Correction suggestions for USB Li-Ion/Li-Poly Charger v 1.2 — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,940
edited 2013-07-12 09:33 in General Discussion
Corrections suggested:
  1. Second sentence, first paragraph, missing a Y on battery: "...Lithium Polymer batter ..."
  2. Third sentence, first paragraph, missing a comma: "Just know that if you're doing both, the battery will charge slower."
  3. First feature bullet point, missing an R on your: "...for wiring in you favorite project board"
  4. Fourth feature bullet point, should state DC IN not just DC and singular for the "status LED": "...for the battery, DC, and status LEDs"
  5. Fifth feature bullet point, should be upper case L: "For use with lithium Ion"
  6. Sixth feature bullet point is duplicate of second feature bullet point
  7. Seventh feature bullet point, remove redundancy usage of "in" to add clarity: "... and solder in the thermistor in it's place." should be "... and solder the thermistor in it's place."
  8. Recommend adding the USB cable as a related item.
thanks!
  • EmilyKurzeEmilyKurze Posts: 127
    thanks!
    Thank you! I have made these corrections.
