What is the fastest way (in SPIN) to rotate a specific number of bits
I need a method that rotates a specified number of bits (not necessarily 32, so I can't use ->/<-).
For example, the method could be called light this smallROR(%11_1011_0100 {value}, 10 {bit count}, 3 {bits to rotate}) and the result should be %10_0111_0110. I need both rotate left and right.
And just like how the rotate instructions work, I need it to accept rotate values larger than the number of bits being rotated. So for our 10-bit example, if bits to rotate were 13, it would yield the same result.
Here is what I have so far, but I know you guys will come up with a much better way of doing it:
PUB smallROR (value, bitsize, rotatebits)
'' Mimics rotate instruction, but for a bit count less than 32 (great for rotating a byte or a word)
'' bitsize is the rotation bountries (everything outside of the lower bits will be removed)
'' rotatebits is the number of bits to rotate
RETURN (((value &= (|< bitsize) - 1) & ((|< (rotatebits //= bitsize)) - 1)) << (bitsize - rotatebits)) | (value >> rotatebits)
{PUB smallROR (value, bitsize, rotatebits) | upper
'' Expanded version of the above method
rotatebits //= bitsize ' constrain rotation
value &= (|< bitsize) - 1 ' constrain value
upper := value & ((|< rotatebits) - 1) ' get what will go in the upper bits
value >>= rotatebits ' shift bits lower
value |= upper << (bitsize - rotatebits) ' put upper bits in place
RETURN value
PUB smallROL (value, bitsize, rotatebits) | dif
RETURN ((((|< (rotatebits //= bitsize) - 1) << (dif := (bitsize - rotatebits))) & value) >> dif) | (value << rotatebits) & ((|< bitsize) - 1)
{PUB smallROL (value, bitsize, rotatebits) | lower, dif
dif := (bitsize - rotatebits) ' number of bits to shift
lower := ((|< (rotatebits) - 1) << dif & value) >> dif ' get what will go to the lower bits
value <<= rotatebits ' shift bits higher
value |= lower ' put lower bits in place
RETURN value
PUB smallROR( value, bitsize, rotatebits ) return { } (value >> rotatebits) | { } (value << (32 - rotatebits) >> (32 - bitsize))JonathanAnyone else with a potentially better solution (seems hard).
And here is why I ask on the forums, because that is so much more ellegant and so much faster it's not even comparable.
Jonathan
