What is the fastest way (in SPIN) to rotate a specific number of bits
Bobb Fwed
I need a method that rotates a specified number of bits (not necessarily 32, so I can't use ->/<-).
For example, the method could be called light this smallROR(%11_1011_0100 {value}, 10 {bit count}, 3 {bits to rotate}) and the result should be %10_0111_0110. I need both rotate left and right.
And just like how the rotate instructions work, I need it to accept rotate values larger than the number of bits being rotated. So for our 10-bit example, if bits to rotate were 13, it would yield the same result.
Here is what I have so far, but I know you guys will come up with a much better way of doing it:
PUB smallROR (value, bitsize, rotatebits) '' Mimics rotate instruction, but for a bit count less than 32 (great for rotating a byte or a word) '' bitsize is the rotation bountries (everything outside of the lower bits will be removed) '' rotatebits is the number of bits to rotate RETURN (((value &= (|< bitsize) - 1) & ((|< (rotatebits //= bitsize)) - 1)) << (bitsize - rotatebits)) | (value >> rotatebits) {PUB smallROR (value, bitsize, rotatebits) | upper '' Expanded version of the above method rotatebits //= bitsize ' constrain rotation value &= (|< bitsize) - 1 ' constrain value upper := value & ((|< rotatebits) - 1) ' get what will go in the upper bits value >>= rotatebits ' shift bits lower value |= upper << (bitsize - rotatebits) ' put upper bits in place RETURN value } PUB smallROL (value, bitsize, rotatebits) | dif '' Mimics rotate instruction, but for a bit count less than 32 (great for rotating a byte or a word) '' bitsize is the rotation bountries (everything outside of the lower bits will be removed) '' rotatebits is the number of bits to rotate RETURN ((((|< (rotatebits //= bitsize) - 1) << (dif := (bitsize - rotatebits))) & value) >> dif) | (value << rotatebits) & ((|< bitsize) - 1) {PUB smallROL (value, bitsize, rotatebits) | lower, dif '' Expanded version of the above method rotatebits //= bitsize ' constrain rotation dif := (bitsize - rotatebits) ' number of bits to shift lower := ((|< (rotatebits) - 1) << dif & value) >> dif ' get what will go to the lower bits value <<= rotatebits ' shift bits higher value &= (|< bitsize) - 1 ' constrain value value |= lower ' put lower bits in place RETURN value }
Anyone else with a potentially better solution (seems hard).
And here is why I ask on the forums, because that is so much more ellegant and so much faster it's not even comparable.
Jonathan
