Low voltage pneumatic valve
For anyone looking for pneumatic valves, I just came across this article. Looks like Bimba is offering a 3 and 5VDC version of their Isonic line of valves. May open up come possibilities.
Personally, my opinion of Bimba is that all their mainstream components are disposable-- no way to rebuild them if needed-- and had a cheap quality to them. I tended to shy away from them.
But technology and materials have changed in the 10 or so years since I've last used them. Maybe it's time to revisit.
1 Horsepower is roughtly 745 Watts.
If you need any really powerful devices, you are going to have to convert 3.3V or 5.0V control logic to both more AMPS and more VOLTS. So it seems silly to cater to the tiny, nearly useless devices. Granger has real stuff for gritty DIYer in the Mid-west of the USA.
Follow the power. Your microcontroller will awe people.
Is there really a market niche for small battery powered pneumatic devices?
Actually, I was thinking more in the way of embedded industrial applications. Even if you use them as a pilot valve to drive a larger pneumatic valve, the electrical power consumption is less than the standard 24VDC valves in use today.
So... wait for it... I was following the power...
Not everyone here is a DIYer...
Still it is hard to comprehend what inspired these devices if it wasn't seridipity and an excess of either cash or enthusiasm.
Microcontroller seem to do more and more with a few watts, but machines seem to always do more and more with more watts.
I could see these valves finding a lot of use in instruments and medical/lab/diagnostic equipment. And as Jordan said, for things like pilot valves.
Come to think of it, pick and place conveyors or sorters might have a need for these. I'm thinking of "puffing" applications where small, precisely aimed jets of air are used to eject a faulty part from a tray, bin or conveyor.
Who knows... maybe we'll end up seeing them in inoculation guns. Hey, wait! I'm trademarking that! Or copyrighting it! Or patenting it! Whatever it takes to make bazillions.
You do not necessarily need high power solenoid valves to control high pressure large volume flow of liquids. A low wattage servo-hydraulic valve can control a hydraulic system that moves fast enough to produce audible sound waves yet can apply forces in the thousands of pounds range.
But if I were thinking of aplpications:
- single point grease dispenser-- in the 1-3 gram volume range.
- Small pick/place-- already mentioned, but could be either a gripper or vacuum.
- small air knife-- already mentioned
- poka-yoke
- pilot actuator
In either an embedded application or as a proof of concept, I wouldn't summarily reject them due to perceived limitations. Sometimes it just needs a little inspiration. As we speak, Rforbes is on his way to bazillionairedom (yes, I just made that up...).Lawson
