to shift to the right bits first(D-14-D3).
    Going to need in in a value so I can make the rest of the calculations
    OBJ
          Max6675       :  "Termomax6675.spin"            '"Max6675_K_thermoCouple"
            LCD : "LCD_20x4"
           Initialize
            repeat
                    TempReading := Max6675.tc
                    pst.dec (TempReading)
    Pub  Initialize
       'Start cogs
               pst.start(115_200)
        LCD.Clear
        Max6675.start(CS, SCK, So)
    [HTML]
    Start LCD Driver.
    Measured Temperture in Celsius = 5650
    Measured Temperture in Celsius = 5600
    Measured Temperture in Celsius = 5700
    Measured Temperture in Celsius = 5750
    Measured Temperture in Celsius = 5800
    Measured Temperture in Celsius = 5750 [/HTML]
    And I used JonnyMac code below (see OBJ Max6675 : "Termomax6675.spin" )
    Bye the way , anyone know of a drop in 1 pin pwm to controll the solid state relay power% with a value
    Many thanks again in advanve
    If i change the reading part like below
    temp := read
      if (hassensor == true)
        return temp
      else
        return -1
    Wich give me a result that resembles the temperture in C more corretly , but im not sure im right about that , cause its supose to be a 0.25 resulution , and 225/4 = 56.C wich doesnt make sense for the room tempeture its in
    [HTML]Measured Temperture in Celsius = 224
    Measured Temperture in Celsius = 218
    Measured Temperture in Celsius = 226
    Measured Temperture in Celsius = 222
    MMeasured Temperture in Celsius = 226
    [/HTML]
    edited 2013-07-20 19:34
    I wrote that code for another person and thought it worked. Your first set of values seem to be double what they should be -- as if there is an extra shift left of the data. On looking at the data sheet for the part (hint, hint), I found that the clock should come AFTER reading the data line because the first bit is available when the CS line is dropped. Try the version attached here. I've renamed it (removed the _ez) and added routines that return whole degrees C and conversions to Fahrenheit.
    I find 0.25C units inconvenient -- especially dealing with integer values. Multiplying by 25 is the same as multiplying by 0.25 and then by 100; the result is that we get 0.01 degree units; much easier to deal with and read in a display. You should see something like 2275 which would be 22.75 degrees C.
    edited 2013-07-20 20:47
    Just curious, why did you put both elements on top?
    edited 2013-07-21 06:15
    @JonnyMac , Thanks , that one does seem to work better , Im now building up a ds1820 also on the schematic so I can reference the measurements at room temp to see if all is fine with the reading , Ill update later tonight with the code used , Trying to get them to the display also , think I will be fine , just some time on my hand needed still . later today to be continued
    @WBA
    I moved them both to the top to try to get a better heat spread on the pcb board , probably going to solder only on 1 side anyway , so think the one below is kinda useless to heat up the pcb from below if your not planning on double sided pcbś . I think I read it somewhere that it was better to move them both to the top , but cant recall where I read that , But seems to make some sens to mee , so I did it , When the temp reading and callibrating starts ill see if it does make sense or not . Ill post updates about it later
    Havent seen a drop in easy to use Reflow Controller , based on the propeller , but I know allot must have done it cause it cant be easier with the Prop dropping in the right objects and building a top level controller for it , So im planning to release the code , schematic , and parts used to build it , so anybody can build it based on a propeller
    Max6675+DS1820(just for ref) + 20*4 Char LCD + 10A SSR + plus a few buttons I think .
    edited 2013-07-21 10:14
    Keep in mind that your SSR is controlling AC using a triac circuit, so traditional PWM will not be appropriate. I once considered building a reflow oven controller and thought that I would use an opto input circuit to monitor the zero-cross point on the AC line. I would have used a Spin cog to control the SSR based on a value (0 to 100) from the program -- something like this (untested code)
    pri control_ssr(zcpin, ssrpin, p_level) | level         ' launch with cognew
    '' Control SSR based on value (0 to 100) at address in p_level
    '' -- zcpin is zero-cross input from AC
    '' -- ssprin is control output to SSR
      dira[zcpin] := 0                                      ' force to input
      outa[ssrpin] := 1                                     ' start off
      dira[ssrpin] := 0
      repeat
        level := 0 #> long[p_level] <# 100                  ' keep in legal bounds
        if (level == 0)
          outa[ssrpin] := 0                                 ' off
        else
          outa[ssrpin] := 1                                 ' on
          repeat level
            waitpne(1 << zcpin, 1 << zcpin, 0)              ' wait for zero-cross
            waitpeq(1 << zcpin, 1 << zcpin, 0)
          repeat (100 - level)
    I've attached a schematic for zero-cross detection; this is tested -- I use it in an AC lighting controller. The 15K resistors at 2W each.
