Problem posting code
acting strange under IE but not Chrome?!?!
Something in this code segment freaking out the forum editor under IE8
' IS24C16A_Demo.bs2
' {$STAMP BS2}
' {$PBASIC 2.5}
' This program demonstrates the basics of reading and writing data to the
' IS24C16A smart card.
' -----[ I/O Definitions ]-------------------------------------------------
IO PIN 3 ' Serial Data IO
CD PIN 2 ' Card Detect
CLK PIN 1 ' Serial Data Clock
' -----[ Constants ]-------------------------------------------------------
Ack CON 0 ' Acknowledge - Successful data transfer
NAck CON 1 ' Acknowledge - Unsuccessful data transfer
' -----[ Variables ]-------------------------------------------------------
index VAR Word ' Variable space for FOR..NEXT loop
command VAR Byte ' Read/Write designation
wData VAR Byte ' Write data
rData VAR Byte ' Read data
choice VAR Nib ' User selection
I2CAck VAR Bit ' Acknowledge bit
temp VAR Byte ' Variable space
address VAR Word ' Current address loaction
EpromSize CON 2
start VAR Word
leng VAR Word '# bytes to dump
incr VAR Nib
'myList VAR Byte(10)
idx VAR Word
' -----[ Initialization ]--------------------------------------------------
' Declares PSC and waits for a smart card to be inserted
leng =256
Program_Start:
DEBUG CLS
DO WHILE (CD = 0) ' Check for smart card,
DEBUG HOME, "No card inserted!" ' loop until card detected
LOOP
' -----[ Program Code ]----------------------------------------------------
Main:
DO
DEBUG CR, "Select:", CR, ' Selection screen
" 1)Dump data from card", CR,
" 2)Load data to card", CR,
"Selection: ", CLREOL
DEBUGIN DEC choice ' Get selection from user
SELECT choice ' Branch to subroutines
CASE 1: GOSUB Dump_Data ' based on user input
CASE 2: GOSUB Load_Data
CASE ELSE: DEBUG CLS, "Invalid selection."
ENDSELECT
LOOP
END
Dump_Data:
DEBUG CR,CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": "
DEBUGIN DEC5 start
start = (start/16)*16
address = start
' address = 256*(page-1) ' Set the counter to the first address of the page
GOSUB Device_Addressing ' Call device addressing
' DEBUG CR, DEC5 address, CR
FOR index = 0 TO 255
IF(index//16 = 0) THEN ' Display 'y-axis' of memory map
DEBUG CR, DEC5 address, " "
incr = 0
ENDIF
GOSUB Read_Current_Data ' Read current address data
DEBUG CRSRX, (incr * 3) + 7, HEX2 temp
SELECT temp
CASE < 32
DEBUG CRSRX, (incr * 2) + 60, "."
CASE > 128
CASE 32 TO 127
DEBUG CRSRX, (incr * 2) + 60, temp
ENDSELECT
incr = incr + 1
address = address + 1
NEXT
RETURN
' -----[ Subroutine - Write_Data ]-----------------------------------------
' Writes data to specified address location
Write_Data:
DEBUG CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": "
DEBUGIN DEC5 address
DEBUG CR, "Input data to write [Hex]: " ' Prompt user for data &
DEBUGIN HEX wData ' store in variable wData
GOSUB Write_Address ' Write data to address location
temp = wData
RETURN
' -----[ Subroutine - Device_Addressing ]----------------------------------
' Begins data transmission & sends address of requested Slave devices
Device_Addressing:
GOSUB DeviceStart ' Call start condition
temp = 100000 ' Device Address 10AAA(W)
command = address.HIGHBYTE << 1
command = command & 001110 ' Device Address 10AAA(R) and ROM Address
temp = temp | command ' Add the ROM address into the Command
GOSUB SendOut
IF (I2CAck=NAck) THEN Device_Addressing ' No acknowledge, send again
Send_Address: ' Read current address
temp = address
GOSUB SendOut
IF (I2CAck=NAck) THEN Send_Address ' No acknowledge, send again
RETURN
' -----[ Subroutine - Read_Current_Data ]----------------------------------------
' During 'read' selection, allows user to browse through each 16-byte page of data
Read_Current_Data:
temp = 100001 ' Device Address 10AAA(R)
command = command & 001110 ' Device Address 10AAA(R) with ROM Address
GOSUB SendOut ' Send out the Device Address information
IF(I2CAck=NAck)THEN Read_Current_Data ' Wait for the acknowledge, if get no acknowledge, Start again
