Could the Propeller be wirelessly programmed?
blittled
I was just brainstorming and was thinking of using a blue tooth to serial or wifi to serial and sent it to a Propeller (or any mcu) that was programmed to receive serial then bit banged it out in the protocol required to program a Propeller. Could this be a possible way of programming a Propeller wirelessly?
Edit: Of course you would have to use PST to make a bin file first then send it possibly by a terminal program to the Propeller doing the conversion
You can use wixels: http://forums.parallax.com/showthread.php/139534-Wireless-Programming-of-a-Propeller-chip-(video)
http://forums.parallax.com/showthread.php/127780-Upload-Prop-programs-via-XBee
Parallax has an App Note:
http://www.parallaxsemiconductor.com/sites/default/files/appnotes/AN007-SoftLoadXBee-v1.0_4.pdf
Yup. Covered in post #3
Don't you mean post #2?
Oh, don't you love the new forum?
BTW, I've used the Wixel method myself and it works great.
#2, #3 whose counting
2, 3, 5 and reaffirmed in #8, wixels do get around!!!
I used it (not recently, sadly), and it worked fine.
Please share your findings.
Enquiring minds want to know.
If I get a chance this weekend, I will resurrect the Wireless USB device and confirm how it works. There've been too may other (non-Propeller) projects going on, for too long.
TD
