Where to find a panel mount mini-USB socket?
I need some help in finding this exotic item.
I've been trying to find a panel mount female mini-USB receptacle that will also connect to the mini-USB port located few inches apart on the board.
In other words a Female mini-USB to male mini-USB on a short cable.
Anyone have any ideas or sources? I haven't found one yet!
I also found plenty of standard type A panel mounts but NOT a single that uses mini-USB receptacle.
I'm almost tempted to build those few that I need using a surface mounted mini-usb socket and add a pigtail with another matching plug.
http://www.mouser.com panel mount mini USB connectors
I guess I go this way https://www.sparkfun.com/products/9966 and attach a short cable with mini-B plug to it.
The panel part is B, not mini-B, but it terminates in a mini-B male to your board. It's just as easy to run an A->B cable from your PC as it is an A->mini-B cable.