GOSUB Receive_NAck ' begin to receive the data from the Slaver, No acknowledge
GOSUB DeviceStop
rData = Temp
RETURN
Write_Address:
Send_Data: ' Send the data
Temp = WData
GOSUB SendOut
IF (I2CAck=NAck) THEN Send_data
GOSUB DeviceStop ' after send out a byte, stop and release the bus
RETURN
' -----[ Subroutine - DeviceStart ]----------------------------------------
DeviceStart: ' I2C start bit sequence
INPUT IO
INPUT CLK
LOW IO
Clock_hold:
DO : LOOP UNTIL(CLK=1)
RETURN
' -----[ Subroutine - DeviceStop ]-----------------------------------------
DeviceStop: ' I2C stop bit sequence
LOW IO
INPUT CLK
INPUT IO
RETURN
' -----[ Subroutine - SendOut ]--------------------------------------------
SendOut: ' Send out a byte and get acknowledge
SHIFTOUT IO, CLK, MSBFIRST, [Temp\8]
SHIFTIN IO, CLK, MSBPRE, [I2CAck\1]
RETURN
'------------------Receive a Byte---------
Receive_NAck: ' While recieving byte in random mode, the device require no Acknowledge
I2CAck = NAck
Receive:
SHIFTIN IO, CLK, MSBPRE, [Temp\8] 'Get a byte of data and send out a acknowledge
SHIFTOUT IO, CLK, MSBFIRST, [I2CAck\1]
RETURN
Load_Data:
' DEBUG DEC ? name,CR
' DEBUG DEC ? addr,CR
' DEBUG DEC ? city,CR
' DEBUG DEC ? phone,CR
address = 0
FOR incr = 1 TO 4 ' Print blocks one by one
LOOKUP (incr - 1),
[name, addr, city, phone], idx
DO
READ idx, wData ' Get next character
idx = idx + 1 ' Point to next location
GOSUB Write_Address
IF (wData = 0) THEN EXIT ' If 0, we're done with block
LOOP
NEXT
RETURN
Thanks, but the issue seems to involve previewing and advanced editing mode. Sometimes I get a popup message saying the message is too short and somtimes I can't place the cursor inside the message to change the text. Really peculiar behavior!
The first time I saw your firs post, it did not have Code tags. Later I saw I did.
I think it's Solar Flares.
That was part of the weird behavior. I was looking at it in preview mode and the code window looked fine but when I saved it, it was all run together and had HTML tags embedded. Now when I try to edit it, the only way I can do it is buy clicking the A/A button to switch the editor in "Source" mode rather than "WYSIWYG" mode...
' IS24C16A_Demo.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} ' This program demonstrates the basics of reading and writing data to the ' IS24C16A smart card. ' -----[ I/O Definitions ]------------------------------------------------- IO PIN 3 ' Serial Data IO CD PIN 2 ' Card Detect CLK PIN 1 ' Serial Data Clock ' -----[ Constants ]------------------------------------------------------- Ack CON 0 ' Acknowledge - Successful data transfer NAck CON 1 ' Acknowledge - Unsuccessful data transfer ' -----[ Variables ]------------------------------------------------------- index VAR Word ' Variable space for FOR..NEXT loop command VAR Byte ' Read/Write designation wData VAR Byte ' Write data rData VAR Byte ' Read data choice VAR Nib ' User selection I2CAck VAR Bit ' Acknowledge bit temp VAR Byte ' Variable space address VAR Word ' Current address loaction EpromSize CON 2 start VAR Word leng VAR Word '# bytes to dump incr VAR Nib 'myList VAR Byte(10) idx VAR Word ' -----[ Initialization ]-------------------------------------------------- ' Declares PSC and waits for a smart card to be inserted leng =256 Program_Start: DEBUG CLS DO WHILE (CD = 0) ' Check for smart card, DEBUG HOME, "No card inserted!" ' loop until card detected LOOP ' -----[ Program Code ]---------------------------------------------------- Main: DO DEBUG CR, "Select:", CR, ' Selection screen " 1)Dump data from card", CR, " 2)Load data to card", CR, "Selection: ", CLREOL DEBUGIN DEC choice ' Get selection from user SELECT choice ' Branch to subroutines CASE 1: GOSUB Dump_Data ' based on user input CASE 2: GOSUB Load_Data CASE ELSE: DEBUG CLS, "Invalid selection." ENDSELECT LOOP END Dump_Data: DEBUG CR,CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": " DEBUGIN DEC5 start