Moving Project to Custom PCB...
I'm trying to work out my power details for my project....
How much power do I need to supply the propeller chip? I'm using 4 cogs and sending PWM to 3 devices.
3.3V and how many ???mAs
Thanks for any help!
dan.
dan.
At 80MHz, 4 active cogs and 4 idle cogs plus the hub will draw about 50mA with nothing connected to the I/O pins and "room temperature" (25C) operating conditions. Plan ahead for additional needs. I'd probably use a regulator that can supply 100mA, just in case I might need it in the future.
-- http://www.digikey.com/product-detail/en/LM2937IMP-3.3/LM2937IMP-3.3CT-ND/3701578
It's good for 400mA which provides lots of overhead to run all the cogs and drive IO pins as I might need.
Should be if it was running all the software and I/O devices it would power in actual use.
