broken PING))) or just using it improperly?
Please keep in mind that my son and I are relative n00bs with these sensors.
We purchased a 3-pin PING))) for use with an Arduino Uno. When we took it out of the package it seemed to work as advertised with the default code in the main Arduino library. Now, however, when turned on there is either no activity, or a burst of blinks for up to 1-2 seconds, reporting data, and then no activity. After that, it blinks & reports intermittently (a few times per minute), but reports zeros the rest of the time. This is the pattern of activity with either the default code of the NewPing library.
It sounds like we have done something disastrous to the unit and should just buy a replacement, but I wanted to check here in case that was a known issue that could be fixed.
thanks
thanks
