Long range motion detection
Hey guys,
I have an interesting problem and am looking for a little brain storming. I am trying to detect a large moving object from a distance of about 300 feet. The object is a semi-truck pulling into a loading dock. I have an exact point where the truck will pass, but I cant position a sensor any closer because of how the dock is layed out. It will also need to detect the truck night and day. I want to tie the input into a Propeller so I may do other things based on the input like sound an alert and log arrivals.
Any ideas?
Any ideas?
Mike, I thought of a laser based sensor but I have not found any with that range and that I can interface with. Do you happen to know of any?
kwinn, I dont know that a IR will get the range I need and there is no way to really put it closer (its like a big parking lot with no place to mount). I think the mic would have to many false positives since there is a highway near by. The thermal is a good idea though. I will explore a little more on that. If memory serves theres a nice thread about a low res thermal somewhere on the forums.
I believe kwinn was talking about the IR heat signature given off by the engine of the truck, not quite the same as the IR from say a tv remote.
If you used a more powerful laser and modified the mounting geometry, I'd think Parallax's Laser Range Finder could be made to work at greater than its standard range.
Is there a solid background color that could be monitored? If so, the CMUcam4 would keep an eye on the area and watch for changes in size of a color blob. This probably wouldn't work well at night though.
Could you mount a reflector beyond were the truck would be to use with some sort of electric eye (bouncing IR or laser light back to a detector)?
I'm still itching to try the thermal sensor Phil experimented with here. Is it the low-res imager you were referring to?
lay it on the ground and let the truck drive over it...
Enjoy!
That's the way all the gas stations did so they know when to come out to pump the gas for you. That was before the selfserve days.
(Just kidding! I remember when the attendant not only filled your tank, but checked your oil and handed out free coffee mugs -- all for what? Thirty cents a gallon?)
I would use a laser pointer, a mirror and a photo-transistor. Place the laser such that its beam will be crossed by the truck. Use the mirror to relfect the laser to a location that holds the photo-transistor. Thats it and it would cost less than 10 bucks.
http://www.conti-online.com/www/industrial_sensors_de_en/themes/ars_300_en.html
All when swimmingly well ... until a rather large crow flew through the field of view and the dish followed that. All the engineers fell about laughing, the director didn't.
DS00 from Lightware is good in broad daylight up to 350 meters, and is accurate to a couple cm.
The newer version is supposed to cost less with shorter range, but I haven't played with those.
http://www.lightware.co.za/index.php/2-cat-lightware
To answer your question Mark_T, no, it is not always the same truck. They receive a variety of trucks.
Beau, I love the simplicity of your solution but unfortunatly I cant put anything in the drive. Though now I do have to wonder what you were like as a kid.
