The WireWorld Computer - Page 7 — Parallax Forums
123457»
  • BaggersBaggers Posts: 3,019
    edited 2013-05-22 08:09
    Dropbox hasn't been updated yet potatohead, will try again later.
  • potatoheadpotatohead Posts: 10,265
    edited 2013-05-22 08:10
    It's uploading now, and I'm outta here for a while. Let me know if it works.
    Filename is: PropGCC_P2_Alpha_V_1_9_0_OSX_10_6_8.tar.gz
    Keep checking back. For some reason, it's a slow upload right now. 30k/sec :( Says about an hour. I've no idea what the deal is.
    edited 2013-05-22 09:37
    The package is there now, FWIW.
    edited 2013-05-22 09:39
    potatohead wrote: »
    Did you try --target-help to verify that it has P2 support?
    edited 2013-05-22 10:10
    Yes I did. Looks A-OK to me.
    edited 2013-05-22 10:17
    potatohead wrote: »
    Great! Thanks for checking!
    edited 2013-05-22 11:40
    Yeah no worries. Happy to do it. We need the right build out there. Thanks for the quick tip.
    edited 2013-05-22 12:20
    potatohead wrote: »
    Let's hope this one works okay for Baggers. I guess we need to figure out how to handle this for official releases since I imagine we want our code to work on Snow Leopard as well as Lion and Mountain Lion. Did you ever try the Mac release I posted on Google Code? Did that fail on your Snow Leopard system like it did for Baggers?
    edited 2013-05-22 12:24
    I think I did, if we are talking about the same one. That was the release I worked through the permissions issue on. (xattrib) When I realized the build was newer than my OS, I started down this road to build a nice old package. :)
    Seems to me, this comes down to either:
    1. Build on an older OS X release. Could do this in a VM maybe. I've not run OS X that way before.
    2. Modify the build scripts to pass along that argument needed to limit the executable.
    FWIW, anybody building on Windows 8 will encounter a similar thing with binaries that won't run on XP. Baggers had it happen with P2Prep. First build was on Windows 7, ran fine, second build was on Win 8, no more XP...
    For a while, I can make packages. This isn't hard now. Honestly, I'm kind of tempted to try packaging one up into one of those spiffy Apple installer type distributions.
    edited 2013-05-22 12:38
    potatohead wrote: »
    If you're willing to figure out how to make an Apple installer for PropGCC that would be great! I think Steve (jazzed) has done some work on this for SimpleIDE so he might be able to point you in the right direction.
  • jazzedjazzed Posts: 11,803
    edited 2013-05-22 14:31
    potatohead wrote: »
    Look here: https://code.google.com/p/propside/source/browse/?name=spinside#hg%2FSimpleIDE.pmdoc
    edited 2013-05-22 15:53
    I asked my good neighbour if I could use their net for a while, and grabbed the Mountain Lion update, as my hub wouldn't allow a file >4GB to be downloaded :D
    So I now have Mountain Lion on my iMac, and have David's build working, and building the sdramtest demo :D
    Thanks all :D look forward to having a good play with it tomorrow after work!
    edited 2013-05-22 16:50
    Where is this sdramtest demo?
    Glad you are running!
    edited 2013-05-22 20:08
    potatohead wrote: »
    sdramtest is attached to message #77 in this topic.
    edited 2013-05-22 20:16
    Thanks!
    I'm doing a fresh build of current default to prepare for a go at an install package and I can definitely tell the difference between jsbuild.sh 5 and 6 The latter just screams through stuff! Back above 3 for a load average. :)
    It took about a third the time. Right about 15 minutes on this machine. The one this morning was a little over 40, just FYI. (Thanks Jazzed)
    To set the system PATH on OSX starting with Leopard, you drop a file containing the path into /etc/paths.d A .bashrc script works, but is non-standard.
    I used sudo echo "/opt/parallax/bin" > /etc/paths.d/PropGCC
    Gonna wait a bit on a package. Built two with PackageMaker tonight and had some basic failure on both. If there is demand, I can revisit this. What we have is pretty easy right now.
    edited 2013-05-23 04:33
    potatohead wrote: »
    Thanks!
