PropBasic Studio - Coming Soon - Page 2 — Parallax Forums
2
    edited 2013-05-26 21:46
    @Batang, this looks brilliant!Keep up the good work.
    I look forward to testing this when it is ready.
  • RS_JimRS_Jim Posts: 1,777
    edited 2013-05-27 06:31
    Me too!
    Jim
  • tritoniumtritonium Posts: 549
    edited 2013-05-27 06:44
    Count me in!
    Dave
  • BatangBatang Posts: 234
    edited 2013-06-01 08:34
    Just a quick update.
    Image showing dockable code editor windows and auto complete for DO...LOOP template.
    New additions:
    1. Auto complete for DO..LOOP, IF..THEN, FOR..NEXT (all variations), SUB..ENDSUB, FUNC..ENDFUNC, TASK..ENDTASK templates as well as Key Words etc.
    2. Auto indentation
    3. DO..LOOP and FOR.. NEXT outline code folding.
    4. Terminal Window can be docked above/below or on the sides of a code window.
    Cheers.
    http://prx.sytes.net/PropBasicStudio_Update.png
    edited 2013-06-01 10:09
    Hi
    Keep up the good work-
    Looking forward to trying it out
    Dave
    edited 2013-06-01 12:27
    Added document export functions
    1. To PDF File (Always useful)
    2. To HTML File (Useful if you want to put syntax highlighted code in a web page)
    3. To Rich Text File (Useful if want to add syntax highlighted code to a word document)
    Cheers.
    edited 2013-06-01 13:10
    Batang wrote: »
    Cheers.
    This is very promising. Thanks to both Batang and Bean.!
  • max72max72 Posts: 1,155
    edited 2013-06-01 13:15
    Looks great!
    Massimo
  • jmgjmg Posts: 15,200
    edited 2013-06-01 14:29
    Batang wrote: »
    Nice.
    Batang wrote:
    12. Integrated prop binary loader (and maybe compiler).
    I would suggest
    a) including the compiler(s) as then users know they have correct 'as tested' version matches.
    b) check the FreeBasic compiler command line, and include an option for fbc compile for PC-hosted testing. (and some debug, via )
    Also, for Bean, I see FreeBasic supports this common pre-processor syntax
    #DEFINE YellowOnGreen
    #IFDEF YellowOnGreen
    so if PropBASIC expanded its IFDEF to include this, users can mix PC/Prop test codes.
  • BeanBean Posts: 8,129
    edited 2013-06-04 07:18
    I just wanted to let everyone know that Batang and I have been working on the IDE and quite a few changes to PropBasic.
    It seems to be going pretty well so far. The relationship seem good.
    The version of PropBasic released with PropBasic Studio will be version 2 (PropBasic2).
    Then there will be another release of PropBasic (PropBasic3) that will be a total re-write. More like a traditional BASIC language.
    Full expression evaluation for all parameters.
    Local variables for subroutines/function.
    Common commands will be subroutines instead of generated in-line.
    All code will be LMM. (TASKs can be PASM for video drivers etc.)
    All variables will be stored in HUB ram.
    Integrated Debugger.
    Will support the Propeller2 (maybe not the initial release).
    PropBasic3 is probably a year away, but I thought I would let everyone know my plans.
    Bean
    edited 2013-06-04 07:32
    FANTASTIC!!
    Jeff
  • MicksterMickster Posts: 2,934
    edited 2013-06-04 09:31
    Bean wrote: »
    Bean
    Truly fantastic news!
    You and Batang need one of those PayPal Donate button thingies :smile:
    Mickster
  • pmrobertpmrobert Posts: 678
    edited 2013-06-04 09:47
    EXCELLENT! I'm very happy to see this collaboration. The eventual Prop 2 support is oh-so-sweet as is a proper IDE/debugger.
    -Mike
    edited 2013-06-04 09:58
    Same as Bean things are progressing well.
    Included here is a PDF giving an example of the new ProBasic syntax as well the IDE highlighting and so on.
    Although the language may be "Basic" you can rapidly write code and as PropBasic compiles to assembly get high speed performance.
    PropBasicSample.pdf
  • Christof Eb.Christof Eb. Posts: 1,593
    edited 2013-06-04 12:57
    Hi,
    writing as an old fan and user of PropBasic:
    1. These activities are great!
    2. perhaps you might include the existing debugging feature into the ide. I found it helpful.
    3. Bean, the possibility to compile to cog code for fast basic instead of pasm drivers is THE key advantage over spin. Perhaps you want to leave a path open for such a feature for later releases? (Why did a simple guy like me use PropBasic? Because he wants to have speed and did not feel firm to write pasm. And because this language has not much overhead and the docu was good enough and reliable.)
