Any interest in one COG chip — Parallax Forums
richaj45richaj45 Posts: 179
edited 2013-07-16 19:22 in Propeller 1
I was thinking that in many cases i just need a small chip to do the job.
That is 18 pins or so.
Would it be nice if you could get a 18-pin dip chip that just had one COG, no video and build in flash that would boot to the COG on
reset?
I think it would any one else agree?
rich
  • RossHRossH Posts: 5,775
    edited 2010-06-24 06:35
    Hi Rich,
    Lots of interest, obviously - but it's called an AVR.
    Ross.
    Catalina - a FREE C compiler for the Propeller - see Catalina
    edited 2010-06-24 06:43
    An AVR with no interrupts.
    If you only have a single processor...ya just gotta have interrupts!
    (or simulate them...what a pain that is)
    Now a 2 or 3 cog prop for 2.00 or less...superb!
    I'd use them instead of something like a tiny88.
    edited 2010-06-24 07:26
    I would much rather a 64 I/O version with 16 cogs at $16. Anyway, it's not going to happen.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
  • AleAle Posts: 2,363
    edited 2010-06-24 12:22
    A 1 COG "prop" can you make not that easily(tm) using a FPGA [noparse]:)[/noparse] Of course an AVR maybe the way to go... or an XMega... there are many options. I agree with cluso, the 64 IOs Propeller _is_ a much useful idea [noparse]:)[/noparse]
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
  • SapiehaSapieha Posts: 2,964
    edited 2010-06-24 12:41
    Hi all.
    I'm sorry to mention it.
    BUT one that mention 1 COG's propeller don't understand principles of NOT have interrupts ON chip.
    And parallel processing principles.
    SORRY for THAT to all.
    Regards
    Nothing is impossible, there are only different degrees of difficulty.
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
  • heaterheater Posts: 3,370
    edited 2010-06-24 12:50
    A one Cog Prop would be very sad.
    20MIP of performance but only if you have all your code in the 496 instruction COG space.
    So all that RAM is only usable for data.
    What data might that be? With no peripherals it's hard to get data in or out.
    If using Spin you just have a really slow micro, with no peripherals.
    Things might be salvageable using LMM code, at least you get to use the RAM.
    But then you still have just a micro-controller that is slow and limited compared to the above mentioned AVRs and PICs.
    edited 2010-06-24 13:15
    Personally, in order of priority, I'd like to see:
    Prop1.5 - current prop with 64 I/O
    Prop2.0 - Chip's next baby
    Prop0.5 - think current prop, 4 cogs, 16KB hub, 28 pin skinny dip (Vcc,Vss,/RST,/BOE,OSC1,OSC2, P0-P21) for $1 in high quantity (4 cogs + 16K hub so smaller die)
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
    My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
    and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-06-24 13:16
    This was mentioned in the SX forum when the SX EOL was announced.· Personally, I would like to see a smaller version of the Propeller made available.· Many applications (Most applications?) do not require 8 cogs.· A single-cog version may be useful, but it may be best to have at least 2 cogs.· I think a 4 cog version would be really nice!
    Edit: I was posting at the same time as Bill.· So that's two votes for a 28-pin 4-cog version.
    Post Edited (Dave Hein) : 6/24/2010 1:21:45 PM GMT
  • edited 2010-06-24 14:29
    If they wanted to do a one or two cog chip with·one large hub memory then there might be some possibilities there.· You could call it a dual engine prop.
  • RiJoRiRiJoRi Posts: 157
    edited 2010-06-24 15:23
    HollyMinkowski said...
    ... If you only have a single processor...ya just gotta have interrupts! ...
    Well, you don't always need interrupts. The engineer at my first Elec.Tech. job seemed to be interrupt-o-phobic, yet we managed to build many vending machines without using interrupts. We used the 8085 running at 3.579MHz, and a polling scheme. Our opus magnus was a token-vending machine for the NYC Transit Authority, which accepted coins and bills, and spewed out tokens and change. The only user interface was a 4-digit LED display, and some lamps lighting status messages. (incidentally, we found that the customers ignored the "Out of Service" message, and got quite irritated when they could not use a non-functioning machine!)
    Oh, and if I remember my history, the first General Instrument PICs did not have interrupts, either.