    I'm doing a fresh build of current default to prepare for a go at an install package and I can definitely tell the difference between jsbuild.sh 5 and 6 The latter just screams through stuff! Back above 4 for a load average. :)
    What kind of processor do you have on your Mac and how much memory?
    edited 2013-05-23 08:15
    2.2 Ghz i7 4GB 1333 Mhz RAM
    at idle, bunch of stuff launched, but not busy
    Processes: 73 total, 3 running, 70 sleeping, 388 threads                    07:58:53
    Load Avg: 0.22, 0.39, 0.34  CPU usage: 1.58% user, 1.71% sys, 96.70% idle
    SharedLibs: 7508K resident, 784K data, 0B linkedit.
    MemRegions: 27149 total, 1325M resident, 26M private, 532M shared.
    PhysMem: 804M wired, 2062M active, 748M inactive, 3614M used, 472M free.
    VM: 196G vsize, 1033M framework vsize, 1429432(41) pageins, 56177(0) pageouts.
    Networks: packets: 4048303/3574M in, 4129641/2714M out.
    Disks: 26117292/217G read, 1553583/55G written.
    PID    COMMAND      %CPU TIME     #TH   #WQ  #POR #MREGS RPRVT  RSHRD  RSIZE  VPRVT
    96916  top          5.8  00:02.25 1/1   0    24   33     1220K  264K   1800K  17M
    96831  ugslmd       0.0  00:13.48 3     0    28   41     18M    244K   19M    49M
    96803  mdworker     0.0  00:01.15 3     1    52   96     4904K  18M    11M    81M
    77870- PackageMaker 0.0  04:20.72 3     1    408  401    38M    104M   62M    105M
    77177  WebProcess   0.0  15:35.19 7     2    124  356    27M    47M    51M    250M
    72350  bash         0.0  00:00.25 1     0    17   25     292K   856K   864K   17M
    72349  login        0.0  00:00.02 1     0    22   53     120K   312K   788K   19M
    58247  VDCAssistant 0.0  00:00.32 5     2    93   89     712K   18M    3496K  80M
    58245- Skype        0.0  00:35.39 19    2    314  365    43M    81M    44M    198M
    57970  Safari       0.0  00:08.43 12    2    185  345    11M    76M    22M    236M
    57861- dbfseventsd  0.0  00:19.33 1     0    8    26     12K    304K   128K   12K
    57860- dbfseventsd  0.0  00:30.89 1     0    8    26     4136K  300K   4272K  12M
    57859- dbfseventsd  0.0  00:04.12 1     0    14   25     16K    296K   240K   5184K
    57849  Image Captur 0.0  00:00.50 3     2    83   88     1824K  35M    5236K  87M
    57831- Dropbox      0.0  04:01.27 27    2    196  627    60M    51M    44M    260M
    57776  bash         0.0  00:00.06 1     0    17   25     260K   856K   800K   1
    a few minutes into a build using ./jsbuild.sh 5 rm -all There is a point a few minutes in where it is just screaming on lots of little object files. I took the TOP snapshot at the peak during that time on each snapshot. Just rough data, but kind of interesting anyway.
    Processes: 94 total, 9 running, 85 sleeping, 421 threads                    08:03:04
    Load Avg: 3.29, 1.34, 0.71  CPU usage: 35.11% user, 8.80% sys, 56.7% idle
    MemRegions: 27787 total, 1490M resident, 27M private, 625M shared.
    PhysMem: 818M wired, 2245M active, 861M inactive, 3924M used, 162M free.
    VM: 243G vsize, 1033M framework vsize, 1435350(12) pageins, 56177(0) pageouts.
    Networks: packets: 4048690/3574M in, 4130201/2714M out.
    Disks: 26124670/217G read, 1577493/55G written.