    Just my thoughts... Thanks Christof
    edited 2013-06-04 23:39
    Bean wrote: »
    Sounds good.
    I grabbed the example in this thread & fed into FreeBASIC. to use as a functional simulator & structural debug.
    Where a function did not exist, I created a dummy wrapper
    It does look quite close, with some simple alias good to solve a couple of issues
    * Allow CONST as alternative to CONSTANT
    * Allow RANDOMn as alternative to RANDOM (RANDOM is a file keyword in FreeBASIC)
    or add alternate format as y = Rnd( seed )
    * Allow Function calls syntax to be open list or (param list) - ie tolerate ()
    fbc requires () on function calls, & can either use () or not on Sub calls
    Personally, I prefer to use () on all calls, for consistency and common with other languages.
    * Tolerate keyword after EXIT (fbc needs EXIT DO, for example )
    and allow #IFDEF flow alias for preprocessor, for the cases needing any fixups..
    A good quick summary of FreeBASIC keywords is here :
    http://www.freebasic.net/wiki/wikka.php?wakka=CatPgFullIndex
    '           This demo program moves 1000 dots around on a NTSC screen.
    ' Edited to compile in FreeBasic - Param details not checked.
    ' Define CONs
    CONST NumDots = 1000 ' CONSTANT NumDots = 1000
    CONST MaxDots = 999  ' CONSTANT MaxDots = 999
    ' Define HUB variables
    DIM  dots(NumDots) AS LONG ' x, y, xdir, ydir  ~HUB
    'DIM  dots AS HUB LONG(NumDots) ' x, y, xdir, ydir  ~HUB
    ' Define variables (LONGs only)
    DIM curDot      AS LONG
    DIM dotsAddr    AS LONG
    DIM X           AS LONG
    DIM Y           AS LONG
    DIM dirX        AS LONG
    DIM dirY        AS LONG
    DIM seed        AS LONG
    DIM temp        AS LONG
    #IFDEF __FB_WIN32__  'Defined in Windows FreeBasic
    SUB PAUSE ( byval amount as integer )
        Sleep amount
    END SUB
    ' fbc prefers specific type per parameter
    SUB RDBYTE (dotsAddr as integer, x as integer, y as integer, dirX as integer, dirY as integer)
    END SUB
    ' fbc allows line-continue _
    SUB WRBYTE (dotsAddr as integer,_
                       x as integer,_
                       y as integer,_
                    dirX as integer,_
                    dirY as integer)
    END SUB
    SUB TV_XPlot (x as integer, y as integer)
    END SUB
    function GETADDR ( va as LONG)  as LONG
         GETADDR = va
    end function
    SUB RANDOMn ( seed as LONG, y as LONG )   ' RANDOM is a reserved word
      y = Rnd( seed )
    END SUB
    #ELSE  'For targets other than Windows (eg PropBASIC), add custom stuff here
    #ENDIF
     ' Start of main code
    ' ~SUB MAIN
         dotsAddr = GETADDR(dots(0))    'fbc requires ()   ~ dotsAddr = GETADDR dots
        FOR curDot = 0 TO MaxDots
            RANDOMn (seed, x) 'RANDOM seed, x   fbc allows () or no ()
            x = x AND 255
            DO
                RANDOMn seed, y  'RANDOM seed, y
                y = y AND 255
            LOOP UNTIL y < 192
            DO
                RANDOMn seed, dirX   ' RANDOM seed, dirX
                dirX = dirX AND 255
                dirX = dirX / 52
                RANDOMn seed, dirY   ' RANDOM seed, dirY
                dirY = dirY AND 255
                dirY = dirY / 52
                IF dirX <> 2 OR dirY <> 2 THEN EXIT DO 'THEN EXIT
            LOOP
            WRBYTE dotsAddr, x, y, dirX, dirY
            TV_XPlot x, y
            dotsAddr = dotsAddr + 4
        NEXT
        DO
            dotsAddr = GETADDR(dots(0))   ' dotsAddr = GETADDR dots
                RDBYTE dotsAddr, x, y, dirX, dirY
                TV_XPlot x, y
                x =x + dirX
                x = x - 2
                IF x > 255 OR x < 0 THEN
                    dirX = 4 - dirX
                    x = x + dirX
                    x = x - 2
                ENDIF
                y = y + dirY
                y = y - 2
                IF y > 191 OR y < 0 THEN
                    dirY = 4 - dirY
                    y = y + dirY
                    y = y - 2
                ENDIF
                TV_XPlot x, y
            NEXT
            PAUSE 10
        LOOP
        END
    ' ENDSUB
    edited 2013-06-05 00:11
    Does anyone have or can point me to the following:
    1. A complete list of SPIN keywords in text file format.
    2. A complete list of PASM mnemonics in text file format.
    Thanks in advance.
    edited 2013-06-05 00:40
    Batang wrote: »
    As a starting point I'd suggest the datasheet chapter 6.1. It needs some cleanup re: SPIN/PASM distinction though (after having been extracted).
