Choosing and using bypass Capacitors — Parallax Forums
john_sjohn_s Posts: 369
edited 2013-04-21 14:19 in General Discussion
I found this worth to share with all http://www.intersil.com/content/dam/Intersil/documents/an13/an1325.pdf
a practical and well documented!
    edited 2013-04-19 10:17
    ...I agree - have used that reference many times!
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2013-04-19 15:28
    I recently came by a rigol dsa815 with tracking generator, and whipped up a test board to try some of my bypass caps. I was surprised to see that the .1uf and 100pf I had paralleled actually caused a dead spot, rather than complementing each other as some other combinations did.
    edited 2013-04-19 21:30
    ...please 'splain "dead spot"? :confused:
    edited 2013-04-20 18:29
    Test setup is tracking generator connected straight through stripline with caps soldered onto stripline. Obviously the lower the db the more effective.
    Email notifications don't seem to be working.
    0.1 uf
    0.1uf + 100pf , note 'dead' spot at 380mhz
    100pf
    4700pf
    0.1uf + 4700pf
    800 x 480 - 33K
    800 x 480 - 33K
    800 x 480 - 32K
    800 x 480 - 33K
    800 x 480 - 33K
    edited 2013-04-20 19:50
    ...another question - what were you expecting to occur with the aforementioned capacitor combinations?
    And yes, the email notification issue has been noted by a bunch o' people.
    edited 2013-04-20 20:10
    davejames wrote: »
    As others have also noted, I get the "Are you sure you want to leave this page" dialog box at every post.
    Edit: Including this one! :)
    edited 2013-04-21 13:08
    I was expecting the 100pf to complement the .1uf, but not to hurt the curve in part where the .1uf is strong. What exactly would you expect in this situation? Can you explain the rise at 382 mhz as shown? I would say its unwanted resonances perhaps similar to this http://licn.typepad.com/my_weblog/2011/01/bypass-capacitor-boobytrap-john-dunn-consultant-ambertec-pe-pc.html ?? Because neither cap on its own is as bad at 382mhz as paralleled.
    I had a older engineer tell me something like this to watch for about paralleled caps, and it went in one ear and out the other, till I decided to try my cap set just to see what would happen.
    ...good article - thanks.
    I like the last line; sums things up nicely:
    "There is no escape from this effect. Just check to be sure that your design's unwanted resonance doesn't occur at a frequency critical to your circuit(s) operation."
