Two CS-101 problems and their FORTH solutions. Comments on style would be helpful.
My flute/whistle instructor said the way to learn an instrument is to learn 100 songs. The approach worked well, so I learn new computer languages the same way by writing solutions to classic programming problems. When I posted my last FORTH program I learned a fair amount from people's comments. Specifically FORTH style like using . in the name of output functions, but other things as well. So to further mooch off the accumulated FORTH experience of the forum, I'm posting two programs for comments on style and approach.
The first program prints all the factors of a number. I found this one pretty simple to do.
The second calculates the integer square root with rounding. In case Heater is curious, I found the stack manipulations on this one hideously difficult to write. In the end I had to solve the problem by writing the program inside out. This is exactly the opposite way I would write the C function.
In terms of time the first program took me no longer than writing it in C, but the second program took much longer than writing in C.
\ predicate used to determine if a number is a divisor : factor? ( n1 n2 - f ) mod 0= ; \ prints n2 if it is a factor of n1 : .factor ( n1 n2 - ) tuck \ n2 n1 n2 factor? \ n2 f if . else drop then ; \ prints all the numbers less than the number that are factors. : factors ( n - ) dup 2 \ from 2 to n do dup i \ n n i .factor \ n loop drop ;
\ compute the number with the highest non sign bit set. 1 cell 8 * 2 - lshift create max_bit 1 cells allot max_bit ! \ shift "bit" to the highest power of four <= n. : starting_bit ( n - n start_bit ) max_bit @ begin 2dup <= while \ one > n 2 rshift repeat ; \ predicate who's name says it all : n>=r+b? ( n r b - n r b f ) \ copy n to return stack rot dup >r -rot \ compute result + bit 2dup + \ n >= result + bit r> swap >= ; \ round up n2 by one if n1 is greater : round_up ( n1 n2 - n1 n2 ) 2dup > if 1+ then ; \ Fast integer square root algorithm, with rounding the result to \ the next greater integer if the fractional part is 0.5 or greater. \ For example 2->1, 3->2, 4->2, 6->2, 7->3, 9->3 : isqrtr \ ( n - n^1/2 ) \ Throughout the function we'll juggle three numbers on the stack: \ n (input), bit (computed), and result (output, starts at 0). starting_bit 0 begin over while \ bit is not zero n>=r+b? if 2dup + >r \ push result + bit to return stack rot r> - -rot \ n = n - (result + one) over 2 * + \ result += 2 * bit; then 1 rshift swap \ divide result by 2 2 rshift swap \ divide bit by 4. repeat \ bit has outlived its usefulness swap drop \ Do arithmetic rounding to nearest integer round_up \ clean off n to return only result. swap drop ;
I've heard this. How many is this so far? I'd be interested in how many you write before you feel you learned forth.
I would suggest your problem is that you made a word too complicated.
If a word takes more than two or three item off the stack, and leave more than one or two, it might be better to break it down further. Of course you can have more or less, this is just the rule of thumb. But its much easier to debug and test a simple word that does just one thing. You can always reduce a serial of called words to a single word after it works.
Also, if the stack manipulations are getting out of hand, just store some values in memory as variables. The rule of thumb here is if its too hard, do it easier. Using variable is much slower, but easier to keep track. Again, you can always factor out the variable after you get it working.
Really cool work!
There are many case where pick and roll are well suited. If I need pick and roll, I'm usually just being sloppy, so I just avoid them.
In this particular case, it looks really nice.
Thanks for the feedback. I've written eight programs so far. In general I know a programming language when I can write code without looking at a reference, and I've developed a sense of the languages aesthetics. At that point I can review my own code and be able to recognize good code versus bad code. I know about variables because I used one for max_bit, but that was essentially a precomputed constant. I've had reentrancy drummed into my head so much by multi-threaded programming that I'm allergic to global variables. I only use them as the jumping off point to other context, not for state within a function.
Thanks for the tweak to the function. Swaping the sense of the comparison operator eliminated the swap, so I'll have to remember that. The words pick and roll are a bit out of my league at the moment, but I'll keep them in mind for the future. I'm just glad I was finally able to find a use for tuck!
ROLL uses the parameter to select the element it will move to the top of the stack. "1 ROLL" is the same as SWAP, and "2 ROLL" is the same as ROT.
PICK and ROLL can be implemented on any Forth system that makes the stack pointer accessible. They could probably be implemented in PropForth. Tachyon implements the stacks in cog registers, which would make it hard to implement PICK and ROLL.
That's awesome. I love code portability. I'm also really liking the create does> construct. It's key to raising the level of semantic abstraction in FORTH from low level to higher level. All that bit vector grunt work was nicely encapsulated.
I'll run this by the college kids and see what they say.
Nice exercise!
Yes, I've run this under gforth, and that construct was in the original code I found here: http://rosettacode.org/wiki/Roman_numerals/Decode#Forth
What is going on is that (arabic) is not a word, it is the name of an array allocated by create. But you have the option of adding code that executes when the array is referenced via the does> construct. The does> construct requires the ';' to terminate its definition, but create doesn't require the preceding ':'. It's a bit confusing, but that's why this reverse engineering exercise was worth doing.
It seems like the use of does> in this context is unusual since it is only applied to the single word (arabic). For me, the code would look cleaner if it defined the array and the "does>" portion of (arabic) as separate words, but I understand that the original code was written using does>.
The original code was definitely on the obscure side. I feel I improved it, but you're right there is further room for improvement.
* Obviously I understand variables, they are a storage location referenced by an address that contains a value. The symbolic name assigned to that variable is stored in some sort of look up table which translates the name into the address and deposit it on the stack.
* On the surface I understand a constant. It is a symbolic name for an unchanging value. In compiled languages a constant is available only at compile time, often the value is stored in the code, and referenced using the immediate mode of the underlying instruction set. But FORTH is a threaded interpreter, so how does that impact this concept?
* A value seems like the most nebulous concept. It seems to behave identically to a constant. For example "10 constant foo" results in 10 on the stack when you type foo. Likewise "10 value foo" results in the same thing. So this puzzles me.
So I decided to find out why and what each does, and armed with the see word I followed the trail below:
I think I understand the variable definition, but the rest are alien to me. However, the definitions of constant and value seem similar to me.
Good, now I feel I have a right to be confused about the difference between constant and value. I've made a good faith effort, so I'm going to chalk this up as likely the result of some sort of legacy in the language. It might get clearer over time, or remain a perpetual mystery like some of the weirder bits of C++.
In pfth the definitions for CONSTANT, VALUE and TO are as follows: pfth doesn't do any error checking on the use of TO, so it could be applied to a value, constant or even a variable.
