Simple question on how to use Propeller EEPROM object
Need some help here determining what Im doing wrong. Im trying to learn how to save data to EEPROM so I can retrieve it back. Below is the code. It should be pretty straight forward.
Thank You
Steve Woodrough
Thank You
Steve Woodrough
{{ Experiment to understand how to read and write data to the EEPROM. Will be used in my Magellan Bot project. }} CON ' Constant declarations ' System clock settings - 80 MHz _clkmode = xtal1 + pll16x ' Low speed external crystal 16x PLL _xinfreq = 5_000_000 ' Crystal input frequency is 5 MHz VAR ' Variable declarations long A,B,C,D OBJ ' Object declarations eeprom : "Propeller Eeprom" ' Propeller EEPROM object FDS : "FullDuplexSerialPlus" ' PST Pub Main FDS.start(31, 30, 0, 115200) waitcnt(clkfreq+cnt) 'Pause a second fds.getstr(string(" ")) 'Wait for enter key repeat fds.str(string(13,"Retrieving data from EEPROM")) eeprom.FromRam(@A,@D, 0) 'Should be retrieving whatever is in EEPROM fds.str(string(13,"Data retrieved from EEPROM")) fds.str(string(13,"Value of A from EEPROM = ")) fds.dec(A) fds.str(string(13,"Value of B from EEPROM = ")) fds.dec(B) fds.str(string(13,"Value of C from EEPROM = ")) fds.dec(C) fds.str(string(13,"Enter A",13)) A:=fds.getdec fds.str(string("Enter B",13)) B:=fds.getdec fds.str(string("Product is = ")) C:=A*B fds.dec(C) fds.str(string(13,"Saving data to EEPROM")) eeprom.FromRam(@A,@D, 0) 'Should be writng variable data to EEPROM fds.str(string(13,"Data saved to EEPROM")) A:=B:=C:=D:=0 'Zero out values
To save your variable "A" to EEPROM in the same location in the EEPROM use:
You need to add the "+ 3" to include the three additional bytes in the long besides the byte located at @A.
To read this data back from EEPROM use:
If you want to use free sections of the EEPROM that won't be overwritten when you save a new program, use addresses higher than $8000 (assuming your have a 64K EEPROM).
So to write your variable "A" to upper EEPROM, use:
To write all four variables to upper EEPROM, use:
Thank you for taking the time.
Point taken on the choice of address. I'll move it up the range. I was just trying to get a result to get a feel for the object.
Steve
Don't use the program as a guide to using EEPROM. It's full of bugs. The part which checks the size of the EEPROM works but not much else.
