Could the Propeller be wirelessly programmed? — Parallax Forums
blittledblittled Posts: 695
edited 2013-05-03 15:08 in Propeller 1
I was just brainstorming and was thinking of using a blue tooth to serial or wifi to serial and sent it to a Propeller (or any mcu) that was programmed to receive serial then bit banged it out in the protocol required to program a Propeller. Could this be a possible way of programming a Propeller wirelessly?
Edit: Of course you would have to use PST to make a bin file first then send it possibly by a terminal program to the Propeller doing the conversion
