aSUS LAPTOP, LESS THAT $400usd TODAY — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2013-05-04 15:26 in General Discussion
http://sellout.woot.com/
Everyone knows I love Asus. This seems an excellent deal
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-05-03 07:59
    Toshiba Satellite C855-S5194 $299.99 at Staples B&M
    - Intel® Core™ i3-3120M 2.50GHz 3MB Cache Processor
    - 6GB DDR3 1600MHz Installed Memory, expandable to 16GB
    - 640GB 5400 RPM SATA Hard Disk Drive
    - 15.6” diagonal widescreen TruBrite® TFT display at 1366 x 768 native resolution (HD)
    - Windows 8
    - 6 cell/48Wh Lithium Ion battery pack
    http://www.fatwallet.com/forums/hot-deals/1270901/
    edited 2013-05-03 09:25
    tonyp12, that is smokin'!
  • pedwardpedward Posts: 1,642
    edited 2013-05-03 21:03
    Does it bug anyone else that Intel's cpu naming scheme is so convoluted?
    I seem to recall:
    i3 dual core
    i5 quad core
    i7 quad core HT
    Now there is only a small difference between the i3 and i5 offered in the OP's laptop.
    The i3 doesn't have turbo or AES new instructions, the i5 does, essentially little difference.
    edited 2013-05-03 21:22
    I grabbed one at Staples and that $100 off coupon works. They were sold out of that unit, but they had the next one down, the C855-S5350, for $279 after $50 rebate. They threw in a coupon for a free Windows 8 class!
    http://us.toshiba.com/computers/laptops/satellite/C850/C855-S5350?cm_mmc=search-_-suggestion-_-c855-s5350
    edited 2013-05-03 21:30
    The main problem of these laptops is their low resolution, paired with relatively large screen size. So image is VERY grainy.
    edited 2013-05-03 21:41
    CuriousOne wrote: »
    Not bad to these old eyes. :) specs: 1366x768 (HD), 16:9 aspect ratio, Supports 720p content
    edited 2013-05-03 22:50
    Neither mine are way too fresh, but higher resolution is always better.
    Staples has lots of laptops on sale, and that fatwallet coupon takes $100 off any Win 8 machine. This $299 HP AMD-based laptop would only be $199 after using that coupon (WHICH expires today). Probably a decent basic machine. http://www.staples.com/HP-2000-2c32nr-156-Laptop/product_188412&cmArea=CIRCULAR
    EDIT: I just called Staples and that coupon won't work on the cheap HP. That item # is the only one singled out in the fine print. Foiled again !!!