    677 x 458 - 85K
    edited 2013-07-21 10:59
    As you're in the early stages and we're all throwing around code, I thought I'd offer the attached. I have done a lot of work with character LCDs and deployed them in several commercial projects. That attached object not only controls the LCD, but allows you to use the data buss pins as button inputs (this concept was originally used by Scott Edwards with the BASIC Stamp 1). The object supports the LCD and up to six buttons. I tend to use this to create an interface with UP, DN, LEFT, RIGHT, ENTER, and ESCAPE buttons. From there it's easy to create code whatever you want.
    Here's an example of a commerical product I programmed and used this object in:
    -- http://www.cameraturret.com/genesis.htm
    True story: this controller was being used on a film shoot in some remote desert region and during a shot in a cave, a rock fell onto the device and broke the LCD. This could have been disastrous, but wasn't, because we had made such a simple interface with the UP, DN, LF, RT, ENT, and ESC buttons -- the operator was able to remember the button sequences and they got the shots they needed!
    One of the useful methods in this object is called rjdec() for right-justified decimal values. This routine will get a lot of use displaying temperature and other values on your reflow controller.
    edited 2013-07-21 14:38
    @ JonnyMac , Your the best help one can ask for , thanks allot
    About the LCD driver , Ill look into it , i know its indeed a thing always to get the value in the right format to get it display endso , I struggled with it allot also but I managed to get it working , going to look tru yours to see what more I can learn about it.
    I did manage to get both the Max6675 and the DS1820 To display the reading on the LCD and in the Serial terminal , ( can comment out one of them if not used )
    And overall I see I have a difference of about 7degrees between them , the max6675 reading the highest . but dont think thats going to be that big of a problem (add an offset i think ) also I am going to dived the readings by 100 still to get only hole degrees , cause that much precishon I probably cant controll anyway. so not needed and easyer i think to manage
    Code used
    CON
       DS1820_D_PIN = 17
        SCK      =  0  ' Max6675 Pin
        CS       =  1  ' Max6675 Pin
        So       =  18 ' Max6675 Pin
        RS = 11        ' LCD Control Pins
        RW = 10        ' LCD Control Pins
        E  = 9         ' LCD Control Pins
        DBLow  = 12    ' LCD Data Pins
        DBHigh = 15    ' LCD Data Pins
      ' ASCII codes.
        CR  = 13
        LF  = 10
        PSTClearScreen = 16
        ' One Wire Values .
         CVRT_TEMP  = $44
         SKIP_ROM   = $CC
         RD_SPAD    = $BE
    Var
           Long TempReading1, TempReading2
    OBJ
          ow            : "jm_1-wire"
          Max6675       :  "jm_max6675.spin"            '"Max6675_K_thermoCouple"
          LCD           : "LCD_20x4"
          num           : "simple_numbers"
          f             : "Float32"
          fp            : "FloatString"
           Initialize
           LCD.RawSetPos( $40 ) ' "first" line
           LCD.RawWriteStr( string("Max6675:") )
           LCD.RawSetPos( $14 )                              {set lcd position}
           LCD.PrintStr( String("DS1820 :"))
            repeat
                  Get_Max6675_Reading
                  Get_DS1820_Reading
                  waitcnt(clkfreq  + cnt)    'dont scan too fast or the conversion will not run
    Pub  Initialize | status
        'waitcnt(clkfreq*3 + cnt)                          'Give time to open terminal if not auto
        pst.start(115_200)                                 'Start Debug Serial Terminal
        pst.str(string(13,"Serial Terminal : Ready.",13))  'Lets us know the driver is working
        pst.str(string(13,"Start LCD Driver.",13))         'Start 20x4 Char LCD Driver
        LCD.Clear
        LCD.RawWriteStr( string("LCD Started : Succes") )    'Lets us know the driver is working
        waitcnt(clkfreq *2+ cnt)
        LCD.Clear                                               'Clear Back the screen
        Max6675.start(CS, SCK, So)                              'Ini Max6675
        ow.init(DS1820_D_PIN)                                   'Ini DS1820 Temp Sensor  ( Used as reference )
    PUB Get_Max6675_Reading
          TempReading1 := Max6675.tc01                              'Get reading from MAX6675
          pst.Str(String("Max6675 Temperture in Celsius = "))      'Display in terminal
          pst.dec (TempReading1)                                    'Display in terminal
          pst.Str(String(" ",13))                                   'Display in terminal
          LCD.RawSetPos( $48 )                                      'set lcd position
          LCD.PrintStr(num.dec(TempReading1))                       'Display on LCD
    PUB Get_DS1820_Reading
