Broken chip?
I bought the prop stick at the OPC, went home plugged it in and it says no prop chip found on com 9. My computer says it was installed correctly though and leds flash. Re-installed it... same message comes up. My quick start board works fine(that's com 6) Wonder if there is a problem with the coms...? Any other thoughts or did i just get a defective chip?
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32210-PropStickUSB-1.2.pdf
