New to Prop...looking for some help with my code — Parallax Forums
gennarobasso81gennarobasso81 Posts: 84
edited 2013-06-27 20:49 in Propeller 1
hello every, Thank you for taking the time to read this post. I am looking to learn the prop language... I have read a lot of material on it already, now I am looking to learn by doing. what I have done is hooked up the 3 axis gyroscope (L3g4300D). That is working with this current code...I also have the quick start board light up P16...showing me it is working. What I would like to do now is light up pin 17 when x axis is above 0 or maybe another nominal number to show x movement...then the same with p18 to show Y axis movement. I have the current code attached
{LED WITH 3 AXIS L3G4200D
Test File for Learning multi-functions with a sensor}
VAR
    long stack[30]
    byte cog
OBJ
axis  : "3-axis_L3g4200D"
PUB LaunchBlinkCogs
    dira [16..18]~~
    cognew(stay(16), @stack[0])
    cognew((axis.go), @stack[8])
PUB Blink( pin, rate, reps)
    dira[pin]~~
    outa[pin]~
    repeat reps * 2
       waitcnt(rate/2 + cnt)
       !outa[pin]
pub stay (pin)
  dira[pin] :=1
  !outa[pin]
  repeat
    repeat until cog := 0
      stop
PUB Start(Pin, DelayMS, Count): Success
    stop
    Success := (Cog := cognew(blink(Pin, DelayMS, Count), @Stack) + 1)
pub stop
    if Cog
      cogstop(Cog~ - 1)
And the Object code is
OBJ
  pst          : "FullDuplexSerial"
CON
  _clkmode      = xtal1 + pll16x
  _clkfreq      = 80_000_000
  SDApin         = 0            ' SDA of gyro connected to P0
  SCLpin         = 1            ' SCL of gyro connected to P1
  WRITE         = $D2           ' Request Write operation
  READ          = $D3           ' Request Read operation
  ' Control registers
  CTRL_REG1     = $20
  CTRL_REG2     = $21
  CTRL_REG3     = $22
  CTRL_REG4     = $23
  STATUS_REG    = $27
  OUT_X_INC     = $A8
  x_idx = 0
  y_idx = 1
  z_idx = 2
VAR
  long x
  long y
  long z
  long cx
  long cy
  long cz
  long ff_x
  long ff_y
  long ff_z
  long multiBYTE[3]
PUB Go | last_ticks
  pst.start(31, 30, 0, 4800)
  ' Set modes
  Wrt_1B(CTRL_REG3, $08)                    ' Fata ready signal
  Wrt_1B(CTRL_REG4, $80)                    ' Block data update
  Wrt_1B(CTRL_REG1, $1F)                    ' Enable all axes
  last_ticks := cnt
  repeat
    pst.tx(1)                               ' Set Terminal data at top of screen
    WaitForDataReady
    Read_MultiB(OUT_X_INC)                  ' Read XYZ bytes
    ' Divide by 114 to reduce noise
    x := (x - cx) / 114
    y := (y - cy) / 114
    z := (z - cz) / 114
    RawXYZ
    WaitCnt(ClkFreq / 4  + Cnt)             ' Delay before next loop
PUB RawXYZ
  'Display Raw X,Y,Z data
  pst.str(string("RAW X ",11))
  pst.dec(x)
  pst.str(string(13, "RAW Y ",11))
  pst.dec(y)
  pst.str(string(13, "RAW Z ",11))
  pst.dec(z)
'' Below here routines to support I2C interfacing
PUB WaitForDataReady | status
    repeat
      status := Read_1B(STATUS_REG)
      if (status & $08) == $08
        quit
PUB Wrt_1B(SUB1, data)
  ''Write single byte to Gyroscope.
      start
      send(WRITE)
      send(SUB1)
      send(data)
      stop
PUB Read_1B(SUB3) | rxd
 ''Read single byte from Gyroscope
      start
      send(WRITE)
      send(SUB3)
      stop
      start
      send(READ)
      rxd := receive(false)
      stop
     result := rxd
PUB Read_MultiB(SUB3)
 ''Read multiple bytes from Gyroscope
     start
      send(WRITE)
      send(SUB3)
      stop
      start
      send(READ)
      multiBYTE[x_idx] := (receive(true)) |  (receive(true)) << 8
      multiBYTE[y_idx] := (receive(true)) |  (receive(true)) << 8
      multiBYTE[z_idx] := (receive(true)) |  (receive(false)) << 8
      stop
      x := ~~multiBYTE[x_idx]
      y := ~~multiBYTE[y_idx]
      z := ~~multiBYTE[z_idx]
PRI send(value)
  value := ((!value) >< 8)
  repeat 8
    dira[SDApin]       := value
    dira[SCLpin]       := false
    dira[SCLpin]       := true
    value >>= 1
  dira[SDApin]         := false
  result               := not(ina[SDApin])
  dira[SDApin]         := true
PRI receive(aknowledge)
  repeat 8
    result <<= 1
    result             |= ina[SDApin]
  dira[SDApin]         := (aknowledge)
PRI start
  outa[SDApin]         := false
  outa[SCLpin]         := false
PRI stop
  • gennarobasso81gennarobasso81 Posts: 84
    edited 2013-06-27 11:20
    just incase anyone knows...my enter key doesn't work in this forum. Anyone else have that problem?
  • TyroneRTyroneR Posts: 22
    edited 2013-06-27 19:01
    gennarobasso81
    Im new to parallax also. Im looking forward to someone helping you with this code.I think what your trying to do will be a good learning curve for both
    of us newby's. Here's a thought. What if the leds slowly brighten as you tilt the gyro. and slowly dim as you move to center , and off when centered.
    Food for thought.
    edited 2013-06-27 20:20
    that is a great idea....I actually love it. I don't know how to code it though. Do you have any ideas? we could work on it together. You know what I have so far. I'll look up the code for led brightening and post it...we can try to figure out how to combine the code to go with the pitch, roll, and yew count
    edited 2013-06-27 20:27
    Are you using the latest IE10 ? You need to set compatibility mode in IE10. If you cannot find it, search the General forum for the details (about a month ago IIRC)
    edited 2013-06-27 20:40
    http://www.youtube.com/watch?v=eANiAChPoAA&feature=player_embedded. Check this out. Jason Dorie has a code that does the same thing, but he is using servos instead. He plans on releasing the code when he has it together
    Im in the middle of learning how to build a talking security system. Im using the Emic2,sound impact sensor, and an IR senor. I better stay with one project at a time. Untill I become more experienced with the propeller.
    Thanks anyhow. But when you do finish your code. Please post it so I can learn what you did.