          TempReading2 := readtc                                    'Get reading from DS1820 sensor
          pst.Str(String("DS1820 Temperture in Celsius = "))      'Display in terminal
          pst.dec (TempReading2)                                    'Display in terminal
          LCD.RawSetPos( $1C )                                      'set lcd position
          LCD.PrintStr(num.dec(TempReading2))                       'Display on LCD
    pub readtc | tc
    '' Reads temperature from DS1820
    '' -- returns degrees C in 0.1 degree units
      ow.reset
      ow.write(SKIP_ROM)
      ow.write(CVRT_TEMP)
      repeat                                                        ' let conversion finish
        tc := ow.rdbit
      until (tc == 1)
      ow.reset
      ow.write(SKIP_ROM)
      ow.write(RD_SPAD)
      tc := ow.read                                                 ' lsb of temp
      tc |= ow.read << 8                                            ' msb of temp
      ow.reset
      tc := ~~tc * 5                                                ' extend sign, 0.1° units
      return tc
    Attached the complete Spin.zip folder so it can be a drop in , Just change the pins accordingly
    MAX6675+DS1820_LCD_20*4.zip
    So that part worked out pretty fine , reading the temp , think we can call the title of the post solved for that
    Reflow still in the making
    About the SSR . about now is the time that I start diging into how to run the oven at say 50%. I didnt dig into that yet ,
    I did have a pice of code somewhere to pwm a led , so i was thinking of using modifing it somehow to get the relay at different power % controlled by a value , so I can controll it easly . .
    Your explination of a triac working got me thinking again , ( I kinda avoided the triac always to understand it completly ) :p hihi
    anyway , I do have experiance with a S202S02F Solid state relay
    wich is a zero cross relay , and uses a smal ciruit (460ohm resistor + transistor and a diode ) to connect it to the propeller , But like the zerro crossing I had in mind I cant controll it that way , only controled it on/off before , wel that was wat i was thinking at least , propbablt wrong ,
    Thats why i bought a Z240D10-17 - SSR, 10A that is direct switching , so I can toggle it directly , to controll it with say pwm , well that was my thinking , got to find that out still, the propeller does turn on /off , if i toggle the pin slowly, dont know about pwm yet. But your mentioning of AC and DC got me thinking again , Guess i will find out soon. Its just a wire that gets heated by pasing the power , I it was a different kind of divice i would be a bigger problem i think .
    ill be working on it tonight and comming days to try to get this working , got some board im realy hopin that I can reflow in the future :p
    The buttons design looks sweet , that means saving up pins to do other things , I bet that will com in handy many times in the future , Wil be testing that out i think . But I was thinking of using less buttons as possible , ( if is hady to work with only 2 buttons ) , probably going to use 1 reflow setting ( dont know how to call it , the time/temp that it needs to perform ) so I will program those hard in the program , and use the buttons to start /stop/ pause the program ,
    Well lets just say , ill work with whatever works best :p
    edited 2013-07-21 16:40
    I rule! :)
    Did you see that the updated version of my MAX6675 driver has a method called tc() that returns whole degrees? It rounds up based on the lower two bits.
    With 50Hz line frequency you're going to have a 10ms (duration of AC half-cycle) granularity with your timing. What's working for you is the thermal inertia of the heating element. You might do something as simple as this -- crude, but with feedback should give you the control you want. As with the other code, this runs in its own cog.
    pri ssr_control(ssrpin, p_level) | level                        ' launch with cognew
      outa[ssrpin] := 0                                             ' set to output
      dira[ssrpin] := 1
      repeat
        level := 0 #> long[p_level] <# 100                          ' get level, keep legal
        if (level > 0)
          outa[ssrpin] := 1                                         ' activate SSR
          waitcnt(cnt + (level * (clkfreq / 100)))                  ' hold for on timing
        if (level < 100)
          outa[ssrpin] := 0                                         ' de-activate SSR
          waitcnt(cnt + (100 - level) * (clkfreq / 100))            ' hold for off timing
    In my experience "few buttons as possible" always means trickier code, and trickier product. While you don't have to implement the full 6-button interface I tend to use (there is even a patent in my name for a Toro irrigation controller that uses that interface), it does make things easier for the user. My object supports up to six buttons; you don't have to use them all (that is why there is a mask parameter).
