Is this a bridge rectifier for converting AC to DC?
http://www.st.com/web/en/resource/technical/document/datasheet/CD00074275.pdf
I ordered a few of these and cant figure them out, i'm connecting them to a 28V transformer and getting 11v out. The more I look at that data sheet I only see two diodes and don't see the word bridge so i'm wondering what these are for, hoping I didnt waste my money.
There are all types of rectifiers. Half wave rectifiers included, which is apparently what you came up with. Four diodes can make a bridge rectifier, so two of your modules can make a bridge.
And yeah, there is more than one way to get a full bridge rectifier. This might be very nice for powering a solid-state audio amp.
It is possible to rectify without a diode. This is the case when trying to achieve top efficiency by actively switching transistors in place of diodes ... but even then there is usually some diodes (possibly inherent in the transistor) present for backup/startup purposes. They just spend most of their time sitting idle due to the transistors cutting them off.
What's a bridge rectifier? Well, I suspect that is a full-wave rectifier matrix of 4 diodes. There is also the full-wave 2 diode solution that has NO 'bridge'.
And the half-wave rectifier configuration. Maybe more than one.
Is it possible to rectify without a diode? I think that depends on what you call a diode. Rectifier tubes are diodes, Amplification tubes are triodes, pentodes, etc.
Using a transistor to rectify is really using two diodes in an NPN or PNP configuration.
Then again, there is the 3-phase bridge rectifier.... more diodes.
http://en.wikipedia.org/wiki/Rectifier
A half wave rectifier is a single diode that produces a pulsating DC output from either the positive or negative half cycle of the AC.
Two diodes can be used with a center tapped transformer to produce full wave DC.
If seems that two diodes alone are never a 'bridge rectifier' but can be used to create just about any that you might wish.
http://en.wikipedia.org/wiki/Diode_bridge
http://www.youtube.com/watch?v=KGb-nUK41tc
Ahh yes, the good old days. Good riddance!
I thought about Alfred Nobel and his dynamite, but it was his brother Emil who died in a factory explosion.
I thought about Marie Curie and her radioactive gloop but she did at least live to the age of 67.
I guess it's just that the ones who died trying never managed to do enough to become famous.
P.S Erco. Did you know that Alfred Noble invented plywood? He wasn't an evil monster after all.
Tesla went mad and there is much speculation about why. Mercury, Lead, and Cadium perhaps.
What about the Manhattan Project.. Did one of the leading scientist actually grab a chunk of U235 to prevent it from going critical?
What about developers of X-rays and radiation burns?
And heavy metal poisionings amongst metallurgist that developed new steel alloys.
Alfred Nobel invented plywood? I didn't know that.
I knew Bill Whelan and in the 1970s he was reputed to be Mr. Plywood for all of USA and Canada.. the leading US authority on making it. I worked for him, took care of his several homes around the Northwest. http://trove.nla.gov.au/work/51092089?q=william+whelan&c=article&versionId=64029012
I read a Tesla biography a while back and don't recall he went mad any more so than many of us will get dementia anyway. Have to check.
Manhattan project, yes, there were two criticality accidents killing Louis Slotin and Harry K. Daghlian. On the whole the Manhatten guys came out of it quite well I thought.
Perhaps this line of inquiry is a bit morbid. I should drop it.
"Mr Plywood", what a great title.
I second that!
Yes, instead these are the days when inventors are still found alive after explosions, electro-not-quite-cution, or poisoning, but fortunately only one at a time
