Smart Card Reader/Writer Not Working: URGENT
NWCCTV
I seem to have an issue with my Smart Card Reader/Writer that hopefully someone can shine some light on. I marked this urgent since this is for my Micro Medic project. I emailed Tech Support also but thought maybe someone here has had the same issue in the past and knows what the problem is. When I first received my Reader/Writer a few months ago I tested it out and it worked fine. Now today when I was trying to work with it, it seems to be malfunctioning. I am using a BOE Board with a BS2 Stamp and a 7.5V wall wart power supply. When I run the demo program for this card, http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/685/Default.aspx?txtSearch=smart+card or any card for that matter, the reader comes up with the Debug terminal with the choices of 1 or 2 whether the card is inserted or not. I do not get the "No Card Inserted" error message. With no card in if I choose to view the card data it shows 8 pages of 00. If I choose to write to the card with it inserted and choose the correct page, and block and enter 11, no data is being written to the card. It will even let me use option 2 if no card is inserted. Any and all help is greatly appreciated. Like I said, this is part of my MM project and time is running out.
For a different issue you should definitely start a new thread. If you have an e-mail into Tech Support I would wait one day at least for someone to follow up otherwise if you call in while waiting on an e-mail two people could be trying to folow up on the same issue, which is not efficient use of time.