start = (start/16)*16 address = start ' address = 256*(page-1) ' Set the counter to the first address of the page GOSUB Device_Addressing ' Call device addressing ' DEBUG CR, DEC5 address, CR FOR index = 0 TO 255 IF(index//16 = 0) THEN ' Display 'y-axis' of memory map DEBUG CR, DEC5 address, " " incr = 0 ENDIF GOSUB Read_Current_Data ' Read current address data DEBUG CRSRX, (incr * 3) + 7, HEX2 temp SELECT temp CASE < 32 DEBUG CRSRX, (incr * 2) + 60, "." CASE > 128 DEBUG CRSRX, (incr * 2) + 60, "." CASE 32 TO 127 DEBUG CRSRX, (incr * 2) + 60, temp ENDSELECT incr = incr + 1 address = address + 1 NEXT RETURN ' -----[ Subroutine - Write_Data ]----------------------------------------- ' Writes data to specified address location Write_Data: DEBUG CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": " DEBUGIN DEC5 address DEBUG CR, "Input data to write [Hex]: " ' Prompt user for data & DEBUGIN HEX wData ' store in variable wData GOSUB Write_Address ' Write data to address location temp = wData RETURN ' -----[ Subroutine - Device_Addressing ]---------------------------------- ' Begins data transmission & sends address of requested Slave devices Device_Addressing: GOSUB DeviceStart ' Call start condition temp = %10100000 ' Device Address %1010AAA(W) command = address.HIGHBYTE << 1 command = command & %00001110 ' Device Address %1010AAA(R) and ROM Address temp = temp | command ' Add the ROM address into the Command GOSUB SendOut IF (I2CAck=NAck) THEN Device_Addressing ' No acknowledge, send again Send_Address: ' Read current address temp = address GOSUB SendOut IF (I2CAck=NAck) THEN Send_Address ' No acknowledge, send again RETURN ' -----[ Subroutine - Read_Current_Data ]---------------------------------------- ' During 'read' selection, allows user to browse through each 16-byte page of data Read_Current_Data: GOSUB DeviceStart ' Call start condition temp = %10100001 ' Device Address %1010AAA(R) command = address.HIGHBYTE << 1 command = command & %00001110 ' Device Address %1010AAA(R) with ROM Address temp = temp | command ' Add the ROM address into the Command GOSUB SendOut ' Send out the Device Address information IF(I2CAck=NAck)THEN Read_Current_Data ' Wait for the acknowledge, if get no acknowledge, Start again GOSUB Receive_NAck ' begin to receive the data from the Slaver, No acknowledge GOSUB DeviceStop rData = Temp RETURN ' -----[ Subroutine - Read_Current_Data ]---------------------------------------- ' During 'read' selection, allows user to browse through each 16-byte page of data Write_Address: GOSUB Device_Addressing Send_Data: ' Send the data Temp = WData GOSUB SendOut IF (I2CAck=NAck) THEN Send_data GOSUB DeviceStop ' after send out a byte, stop and release the bus RETURN ' -----[ Subroutine - DeviceStart ]---------------------------------------- DeviceStart: ' I2C start bit sequence INPUT IO INPUT CLK LOW IO Clock_hold: DO : LOOP UNTIL(CLK=1) RETURN ' -----[ Subroutine - DeviceStop ]----------------------------------------- DeviceStop: ' I2C stop bit sequence LOW IO INPUT CLK INPUT IO RETURN ' -----[ Subroutine - SendOut ]-------------------------------------------- SendOut: ' Send out a byte and get acknowledge SHIFTOUT IO, CLK, MSBFIRST, [Temp\8] SHIFTIN IO, CLK, MSBPRE, [I2CAck\1] RETURN '------------------Receive a Byte--------- Receive_NAck: ' While recieving byte in random mode, the device require no Acknowledge I2CAck = NAck Receive: SHIFTIN IO, CLK, MSBPRE, [Temp\8] 'Get a byte of data and send out a acknowledge SHIFTOUT IO, CLK, MSBFIRST, [I2CAck\1] RETURN Load_Data: ' DEBUG DEC ? name,CR ' DEBUG DEC ? addr,CR ' DEBUG DEC ? city,CR ' DEBUG DEC ? phone,CR address = 0 FOR incr = 1 TO 4 ' Print blocks one by one LOOKUP (incr - 1), [name, addr, city, phone], idx DO READ idx, wData ' Get next character idx = idx + 1 ' Point to next location GOSUB Write_Address address = address + 1 IF (wData = 0) THEN EXIT ' If 0, we're done with block LOOP NEXT RETURN