    --Rich
  • Sal AmmoniacSal Ammoniac Posts: 213
    edited 2010-06-24 16:16
    Sure. If it costs $0.50 or less then I'm all for it. Otherwise there are plenty of AVR or PIC choices in that price range and ARM Cortex-M0 chips are around a buck.
  • Miner_with_a_PICMiner_with_a_PIC Posts: 123
    edited 2010-06-24 16:47
    Make that three votes for a 4 cog version of the propeller with 16KB of RAM (i.e. split the die in two with some rerouting of the metalization here and there)...however keeping the 32 I/O count might be wise. Most all of my programs do not exceed 4 cogs and 16KB is workable for most projects. I suspect there would be a slight reduction in cost for this pedigree...perhaps a 5 dollar price tag and I wonder whether from a business standpoint if this SKU would be viable for Parallax to support...probably not as there would be the added cost of a new line (new mask sets etc.) which might be difficult to recoup.
    A one cog version doesn't make too much sense as the Propellers main strength is its ability to parallel process various tasks rather than use interrupts. As many have mentioned in this thread if a single cog is what is desired it might be best to use any one of the many PICs already on the market.
  • BEEPBEEP Posts: 58
    edited 2010-06-24 18:44
    Yes, it would be nice to have a cheaper/smaller version of Propeller to replace the AVR in my projects.
    edited 2010-06-24 18:47
    The thing that attracted me to the Prop path was that there was only one varient, with one (official) compiler. I was disapointed that the project that I was looking at was on a AtTiny this or a AtMega that, using XXX compiler. Always it was just the combination I didn't have.
    But I will vote for the Prop 1.5. One day after I win the lottery, I will fund the building of a Prop 1.5 in a PLCC84.
    Why did I think a new, more challenging, job was a good idea ??
    edited 2010-06-24 21:32
    I notice that Linus has gone back to the ATMega88 for his 2010 entrance.
    How I wish I could have become the owner of Props or AVRs back 30 years ago, Hey-Ho. cry.gif
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-06-25 00:31
    John Abshier
    2/3 of the way to UPEW
    edited 2010-06-25 02:16
    Since it has been brought up, my preference is..
    Prop 1.5 - current prop with 64 I/O
    Prop 2.0 - Chip's next baby
    Note I do not see a lower spec version. The reason is that it will be too hard for Parallax to compete in this already saturated market. They could not justify the die cost. The current cost is just a factor of volume. If we could up the volume of the current prop significantly then the price would come down.
    And just forget a 1 cog version... No peripherals and no interrupts.
    Whether they could fit the existing prop into a smaller 28pin package I am unsure, but it would not reduce the price without serious volume. I think it may be better to fit the QFN onto a carrier pcb, but of course this only increases the cost. Maybe I could ask, why do you want a 28 skinny dip? For price or for size???
    Just remember, to compete in a well established volume market, you require a differentiated product. That is what the Prop is... a different product!!!
    Toby said "How I wish I could have become the owner of Props or AVRs back 30 years ago, Hey-Ho." - Me too!
  • BigFootBigFoot Posts: 259
    edited 2010-06-25 02:26
    Personally the order I would like to see is
    Prop 1.5 - 256K Ram
    We spend all of our time trying to fit our programs in the prop's tiny ram.
    Russ
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-06-25 02:38
    I say...
    Propeller 2.0 then the Propeller 1.5
    Propeller + Picaxe = Romeo & Juliet
    edited 2010-06-25 06:25
    BigFoot: The Prop 1.5 has been designed so it is only a matter of producing silicon. Redesigning it to include 256K SRAM would most likely take longer than it would to get Prop 2.0 out. It would also require finer geometries which would lose some of the Prop I appeal, such as low power.
  • Jack ScarletJack Scarlet Posts: 15
    edited 2013-07-15 02:15
    I would like to see an 8 cog prop in 10 and 12 pin packages.
  • jmgjmg Posts: 15,200
    edited 2013-07-15 03:55
    richaj45 wrote: »
    Would it be nice if you could get a 18-pin dip chip that just had one COG, no video and build in flash that would boot to the COG on reset?
    Built-in flash, is quite a large jump in business model, and a single COG is under 500 opcodes.
