LED Question
ajward
Hi All...
I'm experimenting with a 10 segment bar graph display. At first, I plan for no more than one bar to displayed at a time. Can I get away with connecting a current limiting resistor to just the cathode for now? Understanding that I might have to put resistors on each of the anode leads later on.
Thanks for any wisdom!
Amanda
Amanda
What could happen? If that resistor value is right for driving a single bar at reasonable brightness then if you accidentally turn on two or more bars those LEDs will get half or less of the current they like each and glow dimmer. No harm done.
Amanda
edit: Though the display was discontinued and not listed in the local Radio Shack inventory, and the manager gave it to me for free! Yay 'Shack!
Everything about mircocontrollers in binary, except these LED displays. Very mysterious. I guess the human interface just needs to pretend that decimal numbers are in control.
I do have a pile of rectangular LEDs with which you can build your own bar graph of any number. But be forwarned, it take practice and patience to get them to align perfectly when soldering.
Up to eleven is now a key part of western culture:
http://en.wikipedia.org/wiki/Up_to_eleven
http://tvtropes.org/pmwiki/pmwiki.php/Main/UpToEleven
So I sugest wiring eleven LED's by hand. After all, if someone's LED bar graph is at ten it's maxed out. But with eleven LED's you can go one brighter then them.
They're in the food business too.....
Homemade LED bargraph. Uses a header socket and 2mm LEDs. The LEDs can be quickly rearranged, changed out for different colors, or they can be removed completely to allow access to the Propeller pins. Uses a DIP resistor array for current limiting (in the foreground between the reset button and voltage regulator).
...plus, you can go to 8, 10 ....or even 11!!
I guess if you had 11 LEDs, you could use one 6x and one 5x end to end. There are solutions for those that think.
