EEPROM Destructive Testing — Parallax Forums
ercoerco Posts: 20,263
edited 2013-07-03 09:09 in General Discussion
Some boys over in the PicAxe forum are betting on how many WRITE cycles an EEPROM can take before failing. Usually estimated at over a million, but one guy got his up to 14 million and quit. Now the debate is whether the guy's program has a bug, or whether running at 3.3V should last longer than 5V: http://www.picaxeforum.co.uk/showthread.php?24119-How-many-writes-can-a-24LC256-take-let-s-find-out-!/page4
Has anyone done any such testing on a Stamp or Prop? We can't let those Brits have all the fun, especially this close to July 4. Let the fireworks and magic smoke begin!
    edited 2013-06-29 15:06
    Back in the 1990's, when the state of the art rated EEPROM at 100,000 write cycles, we inherited a system built by a competitor which weighed trucks at an interstate truck weigh station. And every six or seven months the truck counter would stop working. Our competitor solved this by replacing the controller main board which cost $800. When it happened on our watch I inspected the board and noted that there was no battery. There was however a small EEPROM. It was socketed and I happened to have another chip; when I replaced it, the truck counter started working again. That station weighs about 1,200 trucks a day.
    I have not tried destroying a modern EEPROM but I've had no problems using them with modestly aggressive cycling.
    edited 2013-06-29 15:13
    edited 2013-06-29 15:18
    Most EEPROMs these days are rated for over 10^6 writes over the full temperature range. If I remember correctly, this is somewhat temperature sensitive and gets worse as the temperature rises. I don't think it's dependent on the operating voltage, as long as that's kept within the spec'd limits since the voltage is run through a charge pump for the actual programming and presumably regulated, at least somewhat.
    The problem is that charges get trapped in the oxide layer so they can't be removed with a programming cycle. You could probably unroof the chip and expose it to UV light like in the "good old days" when there was no electrical erase cycle. You could probably take the device to your "friendly neighborhood" nuclear medicine facility and have them irradiate it at a high enough level to drain off those charges without damaging the lattice.
    A test program really needs to erase cells to 1s, then try to program them to 0s in different patterns and see whether any of the bits won't change to 0. That's the failure pattern. The chip does the two phases automatically, so I don't know whether it's enough to just try to program bytes to 0 repeatedly or whether you'd want to write all 1s, then all 0s and see what happens. I'm sure others could suggest better tests.
    edited 2013-06-29 15:40
    @Mike: As ever, I bow to your vast technical knowledge. Your huge areas of expertise and well-written replies make you an invaluable resource and icon in this forum!
  • Too_Many_ToolsToo_Many_Tools Posts: 765
    edited 2013-06-29 16:16
    I agree...without knowing the specifics the results are not comparable.
    I suggest looking up testing procedures and duplicating them as a standard test for all contestants.
    Mike Green wrote: »
  • xanaduxanadu Posts: 3,347
    edited 2013-06-29 16:24
    So we're not going to melt anything here then? I was going to make a P1 with a spark gap ignitor shock itself but the spark gap ignitor went bad before I had a chance :(
    edited 2013-06-30 11:03
    Sal is doing test till failure on an SD with his simple logger. This could be run on the EEprom using the EEprom filesystem. I'm not able to do this test at the moment, but all the pieces are in place, anybody wants to, Sal will answer questions.
    edited 2013-06-30 12:09
    Sal has a very short test ahead. SD cards seem to fail as soon as I look at them the wrong way.
    edited 2013-07-01 17:02
    Heater. wrote: »
    Quite the opposite so far: he is logging to the same file once per second. While each record data is written to a new location, the file header is rewritten each record. Hes past 160 MEG after two weeks with no errors, and the test will be left to run until the card fails or the card runs out of room. Its run another two weeks since then and still going strong.
    By simply creating a new file when the day rolls over, it looks like a caard could last a good long time for logging.
    An interesting note that Microchip's new EEPROM architecture writes a whole 64-byte page even if you only want to write to a single byte. There's more wear & tear than may be intended!
    http://www.picaxeforum.co.uk/showthread.php?24119-How-many-writes-can-a-24LC256-take-let-s-find-out-!&p=241337&viewfull=1#post241337