    There are 10/16/20 pin uC with 8-16k FLASH already out there, so that is a LOT more code space, and they have interrupts, and start at ~ 25c - with 12b ADCs.
    Once Prop 2 hits critical commercial mass, then small variants could perhaps find the resource, but the Prop 1 was hand-taped, whilst the Prop 2 is core-synthesized - so a big decision becomes to shrink Prop 2, but include the time-slice thread design, or trim and paste Prop 1.
    Another approach is to do what the other uC vendors do, and offer one die as more than one part.
    That catches any yield fall out, and cuts testing times, so a labeled-smaller part can be cheaper.
    One limit here, is the Prop 1 die, is already maxed-out in the square packages it is offered in, so smaller skinny-dip packages, need a much smaller die.
    edited 2013-07-15 03:59
    Sure, if the pins are on 5mm centres ;)
    I've seen 8K Micros with 12 bit ADCs in MSOP10, but the Prop 1 die is way too large to come anywhere near a 3mm package.
    edited 2013-07-15 05:21
    Yeah,
    I want a single COG chip.
    Mind you I want that cog to be 64 bits wide and support some megabytes of COG registers.
    The HUB memory would actually be external SD RAM.
    Given the P2 COGs now support automatic thread scheduling we can still run huge LMM code from HUB, and multiple internal COG code threads at the same time.
    No interrupts required.
    edited 2013-07-15 05:25
    Fxc2hh wrote: »
    It is a bit interesting about how less Cogs would work with reading Hub Memory
    4 Cogs... twice as fast as 8
    2 Cogs... four fold faster than 8
    I really can't see the point in ONE Cog.. someone else can do a nice little 32bit processor.. and already has. No reason for SPIN with ONE Cog.. though PASM might really remain useful.
    edited 2013-07-15 15:53
    If the P8X32B (P1 + 64 IO) (edit: or is that # P2?) has actually been designed then yeah, I would really like to see it made into silicon. There are significant advantages to the P1's 360nm process for low power applications and implementation simplicity. I wonder if there's a way Parallax could do something like the next P2 run with less expensive fab but more expensive chips just to make it a thing for seeing what we could do with it?
    More RAM in P1 isn't going to happen. It would bork compatibility with all sorts of things and require a whole lot of new layout with tools Chip and Beau have moved past while working on P2. With more pins you don't need mor Hub RAM because you can use the pins to get to external RAM and still have pins for I/O.
    I also don't think the business case is there for Parallax to do a 4-cog chip. It wouldn't be that much cheaper, and would be much more crippled. That's the kind of thing you make if you're supplying large-scale manufacturers who use exponential notation in their order quantities, but there's no sense for Parallax to dump the cash into layout and tooling for a chip they'd probably still have to sell for $3+ after paying back the tooling costs to compete against <$1 AVR's.
  • average joeaverage joe Posts: 795
    edited 2013-07-15 19:13
    I keep praying for the day the P8X32B is released. Those extra 32 pins would be worth more than their weight in silicon. Don't mess with the number of cogs, or memory size. This is just unnecessary (and asking for trouble) IMO . I have half a dozen projects that a 64 pin prop would benefit from. I'd love to jump on the P2 bandwagon, but a DE2-115 is beyond my price point right now and a DE0-Nano it a bit short on spec. I keep waiting for actual silicon, but very few of my current projects need the actual processing power. Maybe by xmas...
    edited 2013-07-15 21:30
    localroger wrote: »
    Not as a full custom design, but many vendors take one set of wafers and create multiple labels.
    Just checking Microchip, it looks like they vary the price in a ratio ~1:1.75 by doing this.
    Same silicon, less testing time, and usually some sub-set like less code or fewer pins.
    However, the relatively large die of the Prop 1 somewhat limits the package choices.
    Another same-wafer choice, is to bond Loader Flash into the same package.
    edited 2013-07-15 21:44
    I wouldn't mind seeing a lower cost prop1 with fewer (even just 1) cogs. I generally run out of I/O pins or memory before I run out of cogs. I wonder if there are chips where one or more cogs are defective but everything else works. They would be good candidates for a propeller with fewer cogs.
    edited 2013-07-16 07:41
    localroger wrote: »
    More RAM in a P1? Could the 32K ROM space for logs and trig function and characters be done away with and just leave 512 Longs for the Boot Cog image?
