The Shield Concept...how successful is it? — Parallax Forums
Too_Many_ToolsToo_Many_Tools Posts: 765
edited 2013-06-27 13:26 in General Discussion
Coming back to electronics after being gone for awhile, I see that the "shield concept" is now popular to sidestep the problems with PC board fabrications...so in your personal experience how well has it worked for you?
    edited 2013-06-25 16:10
    The shield is strictly an Arduino form factor. IMO it works well for that crowd in that it's all modular and plug & play. Simple & quick to connect and it looks tidy, no ribbon cables or spaghetti wiring, although I suspect it might not be the most flexible option overall. I've barely used my Arduino, but I did just receive this cheap motor shield, so if it rocks my world I'll let you know.
    http://forums.parallax.com/showthread.php/148592-Are-Seeed-Studio-Shields-compatible-with-BASIC-Stamp-2?p=1190441&viewfull=1#post1190441
    edited 2013-06-25 16:15
    I use shields frequently for both the Arduino and the Propeller Platform. Besides commercially available ones I often make my own using perf board or prototyping shield kits.
  • Too_Many_ToolsToo_Many_Tools Posts: 765
    edited 2013-06-25 16:20
    Hmmm...I did not know that the "shield" form factor was a specific Arduino feature...I have seen it discussed here so I thought that Parallax was offering that form factor choice also.
    I had thought that it was some type of ATX specification that had evolved during my absence from the electronics field.
    QUOTE=erco;1191832]The shield is strictly an Arduino form factor. IMO it works for that crowd in that it's all modular and plug & play. Simple & quick to connect and it looks tidy, no ribbon cables or spaghetti wiring, although I suspect it might not be the most flexible option overall. I've barely used my Arduino, but I did just receive this cheap motor shield, so if it rocks my world I'll let you know.
    http://forums.parallax.com/showthread.php/148592-Are-Seeed-Studio-Shields-compatible-with-BASIC-Stamp-2?p=1190441&viewfull=1#post1190441[/QUOTE]
    edited 2013-06-25 16:21
    No idea. I'm still working with 40 pin DIP Propellers and Vero board.
    If someone want's to sell me a "shield" or adapter board for some new fangled, microscopic SMT chip that I can tack onto my strip board I'm very happy.
    edited 2013-06-25 16:27
    I think the "shield" idea started with the Arduino.
    Meanwhile, as chips got smaller and smaller a whole industry has grown up supplying chips mounted on little boards such that normal people could solder them into their projects. Check out Adafruit or GadgetGangster etc.
    In the old days we would call them something boring like "modules" or "adapters" but it seems now a days any old stupid word will do.
    edited 2013-06-25 16:38
    Guess you have been gone for a while. :) The ATX motherboard standard was adopted in 1995:
    http://en.wikipedia.org/wiki/ATX
    edited 2013-06-25 16:39
    I have very limited experience with these things and only with the Arduino, but it seems to me that while the original concept might have been okay, it's starting to break down now that Arduino boards are so different. So now that you have so many different boards, you are required to pay attention to which shields are compatible with which boards, revisions and all. And then you find some shields don't carry their pins all the way through to the next shield, etc. and so the whole concept begins to break down, in my humble opinion. As I see it, if the plug-and-play one-shield-fits-all concept breaks down, then what's the point of having a shield? Without universal compatibility, what the heck is it?
    BTW, I dislike the name shield. I also happen to dislike the name Arduino, too, but who am I to deride such things?
    edited 2013-06-25 16:42
    LOL..when I first saw the term "shield" I thought "What the heck is that?"
    Hey call me boring but "modules" or "adapters" work for me.
    Heater. wrote: »
    edited 2013-06-25 16:44
    Nope..just been busy doing other stuff for about ten years.
    FWIW...not a lot has changed in electronics from what I can see.
    That can be good or bad depending on your viewpoint.
    Publison wrote: »
    edited 2013-06-25 16:49
    We didn't have the Propeller ten years ago, now we do. Life is good. :)
    edited 2013-06-25 16:50
    LOL..your comments discuss exactly why I posted the original post.
    Uniformity sems to be a great idea...as long as everyone wants the same thing.
    The minute you want to change...the form factor is a straitjacket.
    edited 2013-06-25 16:54
    While the implementation may be new, the concept of multi-cores on a chip is an old one.
    And I should add that I think the Parallax implementation is well done.
    Publison wrote: »
    edited 2013-06-25 17:03
    Yes, but as you will find out, there are a bunch of very helpful people around here. A lot of information sharing going on. No question is stupid.
    We do joke around sometimes, so you will have to get used to the humor that comes from all around the world, so some gets lost in the translation.
    Not sure if I said this before , welcome to the forums!
  • David BDavid B Posts: 593
    In my opinion, the idea is great but the implementation is only ok.
    Device breadboarding is really difficult with so many different connectors and power needs. and shields are a step in the right direction.
    The good:
    they're a start at standardizing device connectors
    they provide power along with signal pins
    they stack to some degree
    The bad:
    they aren't all that standard. There are slight variations in shield design
    they don't provide +12 or +/- 15 volts, used by a lot of analog circuits
    some shields don't stack, which limits how multiple shields can be combined
    I'd rather use a parallel backplane for connecting devices, like the old computers used.
    edited 2013-06-25 17:16
    Sounds like the S100 bus all over again.
