Any interest in one COG chip
I was thinking that in many cases i just need a small chip to do the job.
That is 18 pins or so.
Would it be nice if you could get a 18-pin dip chip that just had one COG, no video and build in flash that would boot to the COG on
reset?
I think it would any one else agree?
rich
reset?
rich
Lots of interest, obviously - but it's called an AVR.
Ross.
If you only have a single processor...ya just gotta have interrupts!
(or simulate them...what a pain that is)
Now a 2 or 3 cog prop for 2.00 or less...superb!
I'd use them instead of something like a tiny88.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
I'm sorry to mention it.
BUT one that mention 1 COG's propeller don't understand principles of NOT have interrupts ON chip.
And parallel processing principles.
SORRY for THAT to all.
Regards
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
20MIP of performance but only if you have all your code in the 496 instruction COG space.
So all that RAM is only usable for data.
What data might that be? With no peripherals it's hard to get data in or out.
If using Spin you just have a really slow micro, with no peripherals.
Things might be salvageable using LMM code, at least you get to use the RAM.
But then you still have just a micro-controller that is slow and limited compared to the above mentioned AVRs and PICs.
Prop1.5 - current prop with 64 I/O
Prop2.0 - Chip's next baby
Prop0.5 - think current prop, 4 cogs, 16KB hub, 28 pin skinny dip (Vcc,Vss,/RST,/BOE,OSC1,OSC2, P0-P21) for $1 in high quantity (4 cogs + 16K hub so smaller die)
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
Edit: I was posting at the same time as Bill.· So that's two votes for a 28-pin 4-cog version.
Post Edited (Dave Hein) : 6/24/2010 1:21:45 PM GMT
Well, you don't always need interrupts. The engineer at my first Elec.Tech. job seemed to be interrupt-o-phobic, yet we managed to build many vending machines without using interrupts. We used the 8085 running at 3.579MHz, and a polling scheme. Our opus magnus was a token-vending machine for the NYC Transit Authority, which accepted coins and bills, and spewed out tokens and change. The only user interface was a 4-digit LED display, and some lamps lighting status messages. (incidentally, we found that the customers ignored the "Out of Service" message, and got quite irritated when they could not use a non-functioning machine!)
Oh, and if I remember my history, the first General Instrument PICs did not have interrupts, either.
--Rich
A one cog version doesn't make too much sense as the Propellers main strength is its ability to parallel process various tasks rather than use interrupts. As many have mentioned in this thread if a single cog is what is desired it might be best to use any one of the many PICs already on the market.
But I will vote for the Prop 1.5. One day after I win the lottery, I will fund the building of a Prop 1.5 in a PLCC84.
Why did I think a new, more challenging, job was a good idea ??
How I wish I could have become the owner of Props or AVRs back 30 years ago, Hey-Ho.
John Abshier
2/3 of the way to UPEW
Prop 1.5 - current prop with 64 I/O
Prop 2.0 - Chip's next baby
Note I do not see a lower spec version. The reason is that it will be too hard for Parallax to compete in this already saturated market. They could not justify the die cost. The current cost is just a factor of volume. If we could up the volume of the current prop significantly then the price would come down.
And just forget a 1 cog version... No peripherals and no interrupts.
Whether they could fit the existing prop into a smaller 28pin package I am unsure, but it would not reduce the price without serious volume. I think it may be better to fit the QFN onto a carrier pcb, but of course this only increases the cost. Maybe I could ask, why do you want a 28 skinny dip? For price or for size???
Just remember, to compete in a well established volume market, you require a differentiated product. That is what the Prop is... a different product!!!
Toby said "How I wish I could have become the owner of Props or AVRs back 30 years ago, Hey-Ho." - Me too!
Prop 1.5 - 256K Ram
We spend all of our time trying to fit our programs in the prop's tiny ram.
Russ
Propeller 2.0 then the Propeller 1.5
Propeller + Picaxe = Romeo & Juliet
Built-in flash, is quite a large jump in business model, and a single COG is under 500 opcodes.
There are 10/16/20 pin uC with 8-16k FLASH already out there, so that is a LOT more code space, and they have interrupts, and start at ~ 25c - with 12b ADCs.
Once Prop 2 hits critical commercial mass, then small variants could perhaps find the resource, but the Prop 1 was hand-taped, whilst the Prop 2 is core-synthesized - so a big decision becomes to shrink Prop 2, but include the time-slice thread design, or trim and paste Prop 1.
Another approach is to do what the other uC vendors do, and offer one die as more than one part.
That catches any yield fall out, and cuts testing times, so a labeled-smaller part can be cheaper.
One limit here, is the Prop 1 die, is already maxed-out in the square packages it is offered in, so smaller skinny-dip packages, need a much smaller die.
Sure, if the pins are on 5mm centres
I've seen 8K Micros with 12 bit ADCs in MSOP10, but the Prop 1 die is way too large to come anywhere near a 3mm package.
I want a single COG chip.
Mind you I want that cog to be 64 bits wide and support some megabytes of COG registers.
The HUB memory would actually be external SD RAM.
Given the P2 COGs now support automatic thread scheduling we can still run huge LMM code from HUB, and multiple internal COG code threads at the same time.
No interrupts required.
It is a bit interesting about how less Cogs would work with reading Hub Memory
4 Cogs... twice as fast as 8
2 Cogs... four fold faster than 8
I really can't see the point in ONE Cog.. someone else can do a nice little 32bit processor.. and already has. No reason for SPIN with ONE Cog.. though PASM might really remain useful.
More RAM in P1 isn't going to happen. It would bork compatibility with all sorts of things and require a whole lot of new layout with tools Chip and Beau have moved past while working on P2. With more pins you don't need mor Hub RAM because you can use the pins to get to external RAM and still have pins for I/O.
I also don't think the business case is there for Parallax to do a 4-cog chip. It wouldn't be that much cheaper, and would be much more crippled. That's the kind of thing you make if you're supplying large-scale manufacturers who use exponential notation in their order quantities, but there's no sense for Parallax to dump the cash into layout and tooling for a chip they'd probably still have to sell for $3+ after paying back the tooling costs to compete against <$1 AVR's.
Not as a full custom design, but many vendors take one set of wafers and create multiple labels.
Just checking Microchip, it looks like they vary the price in a ratio ~1:1.75 by doing this.
Same silicon, less testing time, and usually some sub-set like less code or fewer pins.
However, the relatively large die of the Prop 1 somewhat limits the package choices.
Another same-wafer choice, is to bond Loader Flash into the same package.
More RAM in a P1? Could the 32K ROM space for logs and trig function and characters be done away with and just leave 512 Longs for the Boot Cog image?
