Elev-8: props come off
Hello the maiden didnt go so well. A propeller came off on take-off, fortunately close to the ground, but still it flipped the quad over and broke several of the props and the prop assembly is missing for the prop that came off. Questions:
Nick.
- How do you keep the props from coming off? I following the instructions and finger tightened and then used a wrench to tighten slightly more.
- I can not see replacement propeller Cone-Lock/Collet/Propeller-Nut in the crash pack
Nick.
To keep the Props from loosening I use Loctite blue and a nice tight fit. I've never had the issue that you describe. Maybe also make sure that the shafts are clean by wiping with rubbing alcohol. You could also roughen up the shafts a bit with sandpaper if it's a consistent problem for you.
(It's really hard not to type prop with a capital "P". I did it at least three times while typing this reply.)
One benefit of buying an ELEV-8 is that we should be able to provide the service to keep you in the air, quickly, without delays.