    That said, it's very easy to create a simple, little-or-no-training-required interface with six buttons. In my projects I use the LF and RT buttons to move between fields. I use UP and DN to change values in a field, ENTER to accept the new value, ESC to bail out without changing what was originally in the fields. Some years ago I coded a commercial HVAC controller using this code and it was a hit. Think about it; the cost of a few more buttons will not break the bank, and could save you hours of coding trying to do everything with just two buttons.
    Ok , It took some time but im back with results :P
    @Jonnymac , thanks again
    I am pretty sure im going to implement the buttons interface , thats just to cool to not use , saving pins always good ,
    just dont know it it will be with the reflow now, cause
    I have a set of 4 buttons hardwired on the pcb already that I will be using , ( just so i dont have to go discover anything ) button = pin works fine , wont be needing the spare pins for now :P usualy use a monolicit lcd driven by 4 hc595 , so there I only use 3 pins but for 4 digits ,
    thats why i have a different connection for the buttons on the pcb im using , I think those character lcd with the blue backlight like I have tend to give a product a chinees look , like aftermarket , thats why i prefeur the other ones while R&D for a new controller , Nothing wrong with it , just my thinking where I sell my controllers (dont take it personal , cause it aint :p )
    After been soldering allot latly I thouth now is the time to make that simple reflow controller to get the job speeded up , so ill be working to get it working , with just start stop tru terminal for now , just to get the reflowing job done :P
    after that ill try to make it as user frendly as possible and building an interface with the buttons and a menu to set the variables needed , gotta find some time for that soon ,
    and was hoping to get it working at least so I can use it to reflow a few pcb soon , (they are in production now )
    Still need to get myself some stencils for the pcb to get the best result i think
    But at the moment im finding out exactly around what temp the paste starts to evaporate , and how long I should keep it soaking there , and where the paste reflows and how long reflow gives the best result , ( the past datasheet only says 180c solder )
    Was kinda bussy but manage to get it working , off course it still needs allot of tweaking but I managed to get some test runs with some old pcb that I have
    done some runs with some tru hole components just to see what it does also , maybe that wil work :P hihhi
    The pcb im plannin on are all smd so that has to be no problem , hopin to do 2 x 70*90mm boards at a time
    Some pics
    Code used
    CON
        DS1820_D_PIN = 17
      ' ASCII codes.
        CR  = 13
        LF  = 10
        PSTClearScreen = 16
        ' One Wire Values .
         CVRT_TEMP  = $44
         SKIP_ROM   = $CC
         RD_SPAD    = $BE
         S_Temp = 1600    'Soak temperture to reach
         S_Time = 120     'Time in sec to soak at given temperture
         P_Temp = 1900    'Soak temperture to reach
         P_Time = 60      'Time in sec to soak at given temperture
    Var
           Long TempReading1, TempReading2,tell,target,soaktime
           long numleds_, firstled_, persistence_, leds[7],Power
           long stack1[64]
           byte status_reflow
    OBJ
          LCD           : "LCD_20x4"
          f             : "Float32"
          fp            : "FloatString"
          led           : "led_pwm"
           Initialize
             repeat  10    ' Loop in Idle  for 10 sec
              Home
           Ramp_to_Soak(S_Temp)       'Ramp to soaking temp given to variable
           Soak(S_Temp,S_Time)         'Soak for some time at give temp
           Ramp_to_Peak(P_Temp)        'Ramp to reflow temp given to variable
           Reflow(P_Temp,P_Temp)       'Reflow for some time at give temp
           Cooling                     'Shut off power to cool down back , all finished
      repeat
        Home                 'Just Loop in Idle
    Pub  Home
          status_reflow := 0
          leds[0] := 0
          LCD.Clear
          Print_Status_Reflow                               'Show status of reflow
          Print_Max6675_Reading                             'Show current temp reading
          Print_Target_Temp
          Print_Power_Reflow
    Pub  Ramp_to_Soak(target_Temp)
     Tell:=0
     status_reflow := 1
     target := target_Temp
     power:= 50
      repeat
        if  TempReading1 < target_Temp
            Tell++
            leds[0] := 32
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
        if  TempReading1 > target_Temp
            return
