Correction suggestions for USB Li-Ion/Li-Poly Charger v 1.2
WBA Consulting
Corrections suggested:
- Second sentence, first paragraph, missing a Y on battery: "...Lithium Polymer batter ..."
- Third sentence, first paragraph, missing a comma: "Just know that if you're doing both, the battery will charge slower."
- First feature bullet point, missing an R on your: "...for wiring in you favorite project board"
- Fourth feature bullet point, should state DC IN not just DC and singular for the "status LED": "...for the battery, DC, and status LEDs"
- Fifth feature bullet point, should be upper case L: "For use with lithium Ion"
- Sixth feature bullet point is duplicate of second feature bullet point
- Seventh feature bullet point, remove redundancy usage of "in" to add clarity: "... and solder in the thermistor in it's place." should be "... and solder the thermistor in it's place."
- Recommend adding the USB cable as a related item.
Thank you! I have made these corrections.
