newbie question on datasheets for Parallax sensors / components
Is there a spot where the datasheets for the Parallax components are posted? I can't seem to find it. Right now, I'm looking for the specs on the LEDs that came with the kits I have (IR, bicolor, green, red, etc.)
I suggest you go to Mouser or DigiKey's website and look up a typical LED of the color you're interested in. They will have a link to a datasheet and the information there should be close enough (Vf - forward voltage mostly). Bicolor (red / green) LEDs are just two LEDs back to back and a datasheet for any bicolor LED will show you which way they're connected.
http://www.parallax.com/Store/Components/Optoelectronics/tabid/152/CategoryID/30/List/0/SortField/0/Level/a/ProductID/178/Default.aspx
Here it is