    Pub  Soak(target_Temp,soak_time)
     soaktime := soak_time
     Tell:=0
     status_reflow := 2
      repeat   soak_time
            power:= 5
            leds[0] := 1
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
            power:= 0
            leds[0] := 0
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
        Tell++
      return
    Pub  Ramp_to_Peak(target_Temp)
     Tell:=0
     status_reflow := 3
     power:= 100
      repeat
            Tell++
            leds[0] := 64
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
            return
    Pub  Reflow(target_Temp,soak_time)
     Tell:=0
     status_reflow := 4
      repeat   soak_time
            power:= 5
            leds[0] := 1
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
            power:= 0
            leds[0] := 0
            LCD.Clear
            Print_Target_Temp
            Print_Zone_Time
            Print_Power_Reflow
        Tell++
      return
    Pub  Cooling
          status_reflow := 5
          power:= 0
          leds[0] := 0
          LCD.Clear
          Print_Zone_Time
          Print_Power_Reflow
      repeat
        if  TempReading1 > 3500
            Tell++
            leds[0] := 0
            LCD.Clear
            Print_Zone_Time
            Print_Power_Reflow
        if  TempReading1 < 3500
            status_reflow := 6
            return
        LCD.Init( E, RS, RW, DBHigh, DBLow )                'Start The LCD driver in cog0
         persistence_ := 0                             ' Converted a led pwm object to drive the relay ,
         numleds_ := 1                                 ' By far not the best solution but works :P
         firstled_ := 22                               ' Make sure to change the Fistled_ var to the SSR pin
         led.start(@numleds_)                          ' firstled_ := SSR pin
         cognew(Start_Max6675_Reading,@stack1)                'Start The Max6675 in a new cog
         Tell:=0
    PUB Start_Max6675_Reading
       repeat
    PUB Print_Status_Reflow
        if status_reflow == 0
           LCD.RawWriteStr( string("Status:") )
           LCD.RawSetPos( $07 )
           LCD.RawWriteStr( string("Idle") )
        if status_reflow == 1
           LCD.RawWriteStr( string("Ramp to Soak") )
        if status_reflow == 2
           LCD.RawWriteStr( string("Soaking ") )
           LCD.PrintStr(num.dec(soaktime))
           LCD.RawWriteStr( string("Sec") )
        if status_reflow == 3
           LCD.RawWriteStr( string("Ramp 2 Peak") )
         if status_reflow == 4
           LCD.RawWriteStr( string("Reflow") )
         if status_reflow == 5
           LCD.RawWriteStr( string("Cooling") )
         if status_reflow == 6
           LCD.RawWriteStr( string("Cooled") )
      return
    PUB Print_Max6675_Reading
          LCD.RawSetPos( $40 )                                      ' set lcd position
          LCD.RawWriteStr( string("Actual:") )
          LCD.PrintStr(num.dec(TempReading1))                       'Display Temp on LCD
          LCD.RawSetPos( $4C )                                      ' set lcd position
          LCD.RawWriteStr( string("C") )
    PUB Print_Target_Temp
          LCD.RawSetPos( $14 )                                      ' set lcd position
          LCD.RawWriteStr( string("Target:") )
          LCD.PrintStr(num.dec(target))                       'Display Temp on LCD
          LCD.RawSetPos( $20 )                                      ' set lcd position
    PUB Print_Zone_Time
          LCD.RawSetPos( $54 )                                      ' set lcd position
          LCD.RawWriteStr( string("Time:") )
          LCD.RawSetPos( $5A )                                      'set lcd position
          LCD.PrintStr(num.dec(Tell))                       'Display Temp on LCD
          LCD.RawSetPos( $60 )                                      ' set lcd position
    PUB Print_Power_Reflow
          LCD.RawWriteStr( string("Pow:") )
          LCD.RawSetPos( $64 )                                      'set lcd position
          LCD.PrintStr(num.dec(Power))                       'Display Temp on LCD
          LCD.RawWriteStr( string("%") )
    PUB Get_Power
          LCD.RawSetPos( $00 )                                      'set lcd position
          LCD.PrintStr(num.dec(leds))                               'Display on LCD
    Zip of complete project files
    Reflow COntroller.zip
    p.s. the temptc doesnt return a corrct value , but im using the hole numer reading anyway , but that could need some looking at :P . same for the SSR part . I used a led_pwm object modified , by no way the best solution , but it work , Ill do some more homework to make it better in future
    1024 x 768 - 113K
    1024 x 1365 - 121K
    1024 x 1365 - 170K
    1024 x 1365 - 74K