    In that way nothing has changed since 1970 something.
    Don't worry about it, fire up the soldering iron and weld stuff together.
    As for multi-core MCUs, I don't see that there have been so many. The Propeller is one, the chips from XMOS are another. People mention the GreenArray devices from time to time but that's going nowhere. Certainly the Propeller offers a uniquely easy to use multi-core solution.
    My beef is that I can't get tubes so easily anymore...
    edited 2013-06-25 17:47
    Heater. wrote: »
    I
    Nothin' wrong with that. At least I have THAT one memorized. :)
    Tubes...12AX7 are about all I have left. I have heaters, but they all work on 120VAC. Got plenty of 6.3VAC xformers though.
    edited 2013-06-25 18:05
    Publison wrote: »
    We need a project that uses a Prop and one or more 12AX7's...
    C.W.
    edited 2013-06-25 18:50
    In my opinion the inclusion of +/- 12 or 15 volts should be a different adapter all together.
    Analog has a number of very unique needs...and from experience mixing analog and digital usually means problems noisewise.
    I can see advantages for a uniform standard for boards...power and addressing/data are all digital needs.
    David B wrote: »
    The good:
    The bad:
    edited 2013-06-25 20:29
    No single standard will meet the requirements of all digital or analog applications alone, never mind both. IMHO S100 was one of the better attempts in the digital arena at the time since it provided +5 and +-12V power. Industrial automation, building automation, instrumentation, SCADA systems, computers, and networking all have their own unique needs.
  • LawsonLawson Posts: 870
    edited 2013-06-25 20:59
    IMHO clean 3.3 or 5 volts is enough for a lot of analog work now days. There are some VERY nice single supply rail to rail op-amps now. At the higher end the OPA2350 is one of my favorites. Though if SOIC doesn't scare you, the OPA2365 is better in every way. Something like a LMC6482 would be a better 741 replacement. And if you like power consumption golf, the MCP6041 is a favorite.
    Lawson
    edited 2013-06-25 22:00
    Well said.
    kwinn wrote: »
    edited 2013-06-25 22:41
    If you don't have more than 5 volts, how are you going to run your 811A shield?
    1024 x 1365 - 128K
    edited 2013-06-25 22:57
    "Shield" is just a dumbed-down name for "daughterboard," just as "sketch" is a dumbed-down name for "program." This Arduinospeak is designed to attract artsy folks who might otherwise be technophobic and put off by computerspeak. We, of course, being the high priests of everything technical and steeped in the testaments of Spin, C, and Forth, sneer at such inane foolery and do not suffer it gladly.
    edited 2013-06-26 04:57
    And suddenly I wished it was possible to upvote posts here...
    edited 2013-06-26 11:05
    Very true, but lets not be too harsh with the folks my kids dubbed "technotwits" when they were much younger.
    edited 2013-06-26 11:44
    I'd prefer not to think that the Propeller has to be without sheild-like boards.
    We have Gadget Gangster that provides a line of good boards to add to a Propeller mother board. And the Propeller QuickStart board has a set of daughter board options as well. There are times that modularity is very appealing. You just have to know what you are doing with it and why.
    There are ways to have it not be a complete straight jacket if one is creative. But in generally locks in who you buy from... so you better like your suppliers prices, supporting info, quality control, and design ability. A lot of them fall short in one or more of those ares.
    The Propeller even comes in motherboards with 2 or more Propellers on one board for more ambitious projects.
    edited 2013-06-26 12:21
    Heater. wrote: »
    Maybe on your side of the pond, Heater. But here in the states I can find pretty much what I want.
    :thumb:
    ...now, the cost is a different story! :tongue:
    edited 2013-06-26 12:22
    David B wrote: »
    ...now THAT is a thing of beauty!!!
    :thumb:
    edited 2013-06-26 12:23
    Gadgetman wrote: »
    +1000000000000000000000000000000000000000000000000.000000000000000000000000000009
    edited 2013-06-26 15:17
    Well the approach seems to be very successful (=$$$) judging from the popularity of the Arduino.
    In my opinion, it is a case of potato versus potatoe...different names for the same item...driven by marketing.
    The biggest concern for a competitor like Parallax would be to be able to easily utilize any shields that are developed by 3rd parties.
    That ease of use would be a major design decision that can determine whether a Parallax or Arduino branded processor is selected for the product.
    FWIW...it is a known fact that designers under pressing deadlines choose processors for commercial products they are comfortable with...and their comfort zone is usually set up by playing with the processor on their free time aka home projects. A classic case of this is the choice of Intel over Motorola technology in the development of the very sucessful IBM PC platform...at that time the Motorola tech was superior but the Intel tech better known to the designers due to previous exposure in home based/built CP/M systems. Knowing this, any company worth its salt gives free samples and info to engineers and educators to "seed" those who will design the next product line. I consider Parallax to be excellent in terms of this effort and would count it as a big plus when I was deciding what to design into a new product line.
