SRAM to NVRAM
Hi,
for a while I have been looking for a nice solution involving NVRAM but...it is too much expensive.....
I was thinking of using some SRAM and pair a rechargable battery to keep the SRAM chips powered. Since I am not really a tech-guru I was wondering:
The chip I have in mind for SRAM is CY7C1019DV33-10ZSXI
1) do you have any suggestion?
2) do you know if anyone else have tried already....I would like to see some reference material....
Thanks!!!
Nicola
Thanks!!!
Nicola
but can I ask why not Eprom? if your looking for the speed then yes S-ram would be the ticket have you ever looked at the Zeus NV-Sram I have that working with the BS2
http://www.simtek.com/
Robert
At the beginning I was going to use that memory just as video memory then Ithought that it would be great not to lose the info I have stored in.
Thanks for your sugestions
Apparently SIMTEK chip was damaged and after replacement the device is working as before.
