Choosing and using bypass Capacitors
I found this worth to share with all http://www.intersil.com/content/dam/Intersil/documents/an13/an1325.pdf
a practical and well documented!
Email notifications don't seem to be working.
0.1 uf
0.1uf + 100pf , note 'dead' spot at 380mhz
100pf
4700pf
0.1uf + 4700pf
And yes, the email notification issue has been noted by a bunch o' people.
As others have also noted, I get the "Are you sure you want to leave this page" dialog box at every post.
Edit: Including this one!
I had a older engineer tell me something like this to watch for about paralleled caps, and it went in one ear and out the other, till I decided to try my cap set just to see what would happen.
I like the last line; sums things up nicely:
"There is no escape from this effect. Just check to be sure that your design's unwanted resonance doesn't occur at a frequency critical to your circuit(s) operation."
