Prop PING Code help needed.
NWCCTV
I was able to successfully link to this Object from within my IR/Servo program. However, one is using Parallax Serial Terminal and the other uses FullDuplexSerial. How can I modify the attached code to not use the FDS and just run with the results, no Debug needed? I have tried to remark out the Debug commands but then the LED's stop working correctly.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PING_Pin = 15 ' I/O Pin For PING)))
LED1 = 8 ' I/O PIN for LED 1
LED2 = 9 ' I/O PIN for LED 2
ON = 1
OFF = 0
Distlimit = 6 ' In inches
VAR
long range
OBJ
Debug : "FullDuplexSerial"
ping : "ping"
PUB Start
dira[LED1..LED2]~~
outa[LED1..LED2]~
Debug.start(31,30,0,9600)
waitcnt(clkfreq + cnt)
repeat ' Repeat Forever
debug.str(string(1,"PING))) Demo ", 13, 13, "Inches = ", 13, "Centimeters = ", 13))
debug.str(string(2,9,2))
range := ping.Inches(PING_Pin) ' Get Range In Inches
debug.dec(range)
debug.tx(11)
debug.str(string(2,14,3))
range := ping.Millimeters(PING_Pin) ' Get Range In Millimeters
debug.dec(range / 10) ' Print Whole Part
debug.tx(".") ' Print Decimal Point
debug.dec(range // 10) ' Print Fractional Part
debug.tx(11)
if range < Distlimit ' Comparing range to a set value of 6 inches
outa[LED1] := ON ' P1 is on
outa[LED2] := OFF ' P2 is off
elseif range > Distlimit ' If range is further than 6 inches
outa[LED1] := OFF ' P1 is off
outa[LED2] := ON ' P2 is on
Comment the Debug. statements out and remember to take out the extra calls to ping.millimeters and ping.inches
