New PNUT.EXE loads all 128KB of Hub RAM — Parallax Forums
cgraceycgracey Posts: 14,289
edited 2013-07-02 05:32 in Propeller 2
I modified PNUT.EXE so that it loads all 128KB of Hub RAM and then executes the PASM program at $E80 in Cog 0. Use F11 to load all 128KB RAM, instead of F10 which just loads 2KB at $E80.
It is necessary to space your PASM code to $E80 to step over the ROM area. This is done by starting your program off with:
DAT
    orgh    $E80
    org
<start of PASM code here>
For the DE0-Nano, it will be necessary to start off with 'orgh $18E80' to overcome the 4x memory wrap, due to having only 32KB.
Here's the new PNUT.EXE with example programs for both the DE2-115 and the DE0-Nano:
Prop2Full128k.zip
Note there are two new PASM directives, suggested by Sapieha:
ORGH address - fills hub RAM with $00 bytes up to hub location 'address'
ORGF address - fills cog RAM with $00000000 longs up to cog location 'address'
  • SapiehaSapieha Posts: 2,964
    edited 2013-06-17 18:18
    Hi Chip.
    Thanks.
    Now You can see that ORGH have be more usable
    DAT
        byte 0[$E80]
        org
    For the DE0-Nano, it will be necessary to start off with 'byte 0[$18E80]' to overcome the 4x memory wrap, due to having only 32KB.
    Attachment not found.
    edited 2013-06-17 21:24
    Hi Chip.
    I have a DE0-Nano board and just tried the new PNUT program with your suggested header of
    byte 0[$18E80]
    org
    This doesn't seem to work. If I remove the suggested line, programs load + run Ok at $E80.
    This is using the F10 function in PNUT
    Regards
  • cgraceycgracey Posts: 14,289
    edited 2013-06-17 21:58
    ozpropdev wrote: »
    Hi Chip.
    byte 0[$18E80]
    org
    Regards
    Ooops! I forgot to mention that F10 does the same thing as before. It's F11 that loads the whole memory. Use F11.
    edited 2013-06-17 22:23
    DAT
        byte 0[$E80]
        org
    Yaaayyy, now I've just got to jump back into the P2 cockpit and hopefully not crash before take-off.
    BTW, any chance of getting a dud P2 to check PCB footprints against?, or at least a confirmation on the exact package details in case I've probably missed that.
    edited 2013-06-18 00:40
    Sapieha wrote: »
    Hi Chip.
    Thanks.
    Yes, I just implemented your ORGH and ORGF directives. They were needed badly. Thanks for thinking of these.
    edited 2013-06-18 00:41
    PM me your shipping address and I think we can send you a few duds.
    edited 2013-06-18 00:55
    Hi Chip.
    THANKS.
    I saw that long time ago -- As fast I started help Cluso with Debugger and tested some code for my Basic
    edited 2013-06-18 01:04
    Hi Chip.
    Forgot to ask.
    How long it is before You post that version with demo's?
    edited 2013-06-18 01:20
    Sapieha wrote: »
    Hi Chip.
    Forgot to ask.
    The first post in this thread has the latest .zip with PNUT and the demo's.
    edited 2013-06-18 01:24
    Hi Chip.
  • BaggersBaggers Posts: 3,019
    edited 2013-06-18 01:53
    Thanks for this Chip, I'll look forward to having a play later :)
    edited 2013-06-18 02:43
    Hi Chip.
    As You made Start at $E80.
    Is it possible to add another start at $1000
    edited 2013-06-18 03:06
    Hi Chip.
    Now I have tested both OrgH-F directives
    Function correctly as expected.
    Very much thanks
    edited 2013-06-18 03:24
    Hi Chip.
    I have be thinking little -- and as always have impossible questions.
    It is possible have one START XXXXX directive in PNut that auto-start loaded code from its XXXXX address ??
    Sapieha wrote: »
    Hi Chip.
    edited 2013-06-18 06:49
    Thanks Chip!
    This will speed up the development cycle of some code I am working on immensely!!!
    DAT
        orgh    $E80
        org
    Prop2Full128k.zip
    edited 2013-06-18 09:28
    This is excellent. Thanks for the update chip!
    We can specify any address with these right?
    edited 2013-06-18 09:45
    Hi potatohead.
    As long I have tested -- Any address and as many nested OrgH-F as You need in code
    potatohead wrote: »
    edited 2013-06-21 08:33
    DAT
        orgh    $E80
        org
    Prop2Full128k.zip
    Thanks Chip! I suspect this will mostly eliminate the need for p2load but I'll still support it and upgrade it if there is a need.
    edited 2013-06-21 09:16
    Hi David.
    It don't eliminate p2load YET -- and even if in some cases -- p2load still usable as it have much more Start-up possibility's
    And it is always need for stand alone loader..
    David Betz wrote: »
    edited 2013-06-21 09:18
    Sapieha wrote: »
    Hi David.
    I certainly won't eliminate it. I just won't be adding much to it anymore unless someone has a request.
    edited 2013-06-21 12:37
    Actually, p2load has a LOT of features, and I still use it... the new 128k capable pnut does speed up my debug cycle for pasm programs, but does not (easily) let me build large loadables from multiple separate files.
    I like both :)
    David Betz wrote: »
    edited 2013-06-22 00:15
    I like both :)
    Agreed. p2load has multiple file capability. And I like the terminal mode too. :)
    edited 2013-06-22 02:09
    Yes I too think P2Load still has a lot of good usage :D
    edited 2013-07-01 13:41
    Sapieha wrote: »
    Hi Chip.
    I will do something about this. I think if there are no PUB's or PRI's found in the source file, PNUT could operate in a PASM-only mode where a special directive could set the start address. I will add this after I get the Spin2 compiler functioning. Thanks for thinking of this.
    edited 2013-07-01 13:46
    How will this start address be encoded into the binary file? For PASM code the binary file is just a dump of memory isn't it? There isn't any header information that could include a start address is there?
    edited 2013-07-01 14:06
    David Betz wrote: »
    I don't know yet, but it could be a long following the 128KB of data.
    edited 2013-07-01 15:31
    I guess that would essentially be a "trailer" rather than a header. You might be better off with the header though. That way if the image being downloaded was less than 128k you could load only what is necessary. That would speed up loading a bit.
    Hi Chip.
    Thanks for understanding my intentions on that directive.
    Chip I think that even if that directives are found --- It can be good if START XXXXXX can override them and start first INIT code (that in that case will be run and discard and placed at end of other code) for other things TYPE drivers that need be loaded before SPIN and then initialise SPIN interpreter.
