New to Prop...looking for some help with my code
hello every, Thank you for taking the time to read this post. I am looking to learn the prop language... I have read a lot of material on it already, now I am looking to learn by doing. what I have done is hooked up the 3 axis gyroscope (L3g4300D). That is working with this current code...I also have the quick start board light up P16...showing me it is working. What I would like to do now is light up pin 17 when x axis is above 0 or maybe another nominal number to show x movement...then the same with p18 to show Y axis movement. I have the current code attached
{LED WITH 3 AXIS L3G4200D
Test File for Learning multi-functions with a sensor}
VAR
long stack[30]
byte cog
OBJ
axis : "3-axis_L3g4200D"
PUB LaunchBlinkCogs
dira [16..18]~~
cognew(stay(16), @stack[0])
cognew((axis.go), @stack[8])
PUB Blink( pin, rate, reps)
dira[pin]~~
outa[pin]~
repeat reps * 2
waitcnt(rate/2 + cnt)
!outa[pin]
pub stay (pin)
dira[pin] :=1
!outa[pin]
repeat
repeat until cog := 0
stop
PUB Start(Pin, DelayMS, Count): Success
stop
Success := (Cog := cognew(blink(Pin, DelayMS, Count), @Stack) + 1)
pub stop
if Cog
cogstop(Cog~ - 1)
And the Object code is
OBJ
pst : "FullDuplexSerial"
CON
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
SDApin = 0 ' SDA of gyro connected to P0
SCLpin = 1 ' SCL of gyro connected to P1
WRITE = $D2 ' Request Write operation
READ = $D3 ' Request Read operation
' Control registers
CTRL_REG1 = $20
CTRL_REG2 = $21
CTRL_REG3 = $22
CTRL_REG4 = $23
STATUS_REG = $27
OUT_X_INC = $A8
x_idx = 0
y_idx = 1
z_idx = 2
VAR
long x
long y
long z
long cx
long cy
long cz
long ff_x
long ff_y
long ff_z
long multiBYTE[3]
PUB Go | last_ticks
pst.start(31, 30, 0, 4800)
' Set modes
Wrt_1B(CTRL_REG3, $08) ' Fata ready signal
Wrt_1B(CTRL_REG4, $80) ' Block data update
Wrt_1B(CTRL_REG1, $1F) ' Enable all axes
last_ticks := cnt
repeat
pst.tx(1) ' Set Terminal data at top of screen
WaitForDataReady
Read_MultiB(OUT_X_INC) ' Read XYZ bytes
' Divide by 114 to reduce noise
x := (x - cx) / 114
y := (y - cy) / 114
z := (z - cz) / 114
RawXYZ
WaitCnt(ClkFreq / 4 + Cnt) ' Delay before next loop
PUB RawXYZ
'Display Raw X,Y,Z data
pst.str(string("RAW X ",11))
pst.dec(x)
pst.str(string(13, "RAW Y ",11))
pst.dec(y)
pst.str(string(13, "RAW Z ",11))
pst.dec(z)
'' Below here routines to support I2C interfacing
PUB WaitForDataReady | status
repeat
status := Read_1B(STATUS_REG)
if (status & $08) == $08
quit
PUB Wrt_1B(SUB1, data)
''Write single byte to Gyroscope.
start
send(WRITE)
send(SUB1)
send(data)
stop
PUB Read_1B(SUB3) | rxd
''Read single byte from Gyroscope
start
send(WRITE)
send(SUB3)
stop
start
send(READ)
rxd := receive(false)
stop
result := rxd
PUB Read_MultiB(SUB3)
''Read multiple bytes from Gyroscope
start
send(WRITE)
send(SUB3)
stop
start
send(READ)
multiBYTE[x_idx] := (receive(true)) | (receive(true)) << 8
multiBYTE[y_idx] := (receive(true)) | (receive(true)) << 8
multiBYTE[z_idx] := (receive(true)) | (receive(false)) << 8
stop
x := ~~multiBYTE[x_idx]
y := ~~multiBYTE[y_idx]
z := ~~multiBYTE[z_idx]
PRI send(value)
value := ((!value) >< 8)
repeat 8
dira[SDApin] := value
dira[SCLpin] := false
dira[SCLpin] := true
value >>= 1
dira[SDApin] := false
result := not(ina[SDApin])
dira[SDApin] := true
PRI receive(aknowledge)
repeat 8
result <<= 1
result |= ina[SDApin]
dira[SDApin] := (aknowledge)
PRI start
outa[SDApin] := false
outa[SCLpin] := false
PRI stop
Im new to parallax also. Im looking forward to someone helping you with this code.I think what your trying to do will be a good learning curve for both
of us newby's. Here's a thought. What if the leds slowly brighten as you tilt the gyro. and slowly dim as you move to center , and off when centered.
Food for thought.
Thanks anyhow. But when you do finish your code. Please post it so I can learn what you did.
