Simple question on how to use Propeller EEPROM object
Need some help here determining what Im doing wrong. Im trying to learn how to save data to EEPROM so I can retrieve it back. Below is the code. It should be pretty straight forward.
Thank You
Steve Woodrough
Thank You
Steve Woodrough
Experiment to understand how to read and write data to the EEPROM. Will be used in my Magellan Bot project.
CON ' Constant declarations
' System clock settings - 80 MHz
_clkmode = xtal1 + pll16x ' Low speed external crystal 16x PLL
_xinfreq = 5_000_000 ' Crystal input frequency is 5 MHz
VAR ' Variable declarations
long A,B,C,D
OBJ ' Object declarations
eeprom : "Propeller Eeprom" ' Propeller EEPROM object
FDS : "FullDuplexSerialPlus" ' PST
Pub Main
FDS.start(31, 30, 0, 115200)
waitcnt(clkfreq+cnt) 'Pause a second
fds.getstr(string(" ")) 'Wait for enter key
repeat
fds.str(string(13,"Retrieving data from EEPROM"))
eeprom.FromRam(@A,@D, 0) 'Should be retrieving whatever is in EEPROM
fds.str(string(13,"Data retrieved from EEPROM"))
fds.str(string(13,"Value of A from EEPROM = "))
fds.dec(A)
fds.str(string(13,"Value of B from EEPROM = "))
fds.dec(B)
fds.str(string(13,"Value of C from EEPROM = "))
fds.dec(C)
fds.str(string(13,"Enter A",13))
A:=fds.getdec
fds.str(string("Enter B",13))
B:=fds.getdec
fds.str(string("Product is = "))
C:=A*B
fds.dec(C)
fds.str(string(13,"Saving data to EEPROM"))
eeprom.FromRam(@A,@D, 0) 'Should be writng variable data to EEPROM
fds.str(string(13,"Data saved to EEPROM"))
A:=B:=C:=D:=0 'Zero out values
To save your variable "A" to EEPROM in the same location in the EEPROM use:
You need to add the "+ 3" to include the three additional bytes in the long besides the byte located at @A.
To read this data back from EEPROM use:
If you want to use free sections of the EEPROM that won't be overwritten when you save a new program, use addresses higher than $8000 (assuming your have a 64K EEPROM).
So to write your variable "A" to upper EEPROM, use:
To write all four variables to upper EEPROM, use:
Thank you for taking the time.
Point taken on the choice of address. I'll move it up the range. I was just trying to get a result to get a feel for the object.
Steve
Don't use the program as a guide to using EEPROM. It's full of bugs. The part which checks the size of the EEPROM works but not much else.