  • dgatelydgately Posts: 1,647
    edited 2013-06-05 09:56
    Being a total "nag head" here...
    BASIC is an acronym for "Beginner's All-purpose Symbolic Instruction Code" so should be spelled in UPPERCASE, right? So is it PropBasic? or PropBASIC?
    Just some food for thought.
    Having said that, nice effort, guys! I especially like the formatting example, makes even BASIC readable, to me :-)
    dgately
    edited 2013-06-05 11:37
    dgately wrote: »
    dgately
    PropBasic is a version of BASIC ;)
    Bean
  • jonesjones Posts: 281
    edited 2013-06-06 09:28
    Bean wrote: »
    Bean
    Long live PropBasic2!
    Any chance that PB2 might be used to pre-compile tasks as native cog code to be loaded by PB3? Since as you pointed out in another thread, main programs are often LMM, there wouldn't be a speed penalty to have the benefits of your planned changes for PB3. For cog code, PB2 is still a significant step in abstraction and convenience above assembler.
    Either way, thanks for your hard work, Bean. From what I've seen so far, I'll still be pretty happy just with PB2 and PB Studio.
    edited 2013-06-06 09:40
    Jones,
    The code from PropBasic2 will most likely not work in PropBasic3 because ALL variables will be in HUB ram instead of COG ram.
    Usually if you need really fast speed (video drivers, etc) you are going to want to use PASM anyway.
    Yes, I have written a couple video drivers in PropBasic, but you need to really "know" the compiler to do that. And that code still will not be as fast as PASM code.
    It's just not worth the effort to make basically two compilers (one for native code and one for LMM).
    My experience tell me that if you need the speed of native code, there are very few situations where compiled PropBasic code is going to work well.
    Bean
    edited 2013-06-06 14:54
    Bean wrote: »
    but it is much faster than Spin, right ? - and users can in-line as much PASM as they want to ?
    Bean wrote: »
    Even if it is not quite as fast as Pure-PASM (no compiler will be) I see a strong place for a 'High level Assembler' - ie a simple language that can create COG-resident code, as that lets users 'get at' the silicon power better.
    Well commented PASM output, (perhaps even with delay estimates), will also help teach users PASM itself.
    Taking an example from another thread, a user wants to wait on a Pin, and also an Exit flag.
    Seems a fairly common usage.
    We have this code and comment :
    ["repeat until ina[tstop] == 0 or BYTE[stopadr] == 1
    takes more than 1 us (more like 10us), so you will not get a resolution of 1 us with that code."]
    What is the equivalent code in PropBASIC, and what PASM would it create ?
    edited 2013-06-06 15:11
    jmg wrote: »
    I'm not sure if you consider it a "simple language" but Propeller C can generate COG-resident code. C has been called a "universal assembler" by some.
    edited 2013-06-06 15:40
    David Betz wrote: »
    Yes, that detail of PropC has real appeal.
    Perhaps you could do the classic waiting code-line above, in Prop C and we can compare Generated PASM with PropBASIC (when posted), and a variant using in-line PASM, if that offers any further improvement.
    edited 2013-06-24 11:51
    Can we get an update on this project?
    Thanks!
    Jeff
    edited 2013-06-24 16:15
    I haven't heard from Batang for awhile. I'm not sure what he is up to.
    Maybe a "paying gig" got priority ???
    Bean
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-06-25 19:48
    And here I thought I was the only one waiting for this. You guys ROCK. I can't wait to see the full blown program running on my systems. And as @Mickster said, you guys need a PayPal Donation account. Having written a lot of code in the past I know that it is a time consuming and grueling process to get everything to work the way you want and the way others expect!!!!
    edited 2013-06-26 10:53
    Hi,
    this http://forums.parallax.com/showthread.php/148487-Drops-Rain-and-Sleep-...-and-the-Prop-using-PropBasic
    was possible only because of the outstanding feature of PropBasic to generate very fast Cog- Code.
    Thanks a lot!!!
    Christof
    edited 2013-06-27 22:16
    Hi Guys,
    Bean nailed it with the above quote, I have been up to eyeballs with work these last few weeks and will have it cleared over this coming weekend.
    Then it will be about 2 weeks until a beta release.
    Cheers.
