So talk to me about your projects.... - Page 2 — Parallax Forums
2»
    edited 2013-07-01 19:27
    Actually, there's one less summer project to do since I found this: http://www.amazon.com/Contech-CRO101-Scarecrow-Activated-Sprinkler/dp/B000071NUS/ref=sr_1_1?ie=UTF8&qid=1372677935&sr=8-1&keywords=scarecrow+water+sprinkler. Should keep the critters out of the wife's garden.
    For just $50, might also be effective to keep neighbor's dogs from pooping in your yard!
    I wonder how long that 9V battery lasts...
    Maybe it's time for me to buy some stock in a company that manufactures 9V batteries ;-)
    edited 2013-07-01 21:59
    I am creating a DMX controlled giant (1200mm x 600mm) 3 digit 7-segment scoreboard for our next show. As they 'scoreboard' only has to display up to the maximum number of seats in the house (in our case 230) I only need two dmx channels - one for the no. of seats and one to dim it.
    A Prop reads the DMX stream from the console and parse channels 98 and 99. It then spits the data out on a new DMX universe to a 27 channel LED dimmer, of which I use 21 channels, one for each segment. Mock up works great so just waiting for LED strip to arrive and for the stage carpebter to build the display case.
    Something a bit different.
    Also converting an AVR project (from DIYXmas) that emulates an ENTTEC DMX Pro to Prop in my spare time. A bit more challenging so may take a while.
    edited 2013-07-02 19:13
    What are my summer projects? I'll sneak in a few robots when I can. But spending time programming, debugging, and interacting these two cuties is this summer's top priority. They're only young once! :)
    That's Amy on the left, and Lindsey on the right.
    743 x 558 - 85K
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-07-02 19:31
    @erco. Gorgeous. And you are correct, they are only young once. Enjoy them while you can. Once they hit 12 going on 21 then you will really have your hands full!!!!
    edited 2013-07-02 19:43
    I have a whole stack of 2"x2" boards being done...
    3 of these will make a TriBlade (cheaply) - The RamBlade, the video/keyboard etc, and the proto board. All thru hole except a few caps/resistors/etc which will be presoldered. The props and eeproms are DIP.
    There are a few prop based smt boards too.
    And some other micro versions as well that fit well with the above.
    After that I have a series of 1"x1" boards to be completed next...
    Updated CpuBlade, MemBlade, ClockBlade
    New FT232Blade, CanBlade, and some others as well.
    edited 2013-07-02 20:26
    @Erco: You must be a proud dad. Mine are older and producing their own. Grandparenting is another truly fun time - All care and no responsibility.
    @Cluso: And maybe a 1"x1" board with a FT245R and a MAX488? Oh! and a 1"x1" board with a FT232 and a MAX488?
    ... Once they hit 12 going on 21 then you will really have your hands full!!!!
    @NWCCTV: But by 31 they come right again.
    edited 2013-07-02 20:40
    Exactly!!! And grandkids are the best. Spoil them rotten and send them home!
    edited 2013-07-02 20:45
    Good words, guys.
    You ever hear someone say, "If I would have known how much fun the grandkids were, I woulda had them first."?
    That's pretty much what I did since I'm 52 with 3-1/2 year old twins: eliminate the middleman! :)
    edited 2013-07-03 01:04
    I already have an FT232RL board (propplug equiv) but its considerably smaller - 0.6"x0.7".