    97240  taskgated    0.6   00:00.08 3     0    44   41     700K+  244K   1276K+ 81M
    96923  sh           0.0   00:00.01 1     0    14   24     316K   852K   836K   17M
    96916  top          7.8   00:17.71 1/1   0    46+  33     1344K  264K   1924K  17M
    96831  ugslmd       0.0   00:13.50 3     0    28   46     18M    244K   19M    68M
    96803  mdworker     8.2   00:07.60 3     1    56   186    14M+   20M    29M+   98M
    83432  cc1          0.0   00:00.11 1/1   0    14+  50+    12M+   7156K+ 15M+   84M+
    83431  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    83430  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    83425  cc1          0.0   00:00.13 1/1   0    14+  53+    15M+   7156K+ 18M+   87M+
    83424  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    83423  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    83418  cc1          0.0   00:00.17 1/1   0    14+  61+    21M+   7156K+ 25M+   93M+
    83417  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    83416  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    83392  cc1          0.0   00:00.38 1/1   0    14+  85+    43M+   7156K+ 47M+   115M+
    83391  i686-apple-d 0.0   00:00.00 1     0    14+  34+
    same with ./jbuild.sh 6 rm -all
    Processes: 91 total, 6 running, 85 sleeping, 404 threads                    08:06:53
    Load Avg: 4.48, 2.60, 1.37  CPU usage: 72.76% user, 4.80% sys, 22.42% idle
    SharedLibs: 7504K resident, 784K data, 0B linkedit.
    MemRegions: 28044 total, 1525M resident, 26M private, 698M shared.
    PhysMem: 806M wired, 2367M active, 711M inactive, 3883M used, 205M free.
    VM: 236G vsize, 1033M framework vsize, 1442627(7) pageins, 57238(0) pageouts.
    Networks: packets: 4049506/3575M in, 4131380/2714M out.
    Disks: 26129240/217G read, 1601440/56G written.
    96916  top          8.5   00:34.73 1/1   0    47   34     1604K  264K   2180K  17M
    96831  ugslmd       0.0   00:13.51 3     0    28   47     18M    244K   19M    68M
    96803  mdworker     0.2   00:14.19 3     1    56   207    16M    18M    31M    101M
    84180  sh           0.0   00:00.00 1     0    14   24     312K   852K   836K   17M
    77870- PackageMaker 0.0   04:20.72 3     1    408  401    34M    104M   57M    105M
    72995  cc1          0.0   00:00.42 1/1   0    14+  80+    38M+   7156K+ 42M+   110M+
    72994  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    72993  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    72988  cc1          0.0   00:00.52 1/1   0    14+  75+    37M+   7156K+ 44M+   106M+
    72987  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    72986  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    72966  i686-apple-d 0.0   00:00.00 1     0    14   34     328K   460K   784K   82M
    72965  llvm-gcc-4.2 0.0   00:00.00 1     0    14   22     144K   284K   400K   73
    and just for grins ./jbuild.sh 8 rm -all
    Processes: 102 total, 3 running, 8 stuck, 91 sleeping, 417 threads          08:11:42
    Load Avg: 5.37, 3.53, 2.09  CPU usage: 92.49% user, 6.82% sys, 0.68% idle
    MemRegions: 28490 total, 1629M resident, 26M private, 871M shared.
    PhysMem: 807M wired, 2474M active, 638M inactive, 3919M used, 169M free.
    VM: 262G vsize, 1033M framework vsize, 1458600(0) pageins, 66437(0) pageouts.
    Networks: packets: 4049722/3575M in, 4131633/2714M out.
    Disks: 26136332/217G read, 1645731/57G written.
