I need help to connect 2 relay module to BS2sx
Hi,
I just got this 2 relay module and I want some help to connect it to BS2sx, I'm not an electrician and I have no idea about electricity, so I did't want to connect it with out some help. And It has a jumper and I don't know what it is for, so if someone who could possibly explain it. Please some help.
http://www.sainsmart.com/arduino-pro-mini.html
Thanks.
:thumb:
Thanks.
I have found this, I hope it could help cause I don't understand much of this.
http://yourduino.com/sunshop2/index.php?l=product_detail&p=218
Thanks.
I don't see a jumper. If you're referring to the 3-pin header, that's for JD-VCC (and VCC and GND).
Hi,
Yes the 3-pin header (JD-VCC, VCC and GND) and the jumper is in JD-VCC AND VCC, so do you mean that I have to remove the jumper in JD-VCC AND VCC and connect both to VDD and GND to VSS of the 3-pin header and IN1/IN2 to I/O or do I connect the VCC and GND from the 4-pin header (GND,IN1,IN2 and VCC) to the BS2sx.
And I have some questions,
What is the difference between VCC and GND in the 3-pin and 4-pin header?
What is the JD-VCC?
And What is the jumper for?
I would like to know in order to share the information about this with others who have the same problems.
Thanks.
I'm assuming that all the places marked VCC are connected together and that all the places marked GND are connected together. That's the convention.
So if all VCC and GND are connected together I could leave the Jumper there and connect the VCC next to the IN-PIN TO VDD and GND (in the 3-pin header) to VSS or do you recommend that I take off the jumper and connect both JD-VCC and VCC (3-pin header) to VDD?
VCC needs to be connected to a source of +5V with enough current capacity to handle the requirements of the relays plus a little more (10s of mA). GND needs to be connected to the common ground (of everything digital). If you leave the jumper between JD-VCC and VCC on the 3-pin header, you can otherwise ignore the 3-pin header and just use the 4-pin header for VCC, GND, and the two INx connections.
http://www.rambal.com/descargas/libros/Manual-de-uso-Placa-SX-1.pdf
and for example I want to control 2 lamps so I would need the IN1 FOR 1 lamp and IN2 for the other.
And how can I give it a plus (10s of mA) to the current capacity (+5V) for the relays requirements?
Based on the link that you gave, (and my Spanish is rusty), you can use VDD in the upper left on the board for your 5 volt supply to the relay. The header marked VSS is the ground connection.
From what I see in the PDF, the regulator is a standard 7805, 5 volt regulator. It is capable of supplying 1.5 AMPs @ 5 volts, (varies a little between manufactures).
This regulator normally wants to see at least 7 volts on the input to give a good supply of 5 volt to the board. I would add another battery in series to the input, (12 volts), to provide enough voltage. The regulator will handle up to around 25 volts. At 12 volt input, the regulator might get a little warm.
The battery might be 6 volts with a fresh charge, but after it drops below that, the circuit will be inoperable, as the regulator can not supply the correct voltage to the board and relays.
I will try to get another +6V battery or a +12V battery before trying it, I'll try with the jumper.
A question if I take out the jumper the JD-VCC must be +5V or it can be another? Why?
Thanks for the help.:thumb::thumb:
Try and understand the quote from the PDF you supplied:
Since this is not a Parallax product, you may have to contact the manufacturer for a better description.
