Following Garage Fan
Hi,
I am looking for suggestions for a possible project. I have a ceiling mounted fan in my garage and I would like this fan's direction to always being pointing at me. When the fan does not detect me, it will begin to oscillate until it finds me again. I am going to use (1) DC motor and an HB-25 motor controller to rotate the fan about the Y axis (fan rotates from left to right or right to left). I am not concerned about any other axis, just the Y-axis. I am curious as to what device(s) anyone would suggest to use to detect me and follow me. Any feedback would be appreciated. Thanks!
I have attached some pictures of the fan rotating about the Y-axis (DC motor not mounted yet)
Chris
Chris
http://www.youtube.com/watch?v=3rHuFFe6HRc
http://www.youtube.com/watch?v=xAvY-_KW3lI
I do not mind wearing any device as along as it it is not terribly heavy. My garage is about 21' deep and 17' wide. It does not get direct sunlight, but I do get a lot of sunlight relected off of the concrete. My roll up garage door is rarely closed when I am working in my garage. Do you think that this light would interfere with infrared? Any other suggestions.
-Pics of my garage shown attached for reference. Thanks!
Would the airflow from the fan disturb the PING)))'s output/input?
The system would sweep the area until it found something close to body temperature.
The left and right sensors would indicate off center. The middle sensor indicates dead on.
I doubt this would be a problem. I tested my Ping with a hot air gun. I blew hot and cool air at the Ping and across the path of the Ping. The readout from the Ping stayed steady through all these tests.
I have run into a problem with using an ultrasound on a small quadcopter but I think the problem arises from noise the quadcopter's motors are making. I'm guessing the motors have a strong ultrasound component in the sound they produce.
Just came from Walmart and they have cheap fans stacked to the roof. A very cool summer this far in LA!
Please don't jinx it. :P
http://en.wikipedia.org/wiki/Scintillation_counter
I am inclined to just buy one more fan and call it a day. If I had more project time, I would like to go forth with this project, but it would probably be winter (not literally but you know what I mean) by the time I finished it. The fan is $115 so I have to weigh that against all the other components I would have to buy to complete the project. I already have the BS2 controller, the DC motor and HB-25. I think I also have a few ping sensors, but I am not against buying IR sensors and/or thermometers. What would you all do? Thanks again.
By the way, I live in the Houston, TX area and it is really hot, and really humid as I am sure everyone is aware.
These have been used in robots that follow people and/or animals.
Yes, the funny thing was is that I found a moment like that to find someone to "talk shop" .. . :-)
The link on the YouTube video for the object code does not work.
Here it is: http://obex.parallax.com/objects/591/
Don, That link also doesn't work.
Here's the Wii camera object.
BTW, Chris the Carpenter sells some Wii cameras which are easy to use with a Propeller. (Check back in a minute for a link.) Well, darn. Chris doesn't sell them anymore. He does sell one with an added oscillator through Trossen Robotics.
Duane- That was my point. I didn't say that it did. I copied the url from the YouTube video page. It would be nice if you knew what the name of the object was so maybe it could be searched for.
http://www.homedepot.com/p/NightWatcher-Security-220-Degree-Outdoor-Black-Motorized-Motion-Tracking-Halogen-Security-Light-with-Wireless-Indoor-Audio-Alarm-NW300BK/202768304#.UeeA6EbOTuc
http://www.samsclub.com/sams/ge-motion-tracking-security-spotlight/prod4860293.ip
Or, mount a long rod on the fan. Put a loop around the rod, and attach that to your shirt. The fan will follow your movements. <g>
- Mark
Once again, my gamma radiation bombardment concept goes back in the drawer, dangit!
http://www.ebay.com/itm/Ultrasonic-Distance-Detector-Sensor-Module-Transducer-/320862799167?pt=Home_Automation_Modules&hash=item4ab4e9c53f#ht_3086wt_904
Now I have to find it on Ebay China for $50...
I haven't seen any PIR sensors that output which zone changed, which is apparently what this one is doing. Would be very handy. The quest for said sensor begins!
In the photos below, the PIR sensors are mounted in the lower left and lower right of the housing, and the PVC shields are the white tubes sticking out of the bottom.
It's a garage, so, I don't think IR would be the best way to go. Unless, you don't plan on starting any engines or turning on the heat. I'm sure you might turn around at some point, bend over, or stand behind something that would block any line of sight(laser beam, ultrasonic).
Heat will not interfere with the IR seen by a Wii camera. The only things hot enough to glow IR are things that are almost hot enough to glow red hot.
Near IR as used with the Wii, TV remote, and low cost security camera night vision (which require IR LEDs) is best thought of as a color like red of green. It's just happens to be a color we can't see. Sure something red could be red because it glowing red hot (like a kitchen stove) but in general, things we see as red, reflect red light well. Near IR is a color we can't see. As with red, things can glow in near IR but if it's glowing IR it's going to be very hot (almost red hot).
If you have a camera which is sensitive to IR you can test this out by observing an electric stove top with it. Turn the stove up till it's red hot and then back it down a bit so it's just a little cooler than require to glow red. It should then be glowing IR hot.
Thermal imagers and PIR sensors use far IR. Our body heat is enough for us to glow far IR hot.
I think this problem arises from broad range of wavelength which fall under the definition of "infrared".
I still think a Wii camera mounted with the fan and either IR LEDs or IR reflectors on the target would work well. If reflectors are used then you'd need an IR light source mounted next to the camera.
The sensor (far IR) mentioned in post #16 could also work but I think it would require a lot more work (and it would be more expensive).
ETA- or a couple of them.
Why? How?
All the CMUCam tracking I'm aware of uses color blob detection. I'd think this would be a problem in a garage.
Maybe Chris doesn't have anything green in his garage so whenever he want to work he puts on a green t-shirt?
Can the CMUcam track with other means than by color?
