Problem posting code
acting strange under IE but not Chrome?!?!
Something in this code segment freaking out the forum editor under IE8
' IS24C16A_Demo.bs2 ' {$STAMP BS2} ' {$PBASIC 2.5} ' This program demonstrates the basics of reading and writing data to the ' IS24C16A smart card. ' -----[ I/O Definitions ]------------------------------------------------- IO PIN 3 ' Serial Data IO CD PIN 2 ' Card Detect CLK PIN 1 ' Serial Data Clock ' -----[ Constants ]------------------------------------------------------- Ack CON 0 ' Acknowledge - Successful data transfer NAck CON 1 ' Acknowledge - Unsuccessful data transfer ' -----[ Variables ]------------------------------------------------------- index VAR Word ' Variable space for FOR..NEXT loop command VAR Byte ' Read/Write designation wData VAR Byte ' Write data rData VAR Byte ' Read data choice VAR Nib ' User selection I2CAck VAR Bit ' Acknowledge bit temp VAR Byte ' Variable space address VAR Word ' Current address loaction EpromSize CON 2 start VAR Word leng VAR Word '# bytes to dump incr VAR Nib 'myList VAR Byte(10) idx VAR Word ' -----[ Initialization ]-------------------------------------------------- ' Declares PSC and waits for a smart card to be inserted leng =256 Program_Start: DEBUG CLS DO WHILE (CD = 0) ' Check for smart card, DEBUG HOME, "No card inserted!" ' loop until card detected LOOP ' -----[ Program Code ]---------------------------------------------------- Main: DO DEBUG CR, "Select:", CR, ' Selection screen " 1)Dump data from card", CR, " 2)Load data to card", CR, "Selection: ", CLREOL DEBUGIN DEC choice ' Get selection from user SELECT choice ' Branch to subroutines CASE 1: GOSUB Dump_Data ' based on user input CASE 2: GOSUB Load_Data CASE ELSE: DEBUG CLS, "Invalid selection." ENDSELECT LOOP END Dump_Data: DEBUG CR,CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": " DEBUGIN DEC5 start start = (start/16)*16 address = start ' address = 256*(page-1) ' Set the counter to the first address of the page GOSUB Device_Addressing ' Call device addressing ' DEBUG CR, DEC5 address, CR FOR index = 0 TO 255 IF(index//16 = 0) THEN ' Display 'y-axis' of memory map DEBUG CR, DEC5 address, " " incr = 0 ENDIF GOSUB Read_Current_Data ' Read current address data DEBUG CRSRX, (incr * 3) + 7, HEX2 temp SELECT temp CASE < 32 DEBUG CRSRX, (incr * 2) + 60, "." CASE > 128 DEBUG CRSRX, (incr * 2) + 60, "." CASE 32 TO 127 DEBUG CRSRX, (incr * 2) + 60, temp ENDSELECT incr = incr + 1 address = address + 1 NEXT RETURN ' -----[ Subroutine - Write_Data ]----------------------------------------- ' Writes data to specified address location Write_Data: DEBUG CR, "Enter address to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": " DEBUGIN DEC5 address DEBUG CR, "Input data to write [Hex]: " ' Prompt user for data & DEBUGIN HEX wData ' store in variable wData GOSUB Write_Address ' Write data to address location temp = wData RETURN ' -----[ Subroutine - Device_Addressing ]---------------------------------- ' Begins data transmission & sends address of requested Slave devices Device_Addressing: GOSUB DeviceStart ' Call start condition temp = 100000 ' Device Address 10AAA(W) command = address.HIGHBYTE << 1 command = command & 001110 ' Device Address 10AAA(R) and ROM Address temp = temp | command ' Add the ROM address into the Command GOSUB SendOut IF (I2CAck=NAck) THEN Device_Addressing ' No acknowledge, send again Send_Address: ' Read current address temp = address GOSUB SendOut IF (I2CAck=NAck) THEN Send_Address ' No acknowledge, send again RETURN ' -----[ Subroutine - Read_Current_Data ]---------------------------------------- ' During 'read' selection, allows user to browse through each 16-byte page of data Read_Current_Data: GOSUB DeviceStart ' Call start condition temp = 100001 ' Device Address 10AAA(R) command = address.HIGHBYTE << 1 command = command & 001110 ' Device Address 10AAA(R) with ROM Address temp = temp | command ' Add the ROM address into the Command GOSUB SendOut ' Send out the Device Address information IF(I2CAck=NAck)THEN Read_Current_Data ' Wait for the acknowledge, if get no acknowledge, Start again GOSUB Receive_NAck ' begin to receive the data from the Slaver, No acknowledge GOSUB DeviceStop rData = Temp RETURN ' -----[ Subroutine - Read_Current_Data ]---------------------------------------- ' During 'read' selection, allows user to browse through each 16-byte page of data Write_Address: GOSUB Device_Addressing Send_Data: ' Send the data Temp = WData GOSUB SendOut IF (I2CAck=NAck) THEN Send_data GOSUB DeviceStop ' after send out a byte, stop and release the bus RETURN ' -----[ Subroutine - DeviceStart ]---------------------------------------- DeviceStart: ' I2C start bit sequence INPUT IO INPUT CLK LOW IO Clock_hold: DO : LOOP UNTIL(CLK=1) RETURN ' -----[ Subroutine - DeviceStop ]----------------------------------------- DeviceStop: ' I2C stop bit sequence LOW IO INPUT CLK INPUT IO RETURN ' -----[ Subroutine - SendOut ]-------------------------------------------- SendOut: ' Send out a byte and get acknowledge SHIFTOUT IO, CLK, MSBFIRST, [Temp\8] SHIFTIN IO, CLK, MSBPRE, [I2CAck\1] RETURN '------------------Receive a Byte--------- Receive_NAck: ' While recieving byte in random mode, the device require no Acknowledge I2CAck = NAck Receive: SHIFTIN IO, CLK, MSBPRE, [Temp\8] 'Get a byte of data and send out a acknowledge SHIFTOUT IO, CLK, MSBFIRST, [I2CAck\1] RETURN Load_Data: ' DEBUG DEC ? name,CR ' DEBUG DEC ? addr,CR ' DEBUG DEC ? city,CR ' DEBUG DEC ? phone,CR address = 0 FOR incr = 1 TO 4 ' Print blocks one by one LOOKUP (incr - 1), [name, addr, city, phone], idx DO READ idx, wData ' Get next character idx = idx + 1 ' Point to next location GOSUB Write_Address address = address + 1 IF (wData = 0) THEN EXIT ' If 0, we're done with block LOOP NEXT RETURN
Thanks, but the issue seems to involve previewing and advanced editing mode. Sometimes I get a popup message saying the message is too short and somtimes I can't place the cursor inside the message to change the text. Really peculiar behavior!
The first time I saw your firs post, it did not have Code tags. Later I saw I did.
I think it's Solar Flares.
That was part of the weird behavior. I was looking at it in preview mode and the code window looked fine but when I saved it, it was all run together and had HTML tags embedded. Now when I try to edit it, the only way I can do it is buy clicking the A/A button to switch the editor in "Source" mode rather than "WYSIWYG" mode...