    96916  top          9.2   00:54.89 1/1   0    54   34     1680K  264K   2256K  17M
    96831  ugslmd       0.1   00:13.53 3     0    28   47     18M    244K   19M    68M
    96803  mdworker     0.3   00:24.31 3     1    56   265    26M    18M    34M    109M
    94051  cc1          0.0   00:00.34 1     0    14+  68+    28M+   7156K+ 32M+   100M+
    94050  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    94049  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    94046  cc1          0.0   00:00.34 1     0    14+  67+    28M+   7156K+ 32M+   100M+
    94045  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    94044  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    94037  cc1          0.0   00:00.43 1     0    14+  68+    31M+   7156K+ 37M+   101M+
    94036  i686-apple-d 0.0   00:00.00 1     0    14+  34+    328K+  460K+  784K+  82M+
    94035  llvm-gcc-4.2 0.0   00:00.00 1     0    14+  22+    144K+  284K+  400K+  73M+
    94030  cc1          0.0   00:00.56 1     0    14+  77+    39M+   7156K+ 46M+   109
    And I/'m gonna let that one finish, because it peaks in the high fives, which is hard to get for a load average. Maybe too high. The fours are generally sweet, and indicate the machine is running very quickly. That one might come in under 15 minutes, depending. Edit: It actually took a bit longer. I suspect the OS got starved for CPU time on this one, clogging things more than enabing them.
    **used to do a fair amount of system profiling for large data applications, and this stuff interests me some.
    Today, I gotta get the USB devices sorted out so I can write some programs. :) This ended being a fun distraction, aside from building just to get the GCC for this Mac OS. Needed that. I will have questions. Probably embarrasing ones. lol
    Going forward, I can leave this Mac all setup. If a package needs to be made, let me know. In P2 land, it's probably just me. But in P1 land, there could be older Mac computers out there. The V1.0 build that works with P1 that Steve did is in the dropbox. They all have P2load in them, but it can be ignored / removed easy enough.
    One of you guys should edit the install / readme / whatever document to reflect what I learned on Mac OS. Path, permissions, etc... are handy to know for passers by who may not pick up our dialog here. I can make edits, if you tell me what document and where too. Easy enough to fetch it, add, then attach here for you guys to drop back into the mix when it makes sense.
    edited 2013-05-23 08:47
    Doug, send me your google email address and I will add you to propgcc contributors.
    edited 2013-05-23 13:16
    Work finished, food eaten, kids to bed, Prop2 play time :D just copied the ww1024x600.bin to SD card, put it in DE2-115 board, built the wireworld c demo that David kindly ported, and it works :D so I can now start getting the rest of my drivers ported to work with C.
    Happy days..
    btw C guys, for the file handling stuff, does it have any directory stuff ported? or is it all root? and can you do findfirstfile and findnextfile?
    edited 2013-05-23 13:45
    Baggers wrote: »
    Happy days..
    Yes, the PropGCC file support handles directories using "/" as the separator.
    edited 2013-05-23 16:16
    Thanks David, does it do findfirstfile etc? or some other way of getting a directory?
    edited 2013-05-23 18:51
    Baggers wrote: »
    I think it implements a subset of the Linux directory API. Check dirent.h.
    edited 2013-05-24 00:56
    Will do, thanks :)
    edited 2013-05-25 18:46
    The build I did works. Actually both work. Shall I add those to the downloads section? The GCC V1.0 build would interest P1 users running snow leopard or newer. It might actually run on Leopard too. I don't have a system to check and the docs I read are still unclear to me. In any case, I have that one right. It's the 1.0 release.
    A bigger question is whether or not to put *any* of the interim ones for P2 up there, or just use the Dropbox for the few, if any people, interested. Thoughts.
    @Jazzed, I'll find the docs and add what I learned at some point in the near future. Thanks.
    BTW: I built everything just as an ordinary user. I don't know that the root build instructions are needed. Can one of you expand on that some? And Smile, this thread is kind of meandering a little, but it's where the conversation is. Point me somewhere else, if warranted. :)
    I'm up and coding C on my P2 emulation, and I'm on a Mac. Only the task of connecting the Prop Plug to an XP VM for Pnut, and I'm set for a while, but for Win 7 code.
    I don't know how to tell about the Prop Plug state like I can on a Windows machine, but P2load seems to know. I need to get detail on this. Hints? (I know, read the P2load code, and I may do just that, but would appreciate a pointer if somebody has sorted this all out.)
    Thanks Baggers and David for putting a little starter code out there that would interest me. It's a big help. Now I've got to work on sucking less at C. :)
