Prop PING Code help needed.
I was able to successfully link to this Object from within my IR/Servo program. However, one is using Parallax Serial Terminal and the other uses FullDuplexSerial. How can I modify the attached code to not use the FDS and just run with the results, no Debug needed? I have tried to remark out the Debug commands but then the LED's stop working correctly.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PING_Pin = 15 ' I/O Pin For PING))) LED1 = 8 ' I/O PIN for LED 1 LED2 = 9 ' I/O PIN for LED 2 ON = 1 OFF = 0 Distlimit = 6 ' In inches VAR long range OBJ Debug : "FullDuplexSerial" ping : "ping" PUB Start dira[LED1..LED2]~~ outa[LED1..LED2]~ Debug.start(31,30,0,9600) waitcnt(clkfreq + cnt) repeat ' Repeat Forever debug.str(string(1,"PING))) Demo ", 13, 13, "Inches = ", 13, "Centimeters = ", 13)) debug.str(string(2,9,2)) range := ping.Inches(PING_Pin) ' Get Range In Inches debug.dec(range) debug.tx(11) debug.str(string(2,14,3)) range := ping.Millimeters(PING_Pin) ' Get Range In Millimeters debug.dec(range / 10) ' Print Whole Part debug.tx(".") ' Print Decimal Point debug.dec(range // 10) ' Print Fractional Part debug.tx(11) range := ping.Inches(PING_Pin) ' Get Range In Inches if range < Distlimit ' Comparing range to a set value of 6 inches outa[LED1] := ON ' P1 is on outa[LED2] := OFF ' P2 is off elseif range > Distlimit ' If range is further than 6 inches outa[LED1] := OFF ' P1 is off outa[LED2] := ON ' P2 is on
Comment the Debug. statements out and remember to take out the extra calls to ping.millimeters and ping.inches
