DC-DC relay help... no mohawks allowed:)
I've been looking at this on and off for several weeks and have come up empty.
I am driving two (at the moment... 4 in the future) 24V 15A wheelchair motors with a Sabertooth 2X60 control board from DimensionEngineering..http://www.dimensionengineering.com/products/sabertooth2x60
I prefer using analog(pwm) mode... which requires a 2.5v signal to be neutral. Any other signal (or no signal) causes the controller to drive the motors.
I have a circuit, which at start up maintains a 2.5v signal until the circuit is turned off by a Propeller pin output. Theoretically, if the Propeller fails, the circuit will stop the motors.
And until the Propeller starts up... the circuit remains active, keeping the motors neutral. So far, so good.
In actual practice, I also want to use some type of normally open relay...also hooked up to a Propeller output... which would only allow the motors to receive current once engaged by the Propeller.
I have some DC-DC SSRs... but there is a problem. This particular controller features regenerative braking... and from what I read, if I simply put an SSR between the battery and the controller...
and the relay is turned off while the motors are turning, the controller could be damaged. I have read that this could occur, while simply pushing the wheelchair along.
However, since the motors are bi-directional... I can't put the SSRs between the controller and each motor... can I?
Assuming I can't use SSRs what is the best mechanical relay to use between the controller and the motors... and can be controlled by a Propeller?
Having said that, you really need to have a logical plan for all you want to do with a clear set of fail-safe priorities.
The Propeller's 3.3 VDC can be boosted to 24VDC to engage the relay coils without much difficulty. You could use either a high gain transistor, a power darlington-pair, or a power MOSfet to drive the relay coils. I think a TIP12O power darlington would drive just about any large 24VDC relay coil you might use, and there is very good likelyhood that somethig much less, such as a simple 2n2222 which can provide 500ma at 24VDC would be adequate.
But this all takes knowing what the power requirements of the selected relay are and working backwards. So you do have to figure out what switches you want where and what sequence of control you want. Also you need to understand how they respond to having the power completely removed.
So having a clear set of priorities and working logically with how the devices power up and down is the first issue. Then there are whatever logical controls you want to impose.
Why not put the lock out relays .. which would be DPDT .. between the motors and the controller? When all power is removed, the controller would see open circuits instead of motors. And motors that freewheeled would be sending power nowhere. Of course, it you need brakes, you will have to find them via another mechanica configuration. But I hope you weren't considering the regenerative braking as your sole source of brakes in a real world situartion.
Any robot that is large and heavy and going to roll up and down slopes needs real brakes.
I think my problem is that the specs are confusing me:) I need to pass up to 25A peak at 24V. But most specs are for AC... and I just don't get it:(
The brake issue. You are right. There was solenoid style brakes on the motors, but to fit the encoders on the motor shaft, I had to remove it. I have some other wheelchairs, where this is not a problem.
This is a test platform, so I think I can get away with controller braking for the moment.
Any help is appreciated.
Rich
You may find that a 50 amp DPDT 24VDC relay is difficult or expensive to locate and may have to settle for a more economical 30 amp.
In your application, it will allow you to establish the control voltage from the Prop before energizing the power circuits. This will prevent unwanted operation of the motors and will give an independent means ( Emergency Stop switch) to shut the motors off as well.
Cheers,
Coil current rating at 2VA is a bit confusing. It is a 24VDC coil. I would want coil resistance in ohms.
And while the contacts are rated for 240VAC, 10% of that is not uncommon for use with DC.
http://www.grainger.com/Grainger/DAYTON-Power-Relay-3X749
http://www.galco.com/buy/Magnecraft-Schneider-Electric/W199X-13
For use with a motor, the article suggest 20% of the rated use... so a 40 amp relay would be used for an 8 amp motor load.
So ideally a 25 amp motor would want a 125 amp rated relay. There are 130 amp 24VDC automotive relays, but they seem to be single pole single throw, single pole double throw, and double pole single throw configurations. I can't seem to locate a DPDT.
http://www.onlinecomponents.com/te-connectivity-amp-brand-1-1414428-0.html?p=28218728
Search 'automotive relays high current devices'
BTW, the 240VAC 40 amp relays are acceptible for up to 28VDC at 40 amp rating. This is another derating factor by use, not by voltage.
http://en.wikipedia.org/wiki/Relay#Derating_factors
and then there is the issue of contact arc suppression
http://en.wikipedia.org/wiki/Contact_protection
http://www.industrologic.com/mechrela.htm
Thanks guys
This is why we learned E=IxR and all it's derivatives.
2VA / 24V = 0.083A
24V / 0.083A = 288 Ohms
Since a 2n2222 is good to about 800 milliamps and 40Volts, it has enough headroom, but would require more current that a small darlington solution.
I guess the coil says VoltAmps because one might power the coil at 20 volts, and then 2/22 = 0.100A or 100 milliamps... while resistance would become 220 ohms. Not really clear on the implications of resistance being different.
Volts x Amps = Watts, so is it really the coil just wants to be driven at the right amount of watts and not limited by physical resistance?
Driving the 2n2222 at 3.3 volts and 10ma would likely work well... so 3.3/.010 = a 330 ohm current limiting resistor between the Propeller output and the transistor base.
A 2N2222A has a minimum Hfe (gain) of 35 so the base current needed to provide 83mA would be 0.083 / 35 = 2.371mA, which would require a base resistor of a little over 1K. I usually use a gain of 20 for the resistor calculation to be sure the transistor is saturated, and that would give a base resistor of 626 ohms, so I would use a 680 ohm base resistor in this case.
Not really sure what you are trying to say here. The coil is designed (# of turns & wire size) to have the resistance needed to limit the current to a value that will reliably pull in the relay contacts. The VA rating is based on the current drawn at the rated voltage. If you powered the coil with 20V the coil would draw less current (20 / 288 = 69.4mA) and might not pull in the relay contact. Of course the actual VA drawn would only be 20V x 0.069A = 1.38VA
For a coil powered by a DC voltage it is watts. The VA rating is how the manufacturer chose to rate it. It could also be rated as 2W at 24VDC or 188 ohms, 24V DC.
See the first answer. A 330 ohm resistor would certainly work well, but it would provide more base current than is really needed.
B. I hate the VA specification as it seems to be going in the back door when all your really need to know is how many Amps are needed at the proper voltage. I do admit that the coil has reactance as well as resistance. So it actually may require more current that what the measured resistance would indicate. I just don't see why they give me a specification that requires obscure math calculations.
C. I am deeply concerned with the current derating of mechanical relays to 20% when used with motors. This is a huge number and in the case of a 25 amp motor, it results in a jump form a $40 DPDTrelay to maybe having to use more than one relay DPST costing over $100USD.
A. For switching a relay on driving the transistor into saturation is a good thing since it minimizes the transistor power dissipation. For times when maximum switching speed is wanted it is not so good.
B. I agree. The most useful rating would be the coil current and the nominal AC and DC voltage.
C. This is done mainly to deal with the motor starting current and potential arcing on stopping.
These seems to take me back to looking at Solid-State Relays as there is NO arcing and the newer ones are smaller, cooler, and much cheaper that the mechanical relay solution.
Solid State may be much cheaper to build as well.
But to get a DPDT relay in solid state, one would have to use 4 SPST devices.
And, the hazard of solid state relays is that they fail to an ON state, while the mechanical fail to an OFF state.
