Long range motion detection — Parallax Forums
DeathbatDeathbat Posts: 4
edited 2013-07-10 00:30 in Propeller 1
Hey guys,
I have an interesting problem and am looking for a little brain storming. I am trying to detect a large moving object from a distance of about 300 feet. The object is a semi-truck pulling into a loading dock. I have an exact point where the truck will pass, but I cant position a sensor any closer because of how the dock is layed out. It will also need to detect the truck night and day. I want to tie the input into a Propeller so I may do other things based on the input like sound an alert and log arrivals.
Any ideas?
    edited 2013-07-07 13:02
    The only thing that makes any kind of sense at that range is some kind of laser-based sensor, like the surveyor's laser mentioned in your other thread. This assumes that there's space beyond where the semi would come so there would be a significant reading difference between the case where the semi is present and where it's absent.
    edited 2013-07-07 13:11
    A pir sensor with an IR lens to narrow the focus to the entry point, a low res thermal imaging chip, or a parabolic microphone to detect the diesel engine.
  • DeathbatDeathbat Posts: 4
    edited 2013-07-07 15:34
    Thanks for the input guys,
    Mike, I thought of a laser based sensor but I have not found any with that range and that I can interface with. Do you happen to know of any?
    kwinn, I dont know that a IR will get the range I need and there is no way to really put it closer (its like a big parking lot with no place to mount). I think the mic would have to many false positives since there is a highway near by. The thermal is a good idea though. I will explore a little more on that. If memory serves theres a nice thread about a low res thermal somewhere on the forums.
    edited 2013-07-07 18:03
    Deathbat,
    I believe kwinn was talking about the IR heat signature given off by the engine of the truck, not quite the same as the IR from say a tv remote.
    edited 2013-07-07 18:19
    HobbyKing sells a laser range finder that's supposed to work out to 700m. I have one I've been meaning to hack but I haven't gotten around to doing so yet.
    If you used a more powerful laser and modified the mounting geometry, I'd think Parallax's Laser Range Finder could be made to work at greater than its standard range.
    Is there a solid background color that could be monitored? If so, the CMUcam4 would keep an eye on the area and watch for changes in size of a color blob. This probably wouldn't work well at night though.
    Could you mount a reflector beyond were the truck would be to use with some sort of electric eye (bouncing IR or laser light back to a detector)?
    I'm still itching to try the thermal sensor Phil experimented with here. Is it the low-res imager you were referring to?
    edited 2013-07-07 18:27
    How about a garden hose and a pressure sensor?
    lay it on the ground and let the truck drive over it...
    Enjoy!
    edited 2013-07-07 18:40
    msrobots wrote: »
    Enjoy!
    That's the way all the gas stations did so they know when to come out to pump the gas for you. That was before the selfserve days.
    edited 2013-07-07 19:25
    Wow! There are some really OLD people on this forum!
    (Just kidding! I remember when the attendant not only filled your tank, but checked your oil and handed out free coffee mugs -- all for what? Thirty cents a gallon?)
  • HarbingerHarbinger Posts: 7
    edited 2013-07-07 19:34
    Greetings,
    I would use a laser pointer, a mirror and a photo-transistor. Place the laser such that its beam will be crossed by the truck. Use the mirror to relfect the laser to a location that holds the photo-transistor. Thats it and it would cost less than 10 bucks.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-07-08 12:52
    What about a CCTV camera?
    (Just kidding! I remember when the attendant not only filled your tank, but checked your oil and handed out free coffee mugs -- all for what? Thirty cents a gallon?) And they would wash the windshield? All the while letting you take free maps to get you where you were going!!!
    edited 2013-07-08 13:10
    A long, long time ago i thought I would be a smart A**** and build a simple tracking device to follow a helicopter that had a cameraman in it and down linked at our usual 7GHz. To save having a rigger point the 2 foot dish at it all afternoon I had a CCTV camera sense what quadrant the heli was in, and track it.
    All when swimmingly well ... until a rather large crow flew through the field of view and the dish followed that. All the engineers fell about laughing, the director didn't.
    edited 2013-07-08 13:26
    Deathbat wrote: »
    DS00 from Lightware is good in broad daylight up to 350 meters, and is accurate to a couple cm.
    The newer version is supposed to cost less with shorter range, but I haven't played with those.
    http://www.lightware.co.za/index.php/2-cat-lightware
  • rabaggettrabaggett Posts: 96
    edited 2013-07-08 16:44
    Ramsey's SG7 Speed radar kit has an output so you can 'hear' the doppler shift. I bet a truck at 300 feet would make a very distinctive 'sound' that could be sampled with a simple ADC. Pretty cheap, too!. Just look for a tone above a certain pitch-speed for at least so long.. Some experimentation would be in order.
  • Mark_TMark_T Posts: 1,981
    edited 2013-07-09 06:48
    Quick question: is it always the same truck? That would make things easier.
    edited 2013-07-09 08:52
    Seismic ? .... A strategically placed speed bump for the truck might produce a measurable reading. I remember as a kid making a crude Seismograph with a magnet suspended on the end of a spring inside of a PVC tube. At the bottom where the magnet was, a pickup coil fed directly to an Op-Amp. On trash day, the "trash truck" three houses down would set it off.
    edited 2013-07-09 15:27
    Thanks for the suggestions everyone. I think my best bet is going to be radar based. I found a system http://www.southwestmicrowave.com/products/microwave-sensors/ that looks capable. I will have to do more research to make sure but I like prof_braino's suggestion of http://www.lightware.co.za/index.php/2-cat-lightware as a possible backup.
    To answer your question Mark_T, no, it is not always the same truck. They receive a variety of trucks.
    Beau, I love the simplicity of your solution but unfortunatly I cant put anything in the drive. Though now I do have to wonder what you were like as a kid.
    edited 2013-07-10 00:14
    If you are looking into radar solutions check out these units: http://www.isee.biz/products/igep-radar-technologyThey have been used for vehicle detection. A thousand dollars or so gets you the radar unit combined with a capable ARM processor board running Linux.
  • FernandFernand Posts: 83
    Is there a one time cost limit? Recurring cost limit?
